How to use AdapterFactoryObservableList ? [message #1462366] |
Wed, 05 November 2014 08:55  |
I'm trying out the demo about EMF Edit in efxclipse but with my own (extremely simple) ecore model : I only have one class in it, Employer.
So I want to bind this model to an ObservableList, like this :
@PostConstruct
public void init(BorderPane parent, MApplication application)
EditingDomain domain = modelservice.getEditingDomain() ;
AdapterFactory factory = modelservice.getAdapterFactory() ;
listView.setItems(new AdapterFactoryObservableList<Object>(factory, modelservice.getRoot()));
listView.getSelectionModel().setSelectionMode(SelectionMode.MULTIPLE);
parent.setCenter(listView);
As root element, I thought of just providing the first element of my resource, as follows :
public Object getRoot()
return resource.getContents().get(0) ;
When I run this code, I get an IllegalArgumentException : Provided root object cannot be adapted.
But what other root could I provide ? In the demo, the (contact)Group is used for this, but I don't have one in my own model.
The demo would have the same problem anyhow if we would try to have a ListView of contact groups.
I can't come up with some useful alternative, a fortiori because I can't figure out the semantics of a rootelement in a listview? I should just layout independent elements, or am I getting this wrong ?
Thomas
Re: How to use AdapterFactoryObservableList ? [message #1462435 is a reply to message #1462366] |
Wed, 05 November 2014 10:15   |
How did you setup your adapter-factory? Have you tried simply pushing
your resource?
Tom
On 05.11.14 14:55, Thomas Elskens wrote:
> Hello,
> @PostConstruct
> @Override
> Thomas
Re: How to use AdapterFactoryObservableList ? [message #1462542 is a reply to message #1462435] |
Wed, 05 November 2014 12:41   |
You could also look how the generated SWT-Editor works. I've never
really used EMF-Edit so I'm not of great help in this regard but from my
EMF-Projects I normally always create a Root-Element which holds my
domain model, the reason is simply you can only serialize to XML (I'm
not talking about XMI) if you have exactly 1 root-element.
Tom
> your resource?
> Tom
>> Hello,
>> @PostConstruct
>> @Override
>> Thomas
FUDForum. Page generated in 0.04062 seconds
