Home » Modeling » TMF (Xtext) » problem when using projects.itemis.de/nexus/
problem when using projects.itemis.de/nexus/ [message #1473580] Fri, 14 November 2014 14:13 Go to next message
I started to experience a problem when building in Travis
(https://travis-ci.org) using the fornax plugin taken from
https://projects.itemis.de/nexus/content/groups/public/
The error I get is reported below.
Google reports tons of web pages with the Java problem
"java.lang.RuntimeException: Could not generate DH keypair", saying that
it has been fixed in latest JDKs... I tried both with latest JDK 7 and
JDK 8 but the problem is still there (I don't have such problem in
Jenkins though).
I was wondering if something's wrong with the SSL certificate?
Anyone else experienced similar problems?
thanks in advance
Lorenzo
Here's the failing log
Downloading:
https://projects.itemis.de/nexus/content/groups/public/org/fornax/toolsupport/fornax-oaw-m2-plugin/3.4.0/fornax-oaw-m2-plugin-3.4.0.pom
[ERROR] Internal error: java.lang.RuntimeException:
org.apache.maven.MavenExecutionException: Could not setup plugin
ClassRealm: Plugin org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0 or
one of its dependencies could not be resolved: Failed to read artifact
descriptor for org.fornax.toolsupport:fornax-oaw-m2-plugin:jar:3.4.0:
Could not transfer artifact
org.fornax.toolsupport:fornax-oaw-m2-plugin:pom:3.4.0 from/to
fornax.plugin.repository
(https://projects.itemis.de/nexus/content/groups/public/):
java.lang.RuntimeException: Could not generate DH keypair: Prime size
must be multiple of 64, and can only range from 512 to 2048 (inclusive)
-> [Help 1]
org.apache.maven.InternalErrorException: Internal error:
java.lang.RuntimeException: org.apache.maven.MavenExecutionException:
Could not setup plugin ClassRealm
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:166)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:582)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:214)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:158)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: java.lang.RuntimeException:
org.apache.maven.MavenExecutionException: Could not setup plugin ClassRealm
at
org.eclipse.tycho.p2.resolver.P2DependencyResolver.getDependencyMetadata(P2DependencyResolver.java:168)
at
org.eclipse.tycho.p2.resolver.P2DependencyResolver.setupProjects(P2DependencyResolver.java:126)
at
org.eclipse.tycho.core.resolver.DefaultTychoResolver.setupProject(DefaultTychoResolver.java:87)
at
org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:70)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:310)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:154)
... 11 more
Caused by: org.apache.maven.MavenExecutionException: Could not setup
plugin ClassRealm
at
org.eclipse.tycho.core.maven.utils.PluginRealmHelper.newMavenExecutionException(PluginRealmHelper.java:143)
at
org.eclipse.tycho.core.maven.utils.PluginRealmHelper.execute(PluginRealmHelper.java:130)
at
org.eclipse.tycho.p2.resolver.P2DependencyResolver.getDependencyMetadata(P2DependencyResolver.java:148)
... 16 more
Caused by: org.apache.maven.plugin.PluginResolutionException: Plugin
org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0 or one of its
dependencies could not be resolved: Failed to read artifact descriptor
at
org.apache.maven.plugin.internal.DefaultPluginDependenciesResolver.resolve(DefaultPluginDependenciesResolver.java:122)
at
org.apache.maven.plugin.internal.DefaultMavenPluginManager.getPluginDescriptor(DefaultMavenPluginManager.java:148)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at
at
org.eclipse.tycho.core.maven.utils.MavenCompatiblityHelper.getPluginDescriptor(MavenCompatiblityHelper.java:68)
at
org.eclipse.tycho.core.maven.utils.PluginRealmHelper.execute(PluginRealmHelper.java:95)
... 17 more
Caused by: org.eclipse.aether.resolution.ArtifactDescriptorException:
Failed to read artifact descriptor for
at
org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:349)
at
org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.readArtifactDescriptor(DefaultArtifactDescriptorReader.java:231)
at
org.eclipse.aether.internal.impl.DefaultRepositorySystem.readArtifactDescriptor(DefaultRepositorySystem.java:288)
at
org.apache.maven.plugin.internal.DefaultPluginDependenciesResolver.resolve(DefaultPluginDependenciesResolver.java:108)
... 23 more
Caused by: org.eclipse.aether.resolution.ArtifactResolutionException:
at
org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:459)
at
org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:262)
at
org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:239)
at
org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom(DefaultArtifactDescriptorReader.java:334)
... 26 more
Caused by: org.eclipse.aether.transfer.ArtifactTransferException: Could
at
org.eclipse.aether.connector.wagon.WagonRepositoryConnector$6.wrap(WagonRepositoryConnector.java:1016)
at
org.eclipse.aether.connector.wagon.WagonRepositoryConnector$6.wrap(WagonRepositoryConnector.java:1004)
at
org.eclipse.aether.connector.wagon.WagonRepositoryConnector$GetTask.run(WagonRepositoryConnector.java:725)
at
org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:67)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.wagon.TransferFailedException:
at
org.apache.maven.wagon.providers.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:935)
at org.apache.maven.wagon.StreamWagon.getInputStream(StreamWagon.java:116)
at org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:88)
at org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61)
at
org.eclipse.aether.connector.wagon.WagonRepositoryConnector$GetTask.run(WagonRepositoryConnector.java:660)
... 4 more
Caused by: javax.net.ssl.SSLException: java.lang.RuntimeException: Could
at sun.security.ssl.Alerts.getSSLException(Alerts.java:208)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1917)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1874)
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1857)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1378)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1355)
at
org.apache.maven.wagon.providers.http.httpclient.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:261)
at
org.apache.maven.wagon.providers.http.httpclient.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:118)
at
org.apache.maven.wagon.providers.http.httpclient.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:314)
at
org.apache.maven.wagon.providers.http.httpclient.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:357)
at
org.apache.maven.wagon.providers.http.httpclient.impl.execchain.MainClientExec.execute(MainClientExec.java:218)
at
org.apache.maven.wagon.providers.http.httpclient.impl.execchain.ProtocolExec.execute(ProtocolExec.java:194)
at
org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec.execute(RetryExec.java:85)
at
org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RedirectExec.execute(RedirectExec.java:108)
at
org.apache.maven.wagon.providers.http.httpclient.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:186)
at
org.apache.maven.wagon.providers.http.httpclient.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at
org.apache.maven.wagon.providers.http.AbstractHttpClientWagon.execute(AbstractHttpClientWagon.java:756)
at
org.apache.maven.wagon.providers.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:854)
... 8 more
Caused by: java.lang.RuntimeException: Could not generate DH keypair
at sun.security.ssl.DHCrypt.<init>(DHCrypt.java:136)
at
sun.security.ssl.ClientHandshaker.serverKeyExchange(ClientHandshaker.java:686)
at
sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:264)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:936)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:871)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1043)
at
sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1343)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1371)
... 21 more
Caused by: java.security.InvalidAlgorithmParameterException: Prime size
at
com.sun.crypto.provider.DHKeyPairGenerator.initialize(DHKeyPairGenerator.java:120)
at
java.security.KeyPairGenerator$Delegate.initialize(KeyPairGenerator.java:657)
at sun.security.ssl.DHCrypt.<init>(DHCrypt.java:127)
... 28 more
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: problem when using projects.itemis.de/nexus/ [message #1476724 is a reply to message #1473580] Mon, 17 November 2014 04:45 Go to previous messageGo to next message
I can reproduce the same error having the Java Cryptography Extension (JCE) installed. Any chance, you've installed JCE too? If so, try a JRE without JCE, should work. I'll report the JCE issue at itemis.
Alex
Re: problem when using projects.itemis.de/nexus/ [message #1476794 is a reply to message #1476724] Mon, 17 November 2014 06:00 Go to previous messageGo to next message
On 17/11/2014 10:45, Alex Tugarev wrote:
Hi Alex
I'm just using what's available on Travis https://travis-ci.org/
is there a way to disable JCE with some flag?
thanks
Lorenzo
Xtext Book:
Re: problem when using projects.itemis.de/nexus/ [message #1476828 is a reply to message #1476794] Mon, 17 November 2014 06:35 Go to previous messageGo to next message
Hi Lorenzo,
please rerun the build job. Our IT Support Team at itemis did some changes, and it works for me now.
Alex
Re: problem when using projects.itemis.de/nexus/ [message #1476914 is a reply to message #1476828] Mon, 17 November 2014 08:06 Go to previous message
On 17/11/2014 12:35, Alex Tugarev wrote:
> Hi Lorenzo,
> Regards,
> Alex
Hi Alex
I confirm that now it works! :)
thanks for fixing this.
Lorenzo
Xtext Book:
Previous Topic:XML based DSL using xTEXT
Next Topic:Problem with templates in Xtext
Current Time: Sun Jul 20 14:25:22 EDT 2025
Powered by FUDForum. Page generated in 0.07620 seconds
