SWTBot test problem: Double Click node call Derect Edit Label [message #1468903] |
Tue, 11 November 2014 01:21  |
In representation diagram, we have 2 nodes that represent 2 Folders inside a directory. The first node represents the empty folder, and the second node represents the folder that contain sub-folder inside.
We configure the .odesign so that when double click to a node, if the node present empty folder then nothing happens, else open the folder. And also set Direct Edit Label to Node (that present Folder)
It works fine when we run as SWTBot, but problem is that if we run test using Maven build, the double click to Node of empty folder will trigger Derect Edit Label, it mean that instead of nothing happens as expected, the node label is replaced by a textbox to edit.
(No problem found with the node of folder has sub-folder)
So what causes this problem? The problem comes from Maven or Sirius? And what should I do to fix now?
[Updated on: Wed, 12 November 2014 02:22] by Moderator
Re: SWTBot test problem: Double Click node call Derect Edit Label [message #1470849 is a reply to message #1468903] |
Wed, 12 November 2014 12:31   |
Hi Sann,
Do you run your SWTBot tests on Windows or Linux?
When you launch the tests with Maven, which plugin do you use, which
viewer do you use, Xephyr, Xvnc, ... ?
Your issue seems not related to Sirius.
Best Regards.
Le 11/11/2014 14:59, Sann Tran a écrit :
> For example, in representation diagram, we have 2 nodes that represent 2
> We configure the .odesign that when double click to a node, if the node
> also set Derect Edit Label to Node (that present Folder)
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: SWTBot test problem: Double Click node call Derect Edit Label [message #1472942 is a reply to message #1472782] |
Fri, 14 November 2014 02:57  |
Our Sirius SWTBot tests are executed on Linux, then I can't say if your
issue is related to Sirius.
Best Regards.
Le 14/11/2014 05:51, Sann Tran a écrit :
> Thanks for quick reply,
> The problem was found on Window, and we have not tested on Linux yet.
> We use tycho-surefire-plugin for viewer, I think.
> Please check it again, and if the issue is not related to Sirius, I
> think that we should raise the issue on Maven forum.
> Best regards,
FUDForum. Page generated in 0.04270 seconds
