Home » Modeling » TMF (Xtext) » How to work with mydsl from java?
How to work with mydsl from java? [message #1460426] Mon, 03 November 2014 09:58 Go to next message
I have example.mydsl and Inferr which transform it to java. I would like to write other java class with main method and read example.mydsl in main method and I want to write in main method where I want to save generated java file from example.mydsl.
Something like this:
public class Test {
		read(example.mydsl);
		saveGeneratedFileTo(url..)
Is it possible?
Thanks in advance,
Marko
Re: How to work with mydsl from java? [message #1460443 is a reply to message #1460426] Mon, 03 November 2014 10:20 Go to previous messageGo to next message
for the first part
https://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
for the seccond part: obtain an igenerator and call it.
you may adapt the generator fragment in the workflow to generate a java main
Re: How to work with mydsl from java? [message #1462772 is a reply to message #1460443] Wed, 05 November 2014 18:27 Go to previous messageGo to next message
Thak you Christian,
I did next:
package pakett;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.ui.internal.Model;
import org.eclipse.xtext.generator.IGenerator;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.resource.XtextResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceImpl;
import com.google.inject.Injector;
import com.vps.java.ServerStandaloneSetup;
import com.vps.java.generator.ServerGenerator;
import com.vps.java.jvmmodel.ServerJvmModelGenerator;
import org.eclipse.xtext.generator.IFileSystemAccess;
public class Test {
		new org.eclipse.emf.mwe.utils.StandaloneSetup().setPlatformUri("../");
		Injector injector = new ServerStandaloneSetup().createInjectorAndDoEMFRegistration();
		XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
		resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		Resource resource = resourceSet.getResource(URI.createURI("platform:/resource/Probaaa/src/pakett/test.server"), true);
		Model model = (Model)resource.getContents().get(0);
		ServerGenerator gen = new ServerGenerator();
but got next error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/emf/mwe/core/ConfigurationException
	at pakett.Test.main(Test.java:23)
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.mwe.core.ConfigurationException
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
	... 1 more
Parameter in setPlatformUri("../") is not good but I tried a lot path but always got error.
Do yuo know what is problem and what should I do next?
Thank you very much,
Marko
Re: How to work with mydsl from java? [message #1463069 is a reply to message #1462772] Thu, 06 November 2014 02:15 Go to previous messageGo to next message
if you use file uris you wont need the platform uri stuff.
never the less a NoClassDefFoundError should be clear
looks like you are missing the plugin org.eclipse.emf.mwe.core
p.s. how to you call the java main?
Re: How to work with mydsl from java? [message #1463754 is a reply to message #1463069] Thu, 06 November 2014 17:22 Go to previous messageGo to next message
I create java class with main method in java project in Eclipse and included all required plugins. I run this class with right click->Run As->Java Application and have error which I mentioned in a previous post.
I still do not know how to solve the problem.
Thank you Christian,
Marko
Re: How to work with mydsl from java? [message #1463781 is a reply to message #1463754] Thu, 06 November 2014 18:00 Go to previous messageGo to next message
am not sure what you exactly did
(1) create a xtext project using the wizard
(2) create main file
(3) run it once from eclipse
(4) use the export -> java -> runnable jar file wizard.
Re: How to work with mydsl from java? [message #1469235 is a reply to message #1463781] Tue, 11 November 2014 07:20 Go to previous message
Thank you Christian, it works now.
I have other question,
Is Xtext team maybe plannig to develope Xtext for other language, not only java with Xbase, (javascript or python or any other)?
Marko
Previous Topic:Opening Editor in Read-only Mode.
Next Topic:Errors running builder 'Xtext Project Builder' on project
Current Time: Sun Jul 20 16:40:47 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
