comparing a row from a subreport to a row in the master report, is it possible? [message #146060] |
Mon, 20 March 2006 13:12  |
Anyone managed to do this?
I want to highlight a row if the date in a subreport is greater than the
date in the master report.
So I have a list. In the list is a GRID with the columns of the "master"
report, which include row["editedat"]. The last cell of the grid is a list
with a single "detail" which is a different data set and a single column
row["offtime"].
Now in the highlighter dialogue for the offtime sub report cell, if i open
the expression builder under available dataasets It shows the master and
subreport rows. But If I use a master row, I get:
detail : org.eclipse.birt.data.engine.core.DataException: Invalid field
at
org.eclipse.birt.data.engine.executor.ResultObject.getFieldV alue(ResultObject.java:138)
Doh!.
Anyone know how to do this? I could use the onCreate script, in the sub
report data cell, but how do I access the containing reports elements?
this.getParent() might give me the list,
this.getParent().getParent() might give me the grid, but how to I access the
data elements in a grid?
Birt.
Re: comparing a row from a subreport to a row in the master report, is it possible? [message #146077 is a reply to message #146060] |
Mon, 20 March 2006 13:49   |
It's a known bug that BIRT designer generates the wrong expression when you
choose to use an outer table's data set column within an inner table. To fix
this modify the inner table's expression to use the "rows" variable instead
of "row". In your case, change the row["editdat"] reference in the inner
table's highlight expression to rows[0]["editdata"]. The "rows" array gives
you access to parent tables' data sets' rows. "rows[0]" is the top-level
table's "row" variable, "row[1]" is the next level, etc.
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"birt" <birt@ohds.co.uk> wrote in message
news:dvmra8$h1s$1@utils.eclipse.org...
list
> row["offtime"].
> at
t.java:138)
> Doh!.
the
> Birt.
Re: comparing a row from a subreport to a row in the master report, is it possible? [message #146645 is a reply to message #146077] |
Tue, 21 March 2006 15:36  |
You are a GOD, this works!!!!
Ive been looking for weeks for a solution. Where did you find it?
Birt.
"Gary Xue" <gxue@actuate.com> wrote in message
news:dvmtcf$vad$1@utils.eclipse.org...
> you
> fix
> instead
> gives
> Gary Xue
> BIRT Committer
> list
>> row["offtime"].
>> open
>> at
> t.java:138)
>> Doh!.
> the
>> Thanks,
>> Birt.
FUDForum. Page generated in 0.25250 seconds
