Home » Eclipse Projects » Eclipse 4 » EMenuService - get UI representation of menu
EMenuService - get UI representation of menu [message #1476898] Mon, 17 November 2014 07:51 Go to next message
I have a question on retrieving the UI representation of a menu declared in the application model programmatically.
To explain a bit more:
1. I added a popup menu to a part in the application model
2. after some investigation I've found out that with 4.4 it is possible to find the MMenu using the EModelService the following way
List<MMenu> menus = modelService.findElements(part, menuId, MMenu.class, null, EModelService.IN_PART);
Now I need to get the SWT Menu instance for the MMenu. I tried to call getWidget() on MMenu, but that returns null. I try to execute that method in @PostConstruct which should be ok from my understanding of the lifecycle.
I have seen that the SWT implementation of EMenuService contains a static helper method to get the Menu
Menu registerMenu(final Control, final MPopupMenu, IEclipseContext)
Now that method does exactly what I want. But MenuService is located in an internal package, and IMHO it is not good to rely on internal classes.
I'm currently not quite sure how to handle this correctly. Here are my questions:
1. Should MMenu#getWidget() return a valid instance if called in @PostConstruct or is there any trigger to let it be created?
2. If it is intended that it returns null, how could it be possible to get the Menu/trigger the Menu creation?
3. Since MenuService#registerMenu(Control, MPopupMenu, IEclipseContext) is public static, couldn't it be located in a place that is accessible for users? So no "internal" package.
It would be great if I could get help on this.
Greez,
Dirk
Re: EMenuService - get UI representation of menu [message #1477039 is a reply to message #1476898] Mon, 17 November 2014 10:15 Go to previous messageGo to next message
You want EMenuService which got relocated from SWT to ui.services.
Tom
On 17.11.14 13:51, Dirk Fauth wrote:
> lifecycle.
> questions:
> Greez,
> Dirk
Re: EMenuService - get UI representation of menu [message #1477044 is a reply to message #1477039] Mon, 17 November 2014 10:21 Go to previous messageGo to next message
Not necessarily because the Menu could be created lazily IIRC in SWT
(and JavaFX) it is done greedy.
So at the point you called EMenuService#registerContextMenu getWidget
should return a type.
No. Why should it? Maybe you should explain why you need to get access
to the native instance. There's not guarantee of what type the menu is
because it depends on the renderer. I could supply a renderer who does
create a completely different menu type.
Tom
Re: EMenuService - get UI representation of menu [message #1477063 is a reply to message #1477044] Mon, 17 November 2014 10:40 Go to previous messageGo to next message
Maybe you should explain why you need to get access to the native instance.
The reason is the menu mechanism in NatTable. The SWT popup menu mechanism registers the menu for the whole control. Now for NatTable this would mean to have the same menu in all regions (column header, row header, body). Therefore NatTable comes with a custom menu handling where menus are opened with actions dependent on the region. Internally the menu instances are created and handled manually.
The NatTable mechanism allows to extend existing Menu instances and I used that in 3.x before. The idea is to get the menu declared in the application model and register it with the NatTable mechanism to a specific region. But for this I need the Menu instance.
Calling EMenuService#registerContextMenu will register the menu to the whole control, so I can't use it in that case. EMenuService#registerMenu only creates the menu without registering it to the parent control. And the later is what I search for.
Dirk
Re: EMenuService - get UI representation of menu [message #1477092 is a reply to message #1477063] Mon, 17 November 2014 11:05 Go to previous message
OK, found a workaround.
First I use EMenuService#registerContextMenu to create and register the menu from the application model to the NatTable.
Then I retrieve the created Menu for further usage and remove it from NatTable to avoid the SWT context menu mechanism.
menuService.registerContextMenu(natTable, menuId);
Menu swtMenu = natTable.getMenu();
natTable.setMenu(null);
//use swtMenu for NatTable configurations
Previous Topic:How to contribute to the toolbar of an e4view?
Next Topic:Eclipse Luna Problem with @Inject
Current Time: Sun Jul 20 16:35:44 EDT 2025
Powered by FUDForum. Page generated in 0.03963 seconds
