Home » Modeling » EMF » Element names in the generated XSD file(Generate a XSD from EMF genmodel)
Element names in the generated XSD file [message #1464350] |
Fri, 07 November 2014 07:59  |
I've a problem with the XSD generated from a given EMF model.
I would like to determine the element and attribute names used in the generated XSD. By default are the element names equal to the associated type names.
Problem description:
My EMF model is generated based on defined XSD, which contains element definitions named as well by lowercase letters as uppercase letters and containing characters such as '_','-'
e.g.
<xs:element name="schema_version" type="schema_version"
minOccurs="0" maxOccurs="1" />
In the generated EMF model is the obviously names rule for types names with first letter uppercase, for attributes names with first letter lowercase, further the characters '_','-' are omitted, so the corresponding interface is:
public interface SchemaVersion extends EObject { ...
Next up, I generate an XSD file from the EMF genmodel.
I receive an XSD with an element
<xsd:element name="SchemaVersion" type="SchemaVersion"/>
In consequence, my xml-file that validates the source XSD don't validates the generated XSD.
How can I determine the element names in the generated XSD. What is the solution to handle it?
I would be grateful if you would help me.
Inga
Re: Element names in the generated XSD file [message #1464425 is a reply to message #1464350] |
Fri, 07 November 2014 09:37   |
Inga,
Comments below.
On 07/11/2014 3:03 PM, Inga Ohlsen wrote:
Via the Export Model...? Version type of schema?
> generated XSD.
Determine how? Other than by looking at the result
If it's based on an XSD why are you saking about generating an XSD?
> e.g. ..
Keep in mind that schema types map to EClassifiers and schema element
and attribute map to EStructuralFeatures...
> Next up, I generate an XSD file from the EMF genmodel. I receive an
> XSD with an element
> <xsd:element name="SchemaVersion" type="SchemaVersion"/> ..
Using Export Model...? You should not generally expect an XSD -> Ecore
-> XSD to be a round trip...
I get the sense you generated some kind of XMI Schema, which corresponds
to an XMI serialization.
Firstly it seems pointless to generate a schema from a model generated
from a schema. You have the original schema. There's no need to
generate it. You've also not be clear what exactly you did to generate
a schema.
> Inga
Re: Element names in the generated XSD file [message #1467822 is a reply to message #1464425] |
Mon, 10 November 2014 05:39   |
Hello Ed,
thank You, for Your answer,
I explain what I intend with the source XSD.
My processing is the following.
I generate an EMF model and java classes on base on the XSD-file that I receive from the customer.
I receive from my customer XML files compatible to the input XSD with concrete data, by which I instantiate my model and java objects.
Next, I transform these objects in my own objects, whose have another structure. This objects I can process and
complete by appropriate method with my own data manipulating program (that works with my own model).
At the end I transform my model back to the input data structures then I have to deliver a handled xml to the
customer and this xml must of course validate the source XSD.
The last is not offhand the case, because the element and attribute names in the created xml are not all equal to the names defined in the source XSD
(problems with lowercase/uppercase letters and '-', '_' how described in my topic)
This is briefly the background of my problem.
Inga
Re: Element names in the generated XSD file [message #1467857 is a reply to message #1467822] |
Mon, 10 November 2014 06:14   |
Inga,
Comments below.
On 10/11/2014 11:39 AM, Inga Ohlsen wrote:
> Hello Ed,
> thank You, for Your answer, I explain what I intend with the source
> XSD.
That's also an Ecore model, but a different one?
> structure. This objects I can process and complete by appropriate
> model).
And EMF model?
> I have to deliver a handled xml to the customer and this xml must of
I see.
> source XSD (problems with lowercase/uppercase letters and '-', '_' how
Indeed the Ecore model's named model element names must be well-formed
Java identifiers...
In general, if you serialize your model instances and that model was
created by importing from XSD but the serialized result doesn't conform
to the XSD, the most likely cause is that you're not using the generated
XyzResourceFactoryImpl to create the resource that's being used to
serialize those instances. So find that generated resource factory
implementation (in the util package of your model), and make sure it's
being used. It's sometimes helpful to generated the *.tests project and
look at the XyzExample.java to see how things should be registered when
writing a stand alone application...
> Regards,
> Inga
Re: Element names in the generated XSD file [message #1477889 is a reply to message #1464425] |
Tue, 18 November 2014 02:37   |
Hi Ed,
maybe I can give some additional idea what we want to achieve:
A customer gave us an XSD which we import to EMF. Now we discard the
original XSD and work only with the EMF tooling to do small changes in
the model. So when the customer expects us to change something in the
XML, we do the changes in EMF and want to generate some XSD, that
validates the new XML.
So what we want to achieve is to migrate from an XSD as the leading
input from which EMF models are generated to EMF as the leading input
from which the XSD is generated.
> XSD -> Ecore > -> XSD to be a round trip...
I would not expect that the generated XSD looks exactly like the
original one, but I would expect that it validates the same XML
instances. And currently it does not.
The original XSD validates the serialized XML that the generated
EMF-Classes and the generated ResourceFactory produce. So far so good.
However, the generated XSD does not validate this XML as Inga stated.
I assumed that all information about XML identifiers is encoded in the
EAnnotations that were added to the EMF Model during XSD import.
However, the generated XSD seems not to respect those. Is there any
additional option we have to set in the generator model?
Hauke
Am 07.11.2014 15:37, schrieb Ed Merks:
> Inga,
> Comments below.
>> Hi,
>> generated XSD.
>> e.g. ..
>> XSD with an element
> from a schema. You have the original schema. There's no need to generate
> it. You've also not be clear what exactly you did to generate a schema.
>> Thanks,
>> Inga
Re: Element names in the generated XSD file [message #1477942 is a reply to message #1477889] |
Tue, 18 November 2014 03:38   |
Hauke,
Comments below.
On 18/11/2014 8:37 AM, Hauke Fuhrmann wrote:
> Hi Ed,
> the model.
I see.
> So when the customer expects us to change something in the XML, we do
> the changes in EMF and want to generate some XSD, that validates the
> new XML.
That sounds reasonable.
You're using Export Model?
Certainly org.eclipse.xsd.ecore.EcoreSchemaBuilder takes extended
metadata annotations into account. But if you're referring to the
schema generated when you set the GenModel's "Generate Schema" property
to true, that produces totally crappy results.
That's why I keep asking if you're using Export Model...
> Is there any additional option we have to set in the generator model?
You have to use Export Model... which is why I keep asking that
question...
> Cheers,
> Hauke
>> Inga,
>> Comments below.
>>> Hi,
>>> generated XSD.
>>> e.g. ..
>>> XSD with an element
>>> Thanks,
>>> Inga
Re: Element names in the generated XSD file [message #1479456 is a reply to message #1477942] |
Wed, 19 November 2014 07:49  |
Tanks a lot, Ed! We were not aware of an additional option to export the
XSD explicitly via a context menu. This explains a lot.
Hauke
Am 18.11.2014 09:38, schrieb Ed Merks:
> Hauke,
> Comments below.
>> Hi Ed,
>> the model.
> I see.
>> new XML.
> metadata annotations into account. But if you're referring to the schema
> generated when you set the GenModel's "Generate Schema" property to
> You have to use Export Model... which is why I keep asking that question...
>> Cheers,
>> Hauke
>>> Inga,
>>> Comments below.
>>>> Hi,
>>>> generated XSD.
>>>> e.g. ..
>>>> XSD with an element
>>>> Thanks,
>>>> Inga
Current Time: Sat Jul 19 09:18:22 EDT 2025
Powered by FUDForum. Page generated in 0.04776 seconds
