When I try to open Eclipse the next day, it won't open on my Mac [message #1474510] |
Sat, 15 November 2014 08:33  |
Using an iMac with all the latest updates installed. When I first install Eclipse, it works fine, it's only the next day when I try to open it, it comes up with a message saying it unexpectedly quit and this just continues to happen so wondered if anyone could help me out? Cheers
Re: When I try to open Eclipse the next day, it won't open on my Mac [message #1494541 is a reply to message #1494535] |
Mon, 01 December 2014 10:02   |
This is my log file
!SESSION 2014-11-19 13:08:26.734 -----------------------------------------------
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/lindseyjones/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.java.product -keyring /Users/lindseyjones/.eclipse_keyring -showlocation
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-19 13:08:54.852
!MESSAGE Exception while setting up logging:org.eclipse.osgi.internal.framework.EquinoxConfiguration$1 cannot be cast to java.lang.String
!STACK 0
java.lang.ClassCastException: org.eclipse.osgi.internal.framework.EquinoxConfiguration$1 cannot be cast to java.lang.String
at org.eclipse.m2e.logback.configuration.LogHelper.logJavaProperties(LogHelper.java:26)
at org.eclipse.m2e.logback.configuration.LogPlugin.loadConfiguration(LogPlugin.java:189)
at org.eclipse.m2e.logback.configuration.LogPlugin.configureLogback(LogPlugin.java:144)
at org.eclipse.m2e.logback.configuration.LogPlugin.access$2(LogPlugin.java:107)
at org.eclipse.m2e.logback.configuration.LogPlugin$1.run(LogPlugin.java:62)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
!ENTRY org.eclipse.core.net 1 0 2014-11-19 13:08:56.422
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.equinox.p2.operations 4 0 2014-11-19 13:11:19.109
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.operations 4 10050 2014-11-19 13:11:19.109
!MESSAGE Cannot complete the request. See the error log for details.
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10004 2014-11-19 13:11:19.109
!MESSAGE "TFS plug-in for Eclipse" will be ignored because a newer version is already installed.
!MESSAGE "TFS plug-in for Eclipse Language Pack" will be ignored because a newer version is already installed.
!ENTRY org.eclipse.equinox.p2.operations 4 0 2014-11-19 13:11:19.113
!SUBENTRY 1 org.eclipse.equinox.p2.operations 4 10050 2014-11-19 13:11:19.113
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10004 2014-11-19 13:11:19.113
!SESSION 2014-11-24 09:35:25.544 -----------------------------------------------
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-24 09:35:31.288
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2014-11-24 09:35:32.889
!SESSION 2014-11-25 11:17:34.859 -----------------------------------------------
!ENTRY org.eclipse.m2e.logback.configuration 2 0 2014-11-25 11:17:53.562
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2014-11-25 11:17:55.229
FUDForum. Page generated in 0.31632 seconds
