Home » Modeling » Papyrus » Problems while installing MARTE over Payrus(Installation of MARTE over papyrus)
Problems while installing MARTE over Payrus [message #1479323] Wed, 19 November 2014 05:40 Go to next message
I am trying to install the MARTE UML profile for papyrus, using "Install New Software" in Eclipse and using papyrus extensions (I am not able to post the link here)
But I get the following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: UML profile for MARTE 1.2.2.200911231304 (com.cea.papyrus.marte.feature.group 1.2.2.200911231304)
Missing requirement: UML profile for MARTE 1.2.2.200911231304 (com.cea.papyrus.marte.feature.group 1.2.2.200911231304) requires 'com.cea.papyrus.feature.feature.group 1.11.0' but it could not be found
I am not sure what I am missing here. I have the following Eclipse version
Version: Luna Service Release 1 (4.4.1)
Build id: 20140925-1800
Any pointers would be helpful,
Best regards
Padma
Re: Problems while installing MARTE over Payrus [message #1479340 is a reply to message #1479323] Wed, 19 November 2014 05:57 Go to previous messageGo to next message
Hi Padma,
it seems you are trying to install an old version of the MARTE profile, the one coming from the previous open source project Papyrus UML (papyrusuml.org)
The support for MARTE profile is now included in the extra features of Eclipse Papyrus, that can be accessed from the discovery site of Eclipse Papyrus (see Help > Install Papyrus Additional Components)
Hope this helps,
Rémi
Re: Problems while installing MARTE over Payrus [message #1691703 is a reply to message #1479340] Thu, 09 April 2015 04:02 Go to previous messageGo to next message
I am using papyrus and want to install MARTE libraries but i am unable to..
when I use install additional papyrus component in help section it says MARTE is unavailable, try again later..
can anyone help me please,,,
Re: Problems while installing MARTE over Payrus [message #1691782 is a reply to message #1691703] Thu, 09 April 2015 11:26 Go to previous messageGo to next message
Hi Ali,
What version of Papyrus are you currently using ?
Rémi
Re: Problems while installing MARTE over Payrus [message #1691858 is a reply to message #1691782] Fri, 10 April 2015 04:07 Go to previous message
Hi Ali,
The "Install additional components" may fail on one of the following issues:
- It is already installed, because you installed "Papyrus Extra", which includes all additional components
- There is a missing dependency, e.g. you're trying to install Marte Luna SR2 (1.0.2) on top of Papyrus Luna SR1 (1.0.1)
In the first case, nothing to do; in the second case, you need to use "Check for updates" before installing Marte. The second case used to happen because Eclipse Modeling Luna SR2 were installing Papyrus Luna SR1 (Instead of Papyrus Luna SR2), causing these dependency issues
If none of these solutions work, you can use "Help > Install new software", and use the following update site for Papyrus Luna:
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/luna/extra
You may need to uncheck "Group items by category" in order to install only Marte Components (Instead of all extra components, which is usually too much)
HTH,
Camille
Previous Topic:How to listen to models being loaded?
Next Topic:SysML Tutorial using Papyrus
Current Time: Sat Jul 19 15:46:58 EDT 2025
Powered by FUDForum. Page generated in 0.03224 seconds
