Home » Eclipse Projects » Equinox » How to programatically close the osgi console
How to programatically close the osgi console [message #1464492] Fri, 07 November 2014 11:19 Go to next message
Hello
I have an eclipse application , which is being invoked from the command line using a command like
eclipse.exe -consoleLog -console -application <ApplicationId>
This opens another command window , which closes immediately after the application finishes. In order to review the console output the command line was modified to add the 'noExit' parameter
eclipse.exe -consoleLog -console -noExit -application <ApplicationId>
With this the new console window stays open. The user has to explcitly type 'Exit' to quit the console. When I do it , the new console window stays as is, but the osgi console session is closed
The question is
How can i do this from within the code, so that the user does not have to interact with the app to do it
I did notice the 'DisconnectCommand' or 'CloseSession' osgi console classes . not sure if these can be used.
ANy pointers is greatly appreciated
Ani
Re: How to programatically close the osgi console [message #1468034 is a reply to message #1464492] Mon, 10 November 2014 09:20 Go to previous messageGo to next message
I find this behavior of the concole to be rather annoying but I have not spent the time necessary to investigate why this thread just hangs out after the gogo and equinox console bundles have been stopped. Ideally they should clean up properly on shutdown. Could you please open a bug and we can investigate. Thanks.
... and no I am not aware of a programmatic way to shutdown the running thread, but perhaps there is some gogo API we are not calling correctly when our equinox console bundle stops.
Re: How to programatically close the osgi console [message #1468290 is a reply to message #1468034] Mon, 10 November 2014 13:38 Go to previous message
Hi Thomas
Thanks for your reply. I will log a defect and update this with the details.
In the mean time , i was wondering if there was any way of
a) Getting a handle to the console / osgi console in this case
b) Execute the Exit command programatically.
I tried the following code snippet mentioned . For some reason i do get a lost of consoles , using this code.
https://wiki.eclipse.org/FAQ_How_do_I_write_to_the_console_from_a_plug-in%3F
private MessageConsole findConsole(String name) {
ConsolePlugin plugin = ConsolePlugin.getDefault();
IConsoleManager conMan = plugin.getConsoleManager();
IConsole[] existing = conMan.getConsoles();
for (int i = 0; i < existing.length; i++)
if (name.equals(existing[i].getName()))
return (MessageConsole) existing[i];
//no console found, so create a new one
MessageConsole myConsole = new MessageConsole(name, null);
conMan.addConsoles(new IConsole[]{myConsole});
return myConsole;
Ani
Previous Topic:Webstart java 8 update 25
Next Topic:p2 director, "missing requirements" that are totally there
Current Time: Sat Jul 19 13:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.04911 seconds
