Cannot complete the install because of a conflicting dependency. on Mars (Latest) [message #1441934] |
Fri, 10 October 2014 07:45  |
using build 1.0.0 Build 526. I tried to setup an Oomph development environment.
I ended with this error:
[13:41:05] Fetching content.jar from http://download.eclipse.org/egit/updates/
[13:41:06] Calculating requirements and dependencies.
[13:41:07] Cannot complete the request. Generating details.
[13:41:08] ERROR: org.eclipse.equinox.p2.director code=10054 Cannot complete the install because of a conflicting dependency.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:217)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.resolve(ProfileTransactionImpl.java:348)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:304)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:689)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2474)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2445)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3459)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2311)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3453)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3451)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2436)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2420)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2359)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:472)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:552)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1412941266083
ERROR: org.eclipse.equinox.p2.director code=1 Only one of the following can be installed at once:
ERROR: org.eclipse.equinox.p2.director code=0 Compare Support 3.5.500.v20131106-1552 (org.eclipse.compare 3.5.500.v20131106-1552)
ERROR: org.eclipse.equinox.p2.director code=0 Compare Support 3.5.600.v20140825-1753 (org.eclipse.compare 3.5.600.v20140825-1753)
ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1412941266083
ERROR: org.eclipse.equinox.p2.director code=0 To: epp.package.standard [4.5.0,5.0.0)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.platform.feature.group [4.5.0,5.0.0)
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse Standard/SDK 4.5.0.20140807-1637 (epp.package.standard 4.5.0.20140807-1637)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.epp.package.standard.feature.feature.group [4.5.0.20140807-1637]
ERROR: org.eclipse.equinox.p2.director code=0 From: EPP Eclipse Standard/SDK Feature 4.5.0.20140807-1637 (org.eclipse.epp.package.standard.feature.feature.group 4.5.0.20140807-1637)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.platform.feature.group [4.4.0.v20140806-2000]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse Platform 4.4.0.v20140806-2000 (org.eclipse.platform.feature.group 4.4.0.v20140806-2000)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.compare [3.5.500.v20131106-1552]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse Platform 4.5.0.v20140918-0330 (org.eclipse.platform.feature.group 4.5.0.v20140918-0330)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.compare [3.5.600.v20140825-1753]
[13:41:08] Took 12 seconds.
[13:41:08] There are failed tasks.
[13:41:08] Press Back to choose different settings or Cancel to abort.
Is it an issue with the Mars repo? or with Oomph configuration? or I miss something?
Re: Cannot complete the install because of a conflicting dependency. on Mars (Latest) [message #1441945 is a reply to message #1441934] |
Fri, 10 October 2014 07:54   |
Hi Aurelien,
I've noticed that, too. It's not a problem in Oomph. It's caused by a recent renaming of the Eclipse Standard package
from epp.package.standard to epp.package.committers, which IMHO was a very bad idea. I wanted to bring this topic up on
cross-projects-dev but for now your only chance is to "over-install" your installation with the standalone installer and
choosing "Eclipse for Committers" as your product. Content-wise it's identical to the old Standard product.
Cheers
/Eike
http://www.esc-net.de
Am 10.10.2014 um 13:45 schrieb Aurelien Pupier:
> dependency.
> at
> ERROR: org.eclipse.equinox.p2.director code=1 Only one of the following can be installed at once: ERROR:
> dependency.
> at
> Regards,
Re: Cannot complete the install because of a conflicting dependency. on Mars (Latest) [message #1472153 is a reply to message #1472122] |
Thu, 13 November 2014 11:45  |
So this has nothing to do with the thread in which you added your posting...
I tried it just now and it worked fine for me. CDO hard codes its Luna
dependencies so I left the choice as None...
On 13/11/2014 5:12 PM, Laurent Fasani wrote:
> yes I chose "CDO Model Repository" project and i tried with luna and
> mars TP
> I got the error at the first installation. Then I retried clicking on
> "Perform Setup Tasks" and got the same error.
FUDForum. Page generated in 0.03767 seconds
