Home » Eclipse Projects » Remote Application Platform (RAP) » Custom Widget with Session Timeout
Custom Widget with Session Timeout [message #1480525] Thu, 20 November 2014 03:54 Go to next message
I'd like to implement a widget which shows the remaining time after which the session expires if the user is inactive. (For example a label showing "You are getting logged off in 5 minutes" which counts down every minute.)
Of course the widgets timer should be reseted after each user activity.
Currently i'm thinking about the following approach.
The idea is to write a custom widget. The label text is updated by JavaScript, so there shoudn't be any server-client-communication, which resets the server session timeout.
A MessageFilter registered on the ApplicationContext could call a reset-method on the RemoteObject of my Custom Widget.
I have only basic JavaScript knowledge and have never written a custom widget, so any hints on expected problems or advices for a better solution a very much appreciated.
Re: Custom Widget with Session Timeout [message #1480942 is a reply to message #1480525] Thu, 20 November 2014 11:16 Go to previous messageGo to next message
Hi, have you seen this post?
https://www.eclipse.org/rap/developers-guide/devguide.php?topic=server-push.html&version=2.3
You don't need JS or a custom widget to do this.
Re: Custom Widget with Session Timeout [message #1481822 is a reply to message #1480942] Fri, 21 November 2014 03:49 Go to previous messageGo to next message
Thanks for the link. I didn't know about the ServerPushSession.
Interesting, but i'm not sure if it is suitable for my problem.
If i'm updating my Label ("you are getting logged of in x minutes") every minute via the ServerPushSession, doesn't this reset the session-timeout?
Re: Custom Widget with Session Timeout [message #1482088 is a reply to message #1481822] Fri, 21 November 2014 08:27 Go to previous message
You are right, I tested it myself.
Maybe someone more competent could help you to find the best approach.
Previous Topic:OSGI Event on RAP not working
Next Topic:RAP and Cross Site Request Forgery attacks
Current Time: Sun Jul 20 05:35:19 EDT 2025
Powered by FUDForum. Page generated in 0.06209 seconds
