Home » Eclipse Projects » e(fx)clipse » Standalone StyledTextArea(Implementing a standalone StyledTextArea for a code editor)
Standalone StyledTextArea [message #1469610] Tue, 11 November 2014 14:14 Go to next message
Hi!
So we are implementing a code editor which needs to feature inline completion (show with a different opacity the text next to the caret), placeholder editing (complete some syntax and leave some placeholders so the user can tab across them) and syntax highlighting.
I've cloned the efxclipse project and incorporated into the project the sources for StyledTextArea. The issue at the moment is with the content. There's a DefaultContent implementation of StyledTextContent but the main one is done by SWT text classes and an adapter.
I'd prefer not to include these as they have other SWT dependencies and we're using just JavaFX, not JFace neither other SWT components.
Ultimately we'd strip only the necessary classes but there's lots of features we'd not need, so we'd prefer to have a custom lightweight implementation.
What do you recommend us to implement an StyledTextContent given we'd need to implement on top of it the above features?
Thank you very much,
Guillermo
Re: Standalone StyledTextArea [message #1470265 is a reply to message #1469610] Wed, 12 November 2014 02:53 Go to previous messageGo to next message
On 12.11.14 00:56, Guillermo Cifuentes wrote:
> Hi!
Ok we have not yet worked on auto-complete, syntax highlighting is
working good. Only mention this because you need to prepare yourself for
some work ;-)
Yeah DefaultContent is not really working - I should fix or better
remove it!
> implementation.
We did this job already for you. In your cloned repo in
"efxclipse/experimental/compensator" you will find:
* org.eclipse.fx.text
* org.eclipse.fx.text.ui
which are forks from their jface-counter parts the only library you
consume directly from Eclipse.org is org.eclipse.text
I would recommend to use the org.eclipse.text infrastructure because it
already does all parsing and highlighting stuff for you with minimal deps.
IIRC they are:
* org.eclipse.text
* org.eclipse.core.commands
* org.eclipse.equinox.common
* com.ibm.icu.base
If you take a closer look into compensator you'll find out that it is a
fullblown editor framework for fairly any language (currently only
outline support is there but auto-complete is on the list for the
future) but I guess the above should get you going.
The editor framework is more of a research project - just to warn you ;-)
Tom
Re: Standalone StyledTextArea [message #1470905 is a reply to message #1470265] Wed, 12 November 2014 13:27 Go to previous messageGo to next message
Hi Tom,
First of all thanks a lot for your prompt and extensive response, I appreciate it.
I've been digging into the eclipse text project and I've finally discarded it because it is quite complex, and it could take some time to grok everything and get up to speed.
Since we already have the parsing and tokenizing done with Antlr4, and although it's possible to glue everything together, it required much effort.
What I'm finally doing at the moment is stripping out to the bare bones your editor, since I only need one line, and implementing on top of it the other features.
It's served as a great source of inspiration, the only pity is that I won't be able to contribute back the code since it differs a lot.
Again, thanks you very much and keep up rocking eclipse with JavaFX goodies Smile
Guillermo
Re: Standalone StyledTextArea [message #1471069 is a reply to message #1470905] Wed, 12 November 2014 16:31 Go to previous messageGo to next message
On 12.11.14 19:27, Guillermo Cifuentes wrote:
> Hi Tom,
> appreciate it.
> effort.
Sounds like an cool piece of source.
> the other features.
Maybe you can use the DefaultDocumentAdapter and the IDocument API so
that only the StyleRange stuff is left. Anyways I'm glad the code helps you!
No worries - maybe you can contribute to the editor control itself -
e.g. selection is not 100% working.
If there are any interfaces we could add so that you can plug in your
stuff into compensator just file bugs!
Like I said the compensator is more of a cool research project I work on
when I need a break from real world projects ;-)
Tom
Re: Standalone StyledTextArea [message #1494385 is a reply to message #1469610] Mon, 01 December 2014 07:30 Go to previous messageGo to next message
I'm also trying to use StyledTextArea in one of my projects and am fighting with the code.
The implementation of DefaultContent nested in StyledTextArea is too complex and doesn't seem to work.
The attached file is the simplest implementation of StyledTextContent interface that I could make.
I have a very simple javaFX test application that displays a StyledTextArea on a StackedPane. The StyledTextArea component is not displaying the text at this moment but using the debugger I can see that my custom content provider is working.
Any help in making StyledTextArea work would be appreciated.
Rodolfo M. Raya
Re: Standalone StyledTextArea [message #1494434 is a reply to message #1494385] Mon, 01 December 2014 08:18 Go to previous messageGo to next message
Yes the DefaultContent is broken.
Tom
On 01.12.14 13:30, Rodolfo M. Raya wrote:
> Regards,
> Rodolfo M. Raya
Re: Standalone StyledTextArea [message #1494462 is a reply to message #1494434] Mon, 01 December 2014 08:48 Go to previous messageGo to next message
I think your display problem is a problem of the StyledTextControl
itself who currently expects the full size of the text to be covered by
StyleRanges.
This works for me:
> BorderPane p = new BorderPane();
> StyledTextArea t = new StyledTextArea();
> t.getStylesheets().add(getClass().getResource("test.css").toExternalForm());
> t.getContent().setText("This is a styled text!");
> t.setStyleRanges(
> new StyleRange[] {
> new StyleRange("text-normal",0,10,null,null),
> new StyleRange("text-highlight",10,12,null,null)
> p.setCenter(t);
> Scene scene = new Scene(p,800,600);
> primaryStage.setScene(scene);
> primaryStage.show();
test.css:
> .text-normal {
> .text-highlight {
> -styled-text-color: #ff0000;
Tom
On 01.12.14 14:18, Tom Schindl wrote:
> Tom
>> Hi,
>> Regards,
>> Rodolfo M. Raya
Re: Standalone StyledTextArea [message #1494523 is a reply to message #1494462] Mon, 01 December 2014 09:47 Go to previous messageGo to next message
Thanks Tom.
Your example displays the text but crashes as soon as I press a key. Will try to adapt it with my custom content handler and report what happens.
Rodolfo
Re: Standalone StyledTextArea [message #1494614 is a reply to message #1494523] Mon, 01 December 2014 11:10 Go to previous message
With my own content handler I can press keys and use the arrows to move the caret but the display is not updated.
Rodolfo
Previous Topic:JavaFX classes not resolved after product export
Next Topic:Table column and composition relation binding
Current Time: Sat Jul 19 13:32:51 EDT 2025
Powered by FUDForum. Page generated in 0.31897 seconds
