Home » Eclipse Projects » NatTable » Running Nattable Example(Trouble running nattable examples)
Running Nattable Example [message #1465751] Sat, 08 November 2014 12:04 Go to next message
Having trouble checking out the examples any input on how to make it work
I am on java 1.7.0_45. I should add that my jvm is 64 bit if that helps tried both 64 and 32 bit jar
index.php/fa/19811/0/
  • Attachment: delete.png
    (Size: 17.89KB, Downloaded 193 times)
    (Size: 24.97KB, Downloaded 638 times)
[Updated on: Sat, 08 November 2014 12:12] by Moderator
Re: Running Nattable Example [message #1465768 is a reply to message #1465751] Sat, 08 November 2014 12:23 Go to previous messageGo to next message
I would rename the jar to avoid the space in the filename
Re: Running Nattable Example [message #1466129 is a reply to message #1465768] Sat, 08 November 2014 19:45 Go to previous messageGo to next message
that solved one part but now this comes up
index.php/fa/19812/0/
    (Size: 37.95KB, Downloaded 655 times)
Re: Running Nattable Example [message #1466207 is a reply to message #1466129] Sat, 08 November 2014 21:20 Go to previous messageGo to next message
Is the SWT jar in that download directory?
Re: Running Nattable Example [message #1466481 is a reply to message #1466207] Sun, 09 November 2014 03:00 Go to previous messageGo to next message
yes I just donwloaded the jar and nattable before running the command.
Re: Running Nattable Example [message #1466494 is a reply to message #1466481] Sun, 09 November 2014 03:14 Go to previous message
Well the error says it can not find SWT. Do you should check that.
Or simply open the examples app via webstart by clicking 'try it' on the NatTable website
Previous Topic:Is The Given Problem Statement Possible in Nattable
Next Topic:NatTabel sort failing
Current Time: Sun Jul 20 02:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.07079 seconds
