Home » Eclipse Projects » NatTable » Hiding all columns without a rowheader(Hidden columns)
Hiding all columns without a rowheader [message #1463573] Thu, 06 November 2014 13:00 Go to next message
Our project has a requirement to not include the row header or corner in our nattable implementation. However, this presents an issue if the end user hides all columns they no longer have a layer to right-click and show all columns. Could someone give us an idea about how to work around this issue.
Thank you,
Dan
Re: Hiding all columns without a rowheader [message #1463660 is a reply to message #1463573] Thu, 06 November 2014 15:08 Go to previous messageGo to next message
Either add a context menu to the NatTable Canvas or add some button or anything similar that allows to recover
Re: Hiding all columns without a rowheader [message #1463661 is a reply to message #1463660] Thu, 06 November 2014 15:09 Go to previous messageGo to next message
Oh, or implement a custom hide command handler that doesn't allow to hide all. For example always one column stays visible
Re: Hiding all columns without a rowheader [message #1464493 is a reply to message #1463661] Fri, 07 November 2014 11:19 Go to previous messageGo to next message
Thank you for the response Dirk. Was thinking along those lines with the command handler.
Re: Hiding all columns without a rowheader [message #1473106 is a reply to message #1464493] Fri, 14 November 2014 05:40 Go to previous message
For your information, the "hide all columns" issue is tracked by the following tickets:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=451486
https://bugs.eclipse.org/bugs/show_bug.cgi?id=451490
There are contributions for those tickets that will add the ability to check if hiding all columns is possible. The dialog OK button will be disabled if trying to hide all columns. Also the header menu items will use the check to avoid hiding all columns via menu.
After I was able to verify the contribution and hopefully merged it into core, this topic should be done.
Previous Topic:Extending NatTable
Next Topic:Changing the default Excel filename on export
Current Time: Sun Jul 20 03:45:15 EDT 2025
Powered by FUDForum. Page generated in 0.05933 seconds
