Home » Eclipse Projects » Eclipse Platform » excessive authentication when using CVS remotely
excessive authentication when using CVS remotely [message #144673] Wed, 15 October 2003 20:05 Go to next message
Originally posted by: Hamelech.AlHakol.com
When using CVS at the office (local LAN, 10/100 mixed network), performance
is not an issue.
When I use eclipse/CVS (Win/XP pro) from home I notice that most of the
wall-time of a CVS transaction is spent in 'Authentication'.
The connection at the office is ADSL (128KB outbound, 512+KB inbound).
My connection at home is a cable modem which typically downloads at T1
speeds or greater.
The application I'm working on has multiple projects. When I select them all
(40+) and perform a 'global' CVS operation (ex: refresh branches) the
operation which takes at most a few minutes in the office, takes 30-60
minutes from home.
As far as I can tell, most of the delay is due to repeated authentication.
It seems CVS is authenticating me for each project it access rather than a
single authentication when the request starts.
My questions:
1- Is my interpretation of what is going on correct?
2- More importantly, how can I solve this problem? I would like the
performance from home to be in the same ball park as my work at my office.
-TIA
David
Re: excessive authentication when using CVS remotely [message #145090 is a reply to message #144673] Thu, 16 October 2003 12:57 Go to previous messageGo to next message
See new and noteworthy features for the 3.0 M4 relase. 3.0 is under
development currently.
"David J. Marcus" <Hamelech@AlHakol.com> wrote in message
news:bmknbb$ct8$1@eclipse.org...
> Hi
performance
> is not an issue.
> speeds or greater.
all
> minutes from home.
> My questions:
> -TIA
> David
Re: excessive authentication when using CVS remotely [message #145411 is a reply to message #145090] Thu, 16 October 2003 20:53 Go to previous messageGo to next message
Thanks for the reference to 3.0 M4... it was very illuminating. I am
downloading the version and will try their suggested improvement of CVS
usage.
From what I infer from the description of the split of read/write
connection, it will probably alleviate the problem to some extent but it
doesn't appear to address the overall problem where I select a (large) group
of projects and issue a CVS command (such as Team->Update) and where the
command authenticates once for each project in the selected group rather
than a single authenticate which lasts until the command is done with all of
the projects. Such a mode of operation would be ideal from my perspective.
-Thanks again
David
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bmmilh$1ct$1@eclipse.org...
> > Hi
> performance
> > is not an issue.
> > speeds or greater.
> all
> > minutes from home.
authentication.
a
> > My questions:
office.
> > -TIA
> > David
Re: excessive authentication when using CVS remotely [message #145427 is a reply to message #145411] Thu, 16 October 2003 21:19 Go to previous messageGo to next message
As a follow-up, I took a closer look at my CVS connection in eclipse.
I'm already using 'pserver' which means that the split of the read/write
connections suggested by the release notes will not help. I really do need a
mode which does a single global validation once, then performs the selected
operation on all the selected projects rather than doing an authentication
on each project selected.
-TIA
David
news:bmneia$q9g$1@eclipse.org...
> Hi
> usage.
group
of
> -Thanks again
> David
> > > Hi
> > performance
> > > is not an issue.
the
> > > speeds or greater.
them
> > all
> > > minutes from home.
> authentication.
than
> a
> > > My questions:
the
> office.
> > > -TIA
> > > David
Re: excessive authentication when using CVS remotely [message #145737 is a reply to message #145427] Fri, 17 October 2003 10:03 Go to previous message
Originally posted by: Michael_Valenta.oti.com
David,
The use of a connection per project is related to the Team archtitecture
of Eclipse. It is also typically how CVS works. Having said that, it
would be feasible to perform the operation over a minmal number of
connections. Please log a feature request against Platform VCM.
Michael
David J. Marcus wrote:
> Hi
> -TIA
> David
>>Hi
>>usage.
> group
> of
>>-Thanks again
>>David
>>>>Hi
>>>performance
>>>>is not an issue.
> the
>>>>speeds or greater.
> them
>>>all
>>>>minutes from home.
>>authentication.
> than
>>a
>>>>My questions:
> the
>>office.
>>>>-TIA
>>>>David
Previous Topic:Eclipse editor doesn't notice VSS keyword expansion?
Next Topic:CVS conflict on already merged code
Current Time: Sat Jul 19 09:08:48 EDT 2025
Powered by FUDForum. Page generated in 0.25373 seconds
