Home » Eclipse Projects » Remote Application Platform (RAP) » PageBook on FormDialog
PageBook on FormDialog [message #1458293] Sat, 01 November 2014 03:28 Go to next message
Hi RAP Team,
We have a little case where we put SWT Text component on PageBook which
reside on a FormDialog. When focus in on the Text and user presses Enter
key a Widget is disposed exception is thrown.
Below is the snippet:
Button button = toolkit.createButton(container, "PageBook Dialog",
SWT.PUSH);
button.setLayoutData(GridDataFactory.swtDefaults().hint(150,
SWT.DEFAULT).create());
button.addSelectionListener
new SelectionAdapter()
private static final long serialVersionUID = 8745498441542541616L;
public void widgetSelected(SelectionEvent e)
FormDialog dialog = new FormDialog(container.getShell())
private static final long serialVersionUID = -8404073274862848632L;
protected void createFormContent(IManagedForm managedForm)
{ Composite parent = managedForm.getForm().getBody();
parent.setLayout(GridLayoutFactory.fillDefaults().create());
FormToolkit toolkit = managedForm.getToolkit();
Composite composite = toolkit.createComposite(parent);
composite.setLayout(GridLayoutFactory.fillDefaults().create());
composite.setLayoutData(GridDataFactory.fillDefaults().grab(true,true).create());
PageBook pageBook = new PageBook(composite, SWT.NONE);
pageBook.setLayout(GridLayoutFactory.fillDefaults().create());
pageBook.setLayoutData(GridDataFactory.fillDefaults().grab(true,false).create());
toolkit.adapt(pageBook, true, true);
Composite page = toolkit.createComposite(pageBook);
page.setLayout(GridLayoutFactory.fillDefaults().create());
page.setLayoutData(GridDataFactory.fillDefaults().grab(true,true).create());
Text text = toolkit.createText(page, null);
text.setLayoutData(GridDataFactory.fillDefaults().grab(true,false).create());
pageBook.showPage(page);
dialog.open();
If we remove the PageBook all works fine.
Any help would be greatly appreciated.
Setya
Re: PageBook on FormDialog [message #1465205 is a reply to message #1458293] Sat, 08 November 2014 01:08 Go to previous messageGo to next message
Hi Team,
Anybody can confirm this problem.
I'm on RAP 1.5 and so far unable to reproduce it on RCP.
Setya
On 11/01/2014 02:28 PM, Setya wrote:
> Hi RAP Team,
> SWT.PUSH);
> @Override
> @Override
> Composite page =
> Text text =
> dialog.open();
> Regards,
> Setya
Re: PageBook on FormDialog [message #1466602 is a reply to message #1465205] Sun, 09 November 2014 05:24 Go to previous messageGo to next message
Hi Setya,
this sounds similar to this bug:
449350: Press keys then escape key fast enough in dialog generates
"Widget is disposed" exceptions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=449350
which we fixed recently in 3.0 master branch. I can't say for sure what
is going on with RAP 1.5 (a lot of changes have been made to RAP since
than), but could be a similar problem.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: PageBook on FormDialog [message #1466775 is a reply to message #1466602] Sun, 09 November 2014 08:51 Go to previous messageGo to next message
Hi Ivan,
Thank you for your information.
So should I file a bug against this ?
Setya
Re: PageBook on FormDialog [message #1466874 is a reply to message #1466775] Sun, 09 November 2014 10:53 Go to previous message
Can you reproduce it with RAP 3.0?
Ivan Furnadjiev
Previous Topic:Cool new feature: multiple tab support. How do I turn it off?
Next Topic:Nebula Grid missing GridTableViewer and GridTreeViewer
Current Time: Sun Jul 20 09:01:10 EDT 2025
Powered by FUDForum. Page generated in 0.04348 seconds
