Home » Language IDEs » ServerTools (WTP) » Wizard Error : Creating Servlet
Wizard Error : Creating Servlet [message #147047] Tue, 15 November 2005 03:11 Go to next message
Originally posted by: unugurn.hotmail.com
I'm getting the following error;
"An error has occured when Create Servlet finished"
What might be the problem?
Below you can find my configuration details;
Niyazi
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:359)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at
org.eclipse.wst.common.frameworks.internal.ui.WTPWizard.perf ormFinish(WTPWizard.java:241)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.UnsupportedClassVersionError:
org/eclipse/jst/j2ee/web/ServletTemplate (Unsupported major.minor version
49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at
org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.loadClas s(WTPJETEmitter.java:332)
at
org.eclipse.jst.j2ee.internal.project.WTPJETEmitter.initiali ze(WTPJETEmitter.java:215)
at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:592)
at
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.generateTemplateSource(NewServletClassOperation.ja va:287)
at
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.generateUsingTemplates(NewServletClassOperation.ja va:194)
at
org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.execute(NewServletClassOperation.java:138)
at
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.doRun(WTPOperation.java:336)
at
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration$1.run(WTPOperation.java:248)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
at
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.run(WTPOperation.java:266)
at
org.eclipse.jst.j2ee.internal.web.operations.AddServletOpera tion.createServletClass(AddServletOperation.java:122)
at
org.eclipse.jst.j2ee.internal.web.operations.AddServletOpera tion.execute(AddServletOperation.java:99)
at
at
at
at
org.eclipse.wst.common.frameworks.internal.ui.RunnableWithPr ogressWrapper.run(RunnableWithProgressWrapper.java:65)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
... 38 more
*** Date: Tue Nov 15 10:10:28 EET 2005
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20050627-1435
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Eclipse\3.1\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
101c_60
-vm
C:\Eclipse\3.1\jre\bin\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1132040880972
eclipse.vm=C:\Eclipse\3.1\jre\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\Eclipse\3.1\startup.jar
eof=eof
file.encoding=Cp1254
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Eclipse\3.1\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Eclipse\3.1\jre\lib\endorsed
java.ext.dirs=C:\Eclipse\3.1\jre\lib\ext
java.home=C:\Eclipse\3.1\jre
java.io.tmpdir=C:\DOCUME~1\UNUGUR~1.ARG\LOCALS~1\Temp\
java.library.path=C:\Eclipse\3.1\jre\bin;.;C:\windows\system 32;C:\windows;C:\Program
Files\ImageMagick-6.2.4-Q16;C:\windows\system32;C:\windows;C :\windows\System32\Wbem;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\ PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\Program
Files\Borland\Delphi7\Bin;C:\Program
Files\Borland\Delphi7\Projects\Bpl\;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;E:\Oracle\product\10.1.0\Client\bin;E: \private\repository\eda-misc;C:\Program
Files\Common Files\Adobe\AGL;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\SecureCRT\;C:\Sun\AppServer\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_09-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_09
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_09-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.4
org.osgi.framework.language=tr
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.transaction,javax.transactio n.xa,javax.xml.parsers,javax.xml.transform,javax.xml.transfo rm.dom,javax.xml.transform.sax,javax.xml.transform.stream,or g.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_ 3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPack age,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org .omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org .omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg. DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.D ynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactory Package,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.P ortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPa ckage,org.omg.PortableServer,org.omg.PortableServer.CurrentP ackage,org.omg.PortableServer.POAManagerPackage,org.omg.Port ableServer.POAPackage,org.omg.PortableServer.portable,org.om g.PortableServer.ServantLocatorPackage,org.omg.SendingContex t,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax. ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=c:\Eclipse\3.1\configuration\org.eclipse.os gi\bundles
osgi.configuration.area=file:/c:/Eclipse/3.1/configuration/
osgi.framework=file:/c:/Eclipse/3.1/plugins/org.eclipse.osgi _3.1.0.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.0.0
osgi.install.area=file:/c:/Eclipse/3.1/
osgi.instance.area=file:/C:/Eclipse/3.1/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/unugurn.ARGE/workspace/
osgi.logfile=C:\Eclipse\3.1\workspace\.metadata\.log
osgi.manifest.cache=c:\Eclipse\3.1\configuration\org.eclipse .osgi\manifests
osgi.nl=tr_TR
osgi.os=win32
osgi.splashLocation=c:\Eclipse\3.1\plugins\org.eclipse.platf orm_3.1.0\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Eclipse\3.1\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Eclipse\3.1\jre\lib\rt.jar;C:\Eclipse \3.1\jre\lib\i18n.jar;C:\Eclipse\3.1\jre\lib\sunrsasign.jar; C:\Eclipse\3.1\jre\lib\jsse.jar;C:\Eclipse\3.1\jre\lib\jce.j ar;C:\Eclipse\3.1\jre\lib\charsets.jar;C:\Eclipse\3.1\jre\cl asses
sun.boot.library.path=C:\Eclipse\3.1\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 2
user.country=TR
user.dir=C:\Eclipse\3.1
user.home=C:\Documents and Settings\unugurn.ARGE
user.language=tr
user.name=unugurn
user.timezone=Europe/Athens
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
com.ibm.bluez.jcop.eclipse (3.1.1.a) "JCOP Tools"
com.ibm.bluez.jcop.eclipse.signlite (1.0.2) "IBM SignLite Demo"
eclipseme.feature (1.2.1) "EclipseME"
org.eclipse.cdt (3.0.1) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.sdk (3.0.1) "Eclipse C/C++ Development Tools SDK"
org.eclipse.cdt.source (3.0.1) "Eclipse C/C++ Development Tools (Source)"
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.1) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.1.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.1) "GEF Examples"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jst (0.7.1) "J2EE Standard Tools"
org.eclipse.jst.sdk (0.7.1) "J2EE Standard Tools SDK"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.0) "Eclipse RCP"
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples"
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support"
org.eclipse.uml2 (1.1.0) "UML2"
org.eclipse.uml2.doc (1.1.0) "UML2 Documentation"
org.eclipse.uml2.examples (1.1.0) "UML2 Examples"
org.eclipse.uml2.examples.source (1.1.0) "UML2 Examples Source"
org.eclipse.uml2.source (1.1.0) "UML2 Source"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source"
org.eclipse.wst (0.7.1) "Web Standard Tools"
org.eclipse.wst.sdk (0.7.1) "Web Standard Tools SDK"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.bluez.jcop.eclipse (3.1.1.a) "JCOP Tools" [Active]
com.ibm.bluez.jcop.eclipse.demopack (1.0.2) "IBM JCOP Demo Pack for Eclipse"
[Installed]
com.ibm.bluez.jcop.eclipse.perftest (1.0.2) "IBM JCOP Performance Demo"
[Installed]
com.ibm.bluez.jcop.eclipse.signlite (1.0.2) "IBM SignLite Demo" [Resolved]
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
eclipseme.core (1.2.1) "EclipseME Core Plug-in" [Active]
eclipseme.core.preverifier (1.2.1) "EclipseME Preverifier Plug-in" [Active]
eclipseme.docs (1.2.0) "EclipseME Docs Plug-in" [Resolved]
eclipseme.feature.branding (1.1.0) "EclipseME" [Resolved]
eclipseme.toolkit.motorola (1.2.1) "EclipseME Motorola Plug-in" [Active]
eclipseme.toolkit.nokia (1.1.0) "EclipseME Nokia Plug-in" [Active]
eclipseme.toolkit.siemens (1.1.0) "EclipseME Siemens Plug-in" [Active]
eclipseme.toolkit.sonyericsson (1.2.0) "EclipseME Sonyericsson Plug-in"
[Active]
eclipseme.toolkit.sprint (1.1.0) "EclipseME Sprint Plug-in" [Active]
eclipseme.toolkit.sun (1.1.0) "EclipseME Sun Plug-in" [Active]
eclipseme.ui (1.2.1) "EclipseME UI Plug-in" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1) "Axis121 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.cdt (3.0.1) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.0.1) "C/C++ Development Tools Core" [Resolved]
org.eclipse.cdt.core.win32 (3.0.1) "C/C++ Development Tools Core for
Windows" [Resolved]
org.eclipse.cdt.debug.core (3.0.1) "C/C++ Development Tools Debug Model"
[Resolved]
org.eclipse.cdt.debug.mi.core (3.0.1) "C/C++ Development Tools GDB/MI CDI
Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.0.1) "C/C++ Development Tools GDB/MI CDI
Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.0.1) "C/C++ Development Tools Debugger UI"
[Resolved]
org.eclipse.cdt.doc.isv (3.0.1) "C/C++ Plugin Developer Guide" [Resolved]
org.eclipse.cdt.doc.user (3.0.1) "C/C++ Development User Guide" [Resolved]
org.eclipse.cdt.launch (3.0.1) "C/C++ Development Tools Launching Support"
[Resolved]
org.eclipse.cdt.make.core (3.0.1) "C/C++ Standard make Build Core"
[Resolved]
org.eclipse.cdt.make.ui (3.0.1) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.0.1) "C/C++ Managed Builder Core"
[Resolved]
org.eclipse.cdt.managedbuilder.gnu.ui (3.0.1) "GNU Managed Build
Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.0.1) "C/C++ Managed Builder UI"
[Resolved]
org.eclipse.cdt.refactoring (3.0.1) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.sdk (3.0.1) "Eclipse C/C++ Development Tools SDK" [Resolved]
[Resolved]
org.eclipse.cdt.source.win32.win32.x86 (3.0.1) "Eclipse C/C++ Development
Tools (Source)" [Resolved]
org.eclipse.cdt.ui (3.0.1) "C/C++ Development Tools UI" [Resolved]
org.eclipse.compare (3.1.0) "Compare Support" [Active]
org.eclipse.compare.examples (3.0.0) "Compare Example" [Resolved]
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Active]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Active]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Active]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit
Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Active]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Active]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework Documentation"
[Resolved]
org.eclipse.gef.examples.flow (3.1.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.1) "GEF Logic Editor Example" [Resolved]
org.eclipse.gef.examples.shapes (3.1.1) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.1) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.1) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample" [Resolved]
org.eclipse.help.ui (3.1.0) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime
support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support"
[Active]
[Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
org.eclipse.jdt.ui.examples.projects (3.0.1) "Java Development Tools Example
Projects" [Resolved]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo (Introspection)
Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Active]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.jst (0.7.0) "J2EE Standard Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (0.7.1) "Annotation Controller
Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (0.7.0) "Annotation Core Plug-in"
[Resolved]
org.eclipse.jst.common.annotations.ui (0.7.0) "Ui Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (0.7.0) "Integration Plug-in" [Resolved]
org.eclipse.jst.common.navigator.java (0.7.1) "Navigator Plug-in" [Active]
org.eclipse.jst.ejb.ui (0.7.0) "WTP EJB UI Plug-in" [Resolved]
org.eclipse.jst.j2ee (0.7.1) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (0.7.1) "J2EE Core Component" [Active]
org.eclipse.jst.j2ee.ejb (0.7.0) "EJB component Plug-in" [Active]
org.eclipse.jst.j2ee.ejb.annotation.model (0.7.0) "EJB Annotation Model
Plug-in" [Active]
org.eclipse.jst.j2ee.ejb.annotations.emitter (0.7.0) "EJB Emitter Plug-in"
[Active]
org.eclipse.jst.j2ee.ejb.annotations.ui (0.7.1) "EJB Annotations Ui Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (0.7.1) "Xdoclet Annotations
Plug-in" [Active]
org.eclipse.jst.j2ee.jca (0.7.0) "JCA Plug-in" [Active]
org.eclipse.jst.j2ee.jca.ui (0.7.0) "WTP JCA UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.navigator.ui (0.7.0) "J2EE Extensions to Common
Navigator" [Active]
org.eclipse.jst.j2ee.ui (0.7.1) "WTP J2EE UI Plug-in" [Active]
org.eclipse.jst.j2ee.web (0.7.1) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (0.7.0) "Web Service Plug-in" [Active]
org.eclipse.jst.j2ee.webservices.ui (0.7.0) "WTP Webservice UI Plug-in"
[Active]
org.eclipse.jst.jsp.core (0.7.1) "Structured Source JSP Model" [Resolved]
org.eclipse.jst.jsp.ui (0.7.1) "SSE JSP Source Editor" [Resolved]
org.eclipse.jst.server.core (0.7.0) "Java Server Support" [Active]
org.eclipse.jst.server.generic.core (0.7.0) "Generic Server Plugin" [Active]
org.eclipse.jst.server.generic.serverdefinitions (0.7.0) "Generic server
example definitions" [Resolved]
org.eclipse.jst.server.generic.ui (0.7.0) "Generic Server Plugin UI"
[Active]
org.eclipse.jst.server.geronimo.core (0.7.0) "Geronimo server support"
[Resolved]
org.eclipse.jst.server.geronimo.ui (0.7.0) "Geronimo server UI support"
[Resolved]
org.eclipse.jst.server.tomcat.core (0.7.0) "Apache Tomcat Support" [Active]
org.eclipse.jst.server.tomcat.ui (0.7.0) "Apache Tomcat UI Support" [Active]
org.eclipse.jst.server.ui (0.7.0) "Java Server UI Support" [Active]
org.eclipse.jst.server.websphere.core (0.7.0) "WebSphere Generic Server
Definition Core Plug-in" [Resolved]
org.eclipse.jst.servlet.ui (0.7.1) "WTP Servlet UI Plug-in" [Active]
org.eclipse.jst.source (0.7.1) "J2EE Standard Tools SDK" [Resolved]
org.eclipse.jst.ws (0.7.1) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (0.7.0) "Web service Axis
Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (0.7.1) "Webservice Axis Consumption
UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (0.7.0) "Webservice Axis Creation UI"
[Resolved]
org.eclipse.jst.ws.consumption (0.7.0) "Web Services Consumption" [Resolved]
org.eclipse.jst.ws.consumption.ui (0.7.1) "Web Services Consumption
Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (0.7.0) "Web Services Creation EJB
org.eclipse.jst.ws.creation.ui (0.7.1) "Web Services Creation Graphical User
org.eclipse.jst.ws.uddiregistry (0.7.0) "Web Services Universal Description
Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (0.7.1) "Web Services Graphical User Interface"
[Resolved]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment Runtime"
[Active]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Active]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples" [Resolved]
org.eclipse.sdk.examples.source (3.0.1) "Eclipse Platform Plug-in Developer
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.1) "Eclipse Platform
org.eclipse.search (3.1.0) "Search Support" [Active]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin" [Resolved]
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
[Resolved]
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
[Resolved]
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
[Resolved]
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
[Resolved]
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
[Resolved]
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.target (1.0.0) "Target Plug-in" [Resolved]
org.eclipse.target.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.target.ide (1.0.0) "Target IDE Plug-in" [Resolved]
org.eclipse.target.iofile (1.0.0) "I/O File Plug-in" [Resolved]
org.eclipse.target.webdav (1.0.0) "Target WebDAV Plug-in" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example" [Active]
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support" [Resolved]
org.eclipse.team.extras.source (3.1.0) "Eclipse Team Extras Plug-in
org.eclipse.team.ftp (3.1.0) "FTP Deployment Provider" [Resolved]
org.eclipse.team.target (1.0.0) "Team Target Plug-in" [Resolved]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
org.eclipse.team.webdav (3.1.0) "WebDAV Team Provider" [Resolved]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example" [Resolved]
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
[Resolved]
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor" [Resolved]
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
[Resolved]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
org.eclipse.uml2 (1.1.0) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.1.0) "UML2 Ecore Code Generation"
[Resolved]
org.eclipse.uml2.codegen.ecore.ui (1.1.0) "UML2 Ecore Code Generation UI"
[Resolved]
org.eclipse.uml2.common (1.1.0) "UML2 Common" [Resolved]
org.eclipse.uml2.common.edit (1.1.0) "UML2 Common Edit" [Resolved]
org.eclipse.uml2.doc (1.1.0) "UML2 Documentation" [Resolved]
org.eclipse.uml2.ecore.importer (1.1.0) "UML2 Importer for EMF" [Resolved]
org.eclipse.uml2.edit (1.1.0) "UML2 Edit Support" [Resolved]
org.eclipse.uml2.editor (1.1.0) "UML2 Editor" [Resolved]
org.eclipse.uml2.examples (1.1.0) "UML2 Examples" [Resolved]
org.eclipse.uml2.examples.emof2ecore (1.1.0) "UML2 EMOF2Ecore Example"
[Resolved]
org.eclipse.uml2.examples.source (1.1.0) "UML2 Examples Source" [Resolved]
org.eclipse.uml2.examples.ui (1.1.0) "UML2 Examples UI" [Resolved]
org.eclipse.uml2.resources (1.1.0) "UML2 Resources" [Resolved]
org.eclipse.uml2.source (1.1.0) "UML2 Source" [Resolved]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Active]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Resolved]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.sdk (1.1.0) "Visual Editor SDK" [Resolved]
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source" [Resolved]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.eclipse.webdav (3.0.0) "WebDAV Client" [Resolved]
org.eclipse.wst (0.7.0) "Web Standard Tools" [Resolved]
org.eclipse.wst.command.env (0.7.0) "Environment Command Framework
(headless)" [Resolved]
org.eclipse.wst.command.env.core (0.7.0) "Environment Command Framework
(core)" [Resolved]
org.eclipse.wst.command.env.ui (0.7.0) "Environment Command Framework (GUI)"
[Resolved]
org.eclipse.wst.common.emf (0.7.0) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (0.7.0) "EMF Workbench Edit
Plug-in" [Active]
org.eclipse.wst.common.frameworks (0.7.1)
"org.eclipse.wst.common.frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (0.7.1) "WTP UI Plug-in" [Active]
org.eclipse.wst.common.modulecore (0.7.0) "Modulecore Plug-in" [Active]
org.eclipse.wst.common.navigator.views (0.7.0) "Common Navigator View"
[Active]
org.eclipse.wst.common.navigator.workbench (0.7.0) "Navigator Workbench
Components" [Active]
org.eclipse.wst.common.snippets (0.7.0) "Snippets View" [Active]
org.eclipse.wst.common.ui (0.7.0) "Eclipse Base UI extensions" [Active]
org.eclipse.wst.common.ui.properties (0.7.0) "Common Properties UI" [Active]
org.eclipse.wst.common.uriresolver (0.7.0)
"org.eclipse.wst.common.uriresolver" [Active]
org.eclipse.wst.css.core (0.7.0) "Structured Source CSS Model" [Resolved]
org.eclipse.wst.css.ui (0.7.0) "SSE CSS Source Editor" [Resolved]
org.eclipse.wst.dtd.core (0.7.0) "Structured Source DTD Core" [Active]
org.eclipse.wst.dtd.ui (0.7.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.html.core (0.7.1) "Structured Source HTML Model" [Resolved]
org.eclipse.wst.html.standard.dtds (0.7.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (0.7.1) "HTML UI Source Editor" [Resolved]
org.eclipse.wst.internet.cache (0.7.0) "Cache URI Resolver Plug-in" [Active]
org.eclipse.wst.internet.monitor.core (0.7.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (0.7.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (0.7.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.javascript.core (0.7.0) "Structured Source JavaScript Model"
[Resolved]
org.eclipse.wst.javascript.ui (0.7.0) "SSE JavaScript Source Editor"
[Resolved]
org.eclipse.wst.rdb.connection.ui (0.7.1) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (0.7.1) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (0.7.1) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.data.core (0.7.0) "Data Core Plugin" [Resolved]
org.eclipse.wst.rdb.data.ui (0.7.0) "Data UI Plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (0.7.0) "IBM Cloudscape Database
Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (0.7.0) "Informix Database
org.eclipse.wst.rdb.dbdefinition.mysql (0.7.0) "DBDefinition Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (0.7.0) "Oracle Database Definition
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sqlserver (0.7.0) "SQL Server Database
org.eclipse.wst.rdb.dbdefinition.sybase (0.7.0) "Sybase Database Definition
Plug-in" [Resolved]
org.eclipse.wst.rdb.derby (0.7.1) "RDB Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (0.7.1) "RDB Derby Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (0.7.0) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (0.7.0) "FE Ui Actions Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (0.7.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (0.7.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.models.sql.edit (0.7.0) "SQLModel Edit Plug-in"
[Resolved]
org.eclipse.wst.rdb.mysql (0.7.1) "RDB Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (0.7.0) "Data Output Plug-in" [Resolved]
org.eclipse.wst.rdb.server.extensions (0.7.1) "Server Explorer Extensions
Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (0.7.1) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor (0.7.0) "SQL Source Editor Plugin" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (0.7.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (0.7.0) "Server Core" [Active]
org.eclipse.wst.server.ui (0.7.0) "Server UI" [Active]
org.eclipse.wst.source (0.7.1) "Web Standard Tools SDK" [Resolved]
org.eclipse.wst.sse.core (0.7.1) "Structured Text Model" [Active]
org.eclipse.wst.sse.ui (0.7.0) "Structured Source Editor" [Active]
org.eclipse.wst.validation (0.7.0) "Validation Framework" [Active]
org.eclipse.wst.validation.ui (0.7.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (0.7.1) "Simple Web Plug-in" [Active]
org.eclipse.wst.web.ui (0.7.0) "Simple Web UI Plug-in" [Resolved]
org.eclipse.wst.ws (0.7.1) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (0.7.1) "Web Services Explorer" [Resolved]
org.eclipse.wst.ws.parser (0.7.0) "Web Services Description Parser"
[Resolved]
org.eclipse.wst.ws.ui (0.7.0) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (0.7.0) "WSDL Model" [Active]
org.eclipse.wst.wsdl.ui (0.7.1) "WSDL Editor" [Resolved]
org.eclipse.wst.wsdl.validation (0.7.0) "WSDL Validator" [Resolved]
org.eclipse.wst.wsi (0.7.0) "WSI Conformance Tools" [Resolved]
org.eclipse.wst.wsi.ui (0.7.0) "Soap Monitor" [Resolved]
org.eclipse.wst.xml.core (0.7.1) "Structured Source XML Model" [Active]
org.eclipse.wst.xml.ui (0.7.1) "XML UI Plugin" [Active]
org.eclipse.wst.xsd.core (0.7.1) "XSD Core Plugin" [Active]
org.eclipse.wst.xsd.ui (0.7.1) "XML Schema Editor" [Resolved]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Active]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (2.0.3) "UDDI4J 2.0.3" [Resolved]
org.vssplugin (1.6.1) "VSS Plugin Functions for Eclipse" [Active]
org.wsdl4j (1.4.0) "WSDL4J 1.4" [Installed]
org.wsdl4j (1.4.1) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue Nov 15 10:10:28 EET 2005
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=com.kentkart.mobile.application.cityguide,com.kentk art.mobile.examples.harddrivegame,sam,com.kentkart.mail,com. kentkart.smsproxy,com.kentkart.panda,com.kentkart.test.confi guration,Test,com.kentkart.util
/instance/com.seapine.surroundscm/SilentCheckout=true
/project/com.kentkart.mobile.examples.harddrivegame/org.ecli pse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.3
/instance/com.seapine.surroundscm/IconDecorateProject=1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
/instance/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_C REATION=always
/instance/org.eclipse.cdt.core/indexer=org.eclipse.cdt.core. domsourceindexer
/project/com.kentkart.mobile.application.cityguide/org.eclip se.jdt.core/org.eclipse.jdt.core.compiler.source=1.3
/instance/eclipseme.core/proguard_dir=C\:\\Program Files\\proguard3.3.2
@org.eclipse.jst.jsp.core=0.7.1
/instance/org.eclipse.ui.ide/platformState=771
@org.eclipse.ui.ide=3.1.0
@org.eclipse.jdt.core=3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/Eclipse/3.1
/instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.JavaPe rspective_persp= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<perspective version\="0.016"
editorAreaVisible\="1" fixed\="0">\r\n<descriptor
id\="org.eclipse.jdt.ui.JavaPerspective" label\="Java"
class\="org.eclipse.jdt.internal.ui.JavaPerspectiveFactory"/ >\r\n<window
x\="-4" y\="-4" height\="746" width\="1032"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.search.searchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet
id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<alwaysOnActionSet
id\="eclipseme.ui.actionSet.support"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation "/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.presentation"/>\r\n <alwaysOnActionSet
id\="org.eclipse.jdt.ui.CodingActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.text.java.actionSet.presentation"/ >\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.A_OpenActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.SearchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.cdt.ui.CodingActionSet"/>\r\n<alwaysOnActionSet
id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\r\n<alwaysOnActionSet
id\="org.eclipse.jst.ws.consumption"/>\r\n<alwaysOffActionSet
id\="org.vssplugin.menu.actionSet"/>\r\n<show_view_action
id\="org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.SourceView"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action
id\="org.eclipse.pde.runtime.LogView"/>\r\n<show_view_action
id\="org.eclipse.search.ui.views.SearchView"/>\r\n<show_view_action
id\="org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\r\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\r\n<new_wizard_action
id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/ >\r\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.file"/>\r\n<perspective_action
id\="org.eclipse.jdt.ui.JavaPerspective"/>\r\n<perspective_action
id\="org.eclipse.debug.ui.DebugPerspective"/>\r\n<perspective_action
id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\r\n<view
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<view
id\="org.eclipse.ui.views.ProblemView"/>\r\n<view
id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<view
id\="org.eclipse.ui.views.PropertySheet"/>\r\n<view
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<fastViews >\r\n<view
ratio\="0.84714"/>\r\n</fastViews>\r\n<layout>\r\n<mainWindow >\r\n<info
part\="left" folder\="true">\r\n<folder
activePageID\="org.eclipse.jdt.ui.PackageExplorer" expanded\="2"
appearance\="2">\r\n<page label\="Package Explorer"
content\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<page
label\="LabelNotFound"
content\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<page
content\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<page
content\="org.eclipse.jdt.junit.ResultView"/>\r\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part
id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info
part\="stickyFolderRight" relative\="left" relationship\="2"
ratioLeft\="754" ratioRight\="252" ratio\="0.74950296"
folder\="true">\r\n<folder expanded\="2" appearance\="2">\r\n<page
label\="LabelNotFound" content\="org.eclipse.help.ui.HelpView"/>\r\n<page
content\="org.eclipse.ui.internal.introview"/>\r\n<page
content\="org.eclipse.ui.cheatsheets.views.CheatSheetView"/ >\r\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory "/>\r\n</folder>\r\n</info>\r\n<info
part\="org.eclipse.ui.editorss" relative\="left" relationship\="2"
ratioLeft\="317" ratioRight\="694" ratio\="0.31355095"/>\r\n<info
part\="bottom" relative\="org.eclipse.ui.editorss" relationship\="4"
ratioLeft\="472" ratioRight\="161" ratio\="0.7456556"
folder\="true">\r\n<folder activePageID\="org.eclipse.ui.views.ProblemView"
expanded\="2" appearance\="2">\r\n<page label\="Problems"
content\="org.eclipse.ui.views.ProblemView"/>\r\n<page label\="Javadoc"
content\="org.eclipse.jdt.ui.JavadocView"/>\r\n<page label\="LabelNotFound"
content\="org.eclipse.jdt.ui.SourceView"/>\r\n<page label\="LabelNotFound"
content\="org.eclipse.ui.console.ConsoleView"/>\r\n<page
content\="org.eclipse.ui.views.BookmarkView"/>\r\n<page
label\="LabelNotFound" content\="org.eclipse.pde.runtime.LogView"/>\r\n<page
content\="org.eclipse.jdt.callhierarchy.view"/>\r\n<page
label\="LabelNotFound" content\="com.perforce.team.ui.DepotView"/>\r\n<page
label\="LabelNotFound" content\="com.perforce.team.ui.JobView"/>\r\n<page
content\="com.perforce.team.ui.ConsoleView"/>\r\n<page
content\="com.perforce.team.ui.PendingChangelistView"/>\r\n <page
content\="com.perforce.team.ui.HistoryView"/>\r\n<page
content\="com.seapine.surroundscm.eclipse.views.SSCMEHistoryView "/>\r\n<page
content\="com.seapine.surroundscm.eclipse.views.SSCMEMessageView "/>\r\n<page
label\="Properties" content\="org.eclipse.ui.views.PropertySheet"/>\r\n<page
content\="org.eclipse.ve.internal.java.codegen.editorpart.BeansList "/>\r\n<page
label\="LabelNotFound" content\="org.eclipse.ui.console.ConsoleView\:Console
View \#1"/>\r\n<page label\="LabelNotFound"
content\="org.eclipse.ui.views.ProgressView"/>\r\n<page
content\="org.eclipse.search.ui.views.SearchView"/>\r\n<page
content\="com.serena.team.ui.vm.views.RevisionView"/>\r\n <presentation
id\="0"/>\r\n<part id\="1"/>\r\n<part
id\="2"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info
part\="org.eclipse.ui.internal.ViewStack@423606" relative\="bottom"
relationship\="2" ratioLeft\="377" ratioRight\="378" ratio\="0.49933776"
content\="org.vssplugin.ui.checkout"/>\r\n<presentation
part\="
Re: Wizard Error : Creating Servlet [message #147091 is a reply to message #147047] Tue, 15 November 2005 09:20 Go to previous messageGo to next message
I believe that:
version 49.0)
implies that JDK/JRE 1.4.x tried to read a class complied with JDK 1.5.
The Servlet wizard uses JET to create a Java file and compile it. It
then runs this class which in turn writes the requested servlet source
to your specifications. For some reason, the Java file JET created
seems to be compiled using jdk1.5 and you get this error when it is
executed with jdk/jre1.4.
Using a setup basically the same as yours, I tried a couple of scenarios
to try to duplicate this and was unsuccessful. I can't explain why this
is happening in your setup. You could try creating a new workspace and
see if this still happens. If not, you could compare the contents of
the hidden .JETEmitters project to see if there are differences that
might explain this behavior.
Larry
> Niyazi
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 49.0)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> org.eclipse.jst.j2ee.internal.web.operations.NewServletClass Operation.generateUsingTemplates(NewServletClassOperation..j ava:194)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 38 more
<snip...>
Re: Wizard Error : Creating Servlet [message #147294 is a reply to message #147091] Wed, 16 November 2005 11:09 Go to previous message
Thanks Larry,
Fresh installation of eclipse works fine !
Than i found the problem with little effort with your explanation. The
problem is that;
my eclipse installation directory has a JRE folder which contains version
JRE 1.4.
Niyazi
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:dlcqrf$bhi$1@news.eclipse.org...
>I believe that:
> 49.0)
> The Servlet wizard uses JET to create a Java file and compile it. It then
> runs this class which in turn writes the requested servlet source to your
> specifications. For some reason, the Java file JET created seems to be
> compiled using jdk1.5 and you get this error when it is executed with
> jdk/jre1.4.
> see if this still happens. If not, you could compare the contents of the
> hidden .JETEmitters project to see if there are differences that might
> Cheers,
> Larry
>> Niyazi
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> 49.0)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 38 more
> <snip...>
Previous Topic:Flexible Projects - User Feedback Requested
Next Topic:problems in creating new dynamic web project
Current Time: Sun Jul 20 08:54:31 EDT 2025
Powered by FUDForum. Page generated in 0.26720 seconds
