Home » Modeling » TMF (Xtext) » terminal ID is not accepting only upper case letters
terminal ID is not accepting only upper case letters [message #1470591] Wed, 12 November 2014 08:15 Go to next message
In org.eclipse.xtext.xbase.Xtype.xtext the terminal ID is defined by
terminal ID:
	'^'? ('a'..'z'|'A'..'Z'|'$'|'_') ('a'..'z'|'A'..'Z'|'$'|'_'|'0'..'9')*;
According to the Xtext Documentation:
It says that a token ID starts with an optional '^' character (caret), followed by a letter ('a'..'z'|'A'..'Z') or underscore '_' followed by any number of letters, underscores and numbers ('0'..'9').
So far, so good.
But if I want to use "ATX" as ID I got the error "mismatched input 'ATX' expecting RULE_ID". With 'B2' the same. But 'Atx' is fine.
My corresponding rule is:
Entity:
	'entity' name=ID '{'...'}'
Can anybody please explain me what I'm doing wrong?
Re: terminal ID is not accepting only upper case letters [message #1470597 is a reply to message #1470591] Wed, 12 November 2014 08:20 Go to previous messageGo to next message
hi is ATX a keyword in your grammar?
Re: terminal ID is not accepting only upper case letters [message #1470614 is a reply to message #1470597] Wed, 12 November 2014 08:31 Go to previous messageGo to next message
Christian Dietrich wrote on Wed, 12 November 2014 14:20
Oh, this I've missed to mention. No ATX is not a keyword, instead I can exchange ATX with ABC with the same result.
Re: terminal ID is not accepting only upper case letters [message #1470617 is a reply to message #1470614] Wed, 12 November 2014 08:34 Go to previous messageGo to next message
do you have any other terminals defined? can you share a minimal grammar?
Re: terminal ID is not accepting only upper case letters [message #1471530 is a reply to message #1470617] Thu, 13 November 2014 01:27 Go to previous messageGo to next message
Thanks Christian.
You pushed me in the right direction. The grammar still contained an old, no longer used, terminal definition which caused the problem:
terminal ENUM_NAME:
    ('A'..'Z' | '_') ('A'..'Z' | '_' | '0'..'9')*;
[Updated on: Thu, 13 November 2014 01:28] by Moderator
Re: terminal ID is not accepting only upper case letters [message #1471735 is a reply to message #1470614] Thu, 13 November 2014 04:46 Go to previous messageGo to next message
Could you provide the complete grammar and maybe a unit test?
I just tried an all uppercase keyword and it works.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: terminal ID is not accepting only upper case letters [message #1471757 is a reply to message #1471735] Thu, 13 November 2014 05:04 Go to previous message
Sebastian Zarnekow wrote on Thu, 13 November 2014 10:46
The problem is solved. It was my error because I had the not longer used terminal ENUM_NAME I posted before.
Previous Topic:Interrupt inferring
Next Topic:Xtext to notify the modified Object
Current Time: Sun Jul 20 17:33:45 EDT 2025
Powered by FUDForum. Page generated in 0.04777 seconds
