Home » Eclipse Projects » Eclipse 4 » Shortcuts / Keybinding doesn't work
Shortcuts / Keybinding doesn't work [message #1458018] Fri, 31 October 2014 20:02 Go to next message
Hi all,
is there a point where I can control if a keybinding is active or not? I've created a test project where the key binding works fine:
http://ralf-heydenreich.homepage.t-online.de/bilder/Screenshot-working.png
Another test project (with some additional plugins) don't work at all with keybindings (no shortcuts are added to menu entries, no shortcut is active):
http://ralf-heydenreich.homepage.t-online.de/bilder/Screenshot-notWorking.png
Any hints are welcome.
Ralf.
Re: Shortcuts / Keybinding doesn't work [message #1459428 is a reply to message #1458018] Sun, 02 November 2014 08:32 Go to previous messageGo to next message
Which keybinding-set is active is defined through the active-contexts
you have set in your application model.
Tom
On 01.11.14 01:02, Ralf Heydenreich wrote:
> Hi all,
> active):
> Ralf.
Re: Shortcuts / Keybinding doesn't work [message #1459597 is a reply to message #1459428] Sun, 02 November 2014 13:01 Go to previous messageGo to next message
Am 02.11.2014 um 14:32 schrieb Tom Schindl:
> Tom
>> Hi all,
>> active):
>> Ralf.
Hi Tom,
the binding contexts are equal in both application models. The controls
don't have set any binding context, which IMHO means that the default is
used. maybe there's an additional plugin which prevents the correct key
binding? I'll try to debug this to collect more information...
Ralf.
[SOLVED] Re: Shortcuts / Keybinding doesn't work [message #1459681 is a reply to message #1459597] Sun, 02 November 2014 15:15 Go to previous message
Hi all,
I found it out. For testing purposes I added the org.eclipse.help plugin
and the org.eclipse.ui.workbench (NOT only the e4 workbench!) to my
launch configuration. This causes that all keybindings were removed (has
to do with the extension point registry, but this I didn't analyzed
further). I removed these plugins from my launch configuration and now
it works as expected ;-)
Ralf.
Am 02.11.2014 um 19:01 schrieb Ralf Heydenreich:
>> Tom
>>> Hi all,
>>> active):
>>> Ralf.
> Hi Tom,
> Ralf.
Previous Topic:Menu Item Handler Execute() Results in IllegalStateException: Workbench has not been created yet
Next Topic:Eclipse 3.x Bridge Cannot Be Installed with e4 Tools
Current Time: Sun Jul 20 10:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.02678 seconds
