Home » Eclipse Projects » NatTable » Extending NatTable (When I am extending NatTable, it is coming with deafult NatTable. How to avoid the default NatTable from being added?)
Extending NatTable [message #1463295] Thu, 06 November 2014 07:17 Go to next message
I am calling NatTable from the dialog as below:
MyNatTable natTable = new MyNatTable(composite);
MyNatTable extends from NatTable as below:
public class FV9VSCSECUVarNatTable extends org.eclipse.nebula.widgets.nattable.NatTable
I am using the class constuctor as below:
public MyNatTable(Composite parent)
super(parent,true);
In this case I am getting composite with default NatTable (please check in the attached screenshot). When I am trying to add my contents it is coming below this default NatTable.
How to avoid this default NatTable from being added to composite?
Re: Extending NatTable [message #1463373 is a reply to message #1463295] Thu, 06 November 2014 09:01 Go to previous messageGo to next message
Moving this to the NatTable forum group.
Re: Extending NatTable [message #1463424 is a reply to message #1463373] Thu, 06 November 2014 09:52 Go to previous messageGo to next message
If you extend NatTable you should check which constructors you need to implement accordingly. It seems you only implemented the constructor that creates the default NatTable stuff.
Although I completely don't understand why you are extending NatTable instead of using and configuring it.
Re: Extending NatTable [message #1464283 is a reply to message #1463424] Fri, 07 November 2014 06:36 Go to previous messageGo to next message
Hi Dirk,
Actually I need to create TabFolder that will have different tabs as per requirement. In each tab I need to show Nattable with different eventlist. The table columns will be same however data will be different as it will be fetched from different objects.
In short I need to create multiple NatTable runtime and add it in different tab. The number of Tab and NatTable will very depending upon condition.
I was trying to separate out NatTable creation so that I can add it under different tab.
What do you think is the better way?
Re: Extending NatTable [message #1464300 is a reply to message #1464283] Fri, 07 November 2014 07:00 Go to previous message
create a new NatTable instance on the tab. If you want to abstract things out, implement a custom pre-configured layer. But it doesn't make sense to extend NatTable
Previous Topic:How to use Nattable as a tree viewer?
Next Topic:Hiding all columns without a rowheader
Current Time: Sat Jul 19 14:24:29 EDT 2025
Powered by FUDForum. Page generated in 0.29129 seconds
