Home » Eclipse Projects » Sirius » Get selected element
Get selected element [message #1450709] Wed, 22 October 2014 16:44 Go to next message
My issue seems to be very simple but I could not manage to solve it. How can I get the EMF object selected in a diagram?
Re: Get selected element [message #1451037 is a reply to message #1450709] Thu, 23 October 2014 04:34 Go to previous message
I think it depends on the content of your selection.
If you try to use the interpreter view, the selection will contains the
Sirius internal EObjects, from them you can retrieve the corresponding
domain/semantic element with the "target" reference. This EReference is
define in the Sirius metamodel on the DSemanticDecorator EClass.
If you are in some Java code, the following tips could allow to retrieve
the wanted element:
. org.eclipse.gef.EditPart.getModel() will return the GMF View
. org.eclipse.gmf.runtime.notation.View.getElement() will return the
Sirius DDiagramElement
. org.eclipse.sirius.diagram.DDiagramElement inherits from
org.eclipse.sirius.viewpoint.DSemanticDecorator and getTarget() will
return the domain EObject.
Maxime - Obeo
Need professional services for Sirius?
Previous Topic:Export the Sirius project so others can use
Next Topic:Developer Documentation
Current Time: Sun Jul 20 14:27:58 EDT 2025
Powered by FUDForum. Page generated in 0.08347 seconds
