Home » Modeling » Model-to-Model Transformation » [QVTo] how to query all objects from a referenced model ?
[QVTo] how to query all objects from a referenced model ? [message #1456406] Thu, 30 October 2014 06:24 Go to next message
I'm using QVTo to translate a model in another one (classical).
My source model is referencing eObjects from another model (conforming to another MM)
I used to do something like that to query all the objects of type XXX:
inM.rootObjects().allSubObjects()[XXX] -> map ....
However, this code does not work for the objects referenced from another model Sad
What am I missing ?
is there a workaround ?
thanks
j
Re: [QVTo] how to query all objects from a referenced model ? [message #1457589 is a reply to message #1456406] Fri, 31 October 2014 09:35 Go to previous messageGo to next message
The whole thing depends on the concept of extent which is not
well-defined for model inputs.
OMG-wise it would appear that referenced models are definitely not
considered if they involve types not forming part of the true input.
Whether types that occur in the true input are included is vague.
Eclipse-wise, without studying the code, there is a design choice as to
whether extent corresponds to Resource or ResourceSet. The classic OCL
uses Resource, the Pivot OCL uses ResourceSet for allInstances().
You should get predictable behavior by explicitly navigating to the
roots of referenced resources and then using perhaps
Element::allSubobjects()
Ed Willink
On 30/10/2014 10:24, Julien DeAntoni wrote:
> Hello,
> to another MM)
> model :(
> What am I missing ?
> thanks
> j
Re: [QVTo] how to query all objects from a referenced model ? [message #1457603 is a reply to message #1456406] Fri, 31 October 2014 09:57 Go to previous message
thanks a lot for the answer...
Because the transformation is generated automatically (by an HOT) it would have been of great help to have a Element::veryAllSubObjects() Smile.
Anyway, I should be able to grab the good resource by calling black box java
thanks a lot Ed !
regards
julien
Previous Topic:Choosing between ATL and QVT for model to model transformation
Next Topic:Empty target model
Current Time: Sat Jul 19 13:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.03613 seconds
