Master Page Footer Height [message #1462395] |
Wed, 05 November 2014 09:34  |
it is possible to have a dynamic size of the footer height in master page. If i try to set no value to the size, the size is automatically set to 0.5in.
Thanks in advance.
Re: Master Page Footer Height [message #1746967 is a reply to message #1476776] |
Tue, 08 November 2016 02:20  |
I am also facing the same issue. I am generating the PDF with Fixed Layout. We have a dynamic footer whose length is different every time the report is run. We were using Birt 2.5 version where, if we do not specify the Footer height, the footer is set to the end of the page and is dynamic, i.e the text in the table is shown completely and the page above the footer is set accordingly. Now we are moving to the Birt 4.4.2 version. Now if we do not specify the footer height then it is either set to 0 or 0.5in and no or only few lines are visible from the footer.
Is there any way in 4.4.2 to adjust the footer depending upon the dynamic text. It is not possible to count the number of lines or characters as these reports are in different languages and for each run, in different languages, the length of the footer is different.
Thanks in Advance.
FUDForum. Page generated in 0.28259 seconds
