Home » Newcomers » Newcomers » WindowBuilder Plug-in(Where is the WindowBuilder Plug-in)
WindowBuilder Plug-in [message #1455636] Wed, 29 October 2014 11:35 Go to next message
I ran into some info about WindowBuilder Plug-in at http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.wb.swing.doc.user%2Fhtml%2Fwizards%2Fswing%2Fjframe.html.
Where is the link to download that plug-in?
Re: WindowBuilder Plug-in [message #1455735 is a reply to message #1455636] Wed, 29 October 2014 13:57 Go to previous messageGo to next message
Your Eclipse is a couple of generations old. You might be better off with Luna.
Click Help -> Install new software -> Swing Designer
Re: WindowBuilder Plug-in [message #1455807 is a reply to message #1455735] Wed, 29 October 2014 15:36 Go to previous messageGo to next message
When I select Help -> Install new Software ... Swing Designer is not an option.
When I select Help -> About Eclipse ... I see Eclipse IDE for Java Developers ... Luna Service Release 1 (4.4.1).
While I've written code for many years (including Visual Studio C# WPF), I'm new to Java and Eclipse. The number one challenge I'm facing is the "many" choices ... difficult for me to identify what I "need" to learn Java and Eclipse.
My primary goal is to learn Java, to create websites, and eventually access databases. I like to learn by seeing sample code. As I understand, Eclipse is a good foundation. Any suggestions where I can download some sample code?
Re: WindowBuilder Plug-in [message #1455816 is a reply to message #1455807] Wed, 29 October 2014 15:45 Go to previous messageGo to next message
That version of Eclipse already includes WindowBuilder, no need to install it.
Having said that, you don't need WB to learn Java or create web applications - WB is primarily for creating desktop Java GUIs.
For good tutorials, have a look at Lars' stuff, it's generally pretty good and he's an Eclipse guru: http://www.vogella.com/tutorials/
Re: WindowBuilder Plug-in [message #1455889 is a reply to message #1455807] Wed, 29 October 2014 17:37 Go to previous messageGo to next message
Sorry - I had to look at already installed packages.
Go to Help -> Install new software, and select your Eclipse update site.
My preference is <Luna - http://download.eclipse.org/releases/luna>
WindowBuilder is in General Purpose tools.
There are also tools for Web development in
Web, XML, Java EE and OSGI Enterprose Development.
Re: WindowBuilder Plug-in [message #1456762 is a reply to message #1455816] Thu, 30 October 2014 13:52 Go to previous messageGo to next message
I find the Lars Vogel tutorial very useful. Thanks!
Eclipse IDE - Tutorial -> 20.5. Write a test class ... not certain what else to add. I am using the code examples in previous sections (classes Todo & TodoProvider). I have:
package com.vogella.ide.todo;
import java.util.List;
public class TodoProviderTest
public static void main(String[] args)
System.out.println(TodoProviderListCount());
private static int TodoProviderListCount()
List list = TodoProvider();
return list.size();
The compiler does not like "List list = TodoProvider()".
Re: WindowBuilder Plug-in [message #1456830 is a reply to message #1456762] Thu, 30 October 2014 15:32 Go to previous message
TodoProvider tp = new TodoProvider();
List list = tp.createInitialModel();
return list.size();
Works. Is this considered a standard way? Is there a simpler, cleaner way?
Previous Topic:close panel window with one click
Next Topic:I can't import a project
Current Time: Sun Jul 20 17:55:47 EDT 2025
Powered by FUDForum. Page generated in 0.11424 seconds
