Home » Newcomers » Newcomers » Eclipse and Hibernate. Reverse engineering(Error when I try to Hibernate Code Generation)
Eclipse and Hibernate. Reverse engineering [message #1449752] Tue, 21 October 2014 15:59 Go to next message
I'm trying to use reverse engineering to generate the POJOs, XML, DAO, and so on, and when I run Hibernate Code Generation shows me the following error message:
org.hibernate.console.HibernateConsoleRuntimeException: Received a NoClassDefFoundError, probably the console configuration classpath is incomplete or contains conflicting versions of the same class
with the following stack trace:
at org.hibernate.eclipse.console.common.ConsoleExtension.launchExporters(ConsoleExtension.java:137)
at org.hibernate.eclipse.launch.CodeGenerationLaunchDelegate.launch(CodeGenerationLaunchDelegate.java:266)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:883)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.hibernate.cfg.reveng.OverrideRepository
at org.jboss.tools.hibernate.proxy.ServiceProxy.newOverrideRepository(ServiceProxy.java:203)
at org.hibernate.eclipse.console.common.ConsoleExtension$2.execute(ConsoleExtension.java:282)
at org.hibernate.console.execution.DefaultExecutionContext.execute(DefaultExecutionContext.java:63)
at org.hibernate.console.ConsoleConfiguration.execute(ConsoleConfiguration.java:108)
at org.hibernate.eclipse.console.common.ConsoleExtension.buildConfiguration(ConsoleExtension.java:266)
at org.hibernate.eclipse.console.common.ConsoleExtension.runExporters(ConsoleExtension.java:174)
at org.hibernate.eclipse.console.common.ConsoleExtension.launchExporters(ConsoleExtension.java:110)
... 6 more
I have installed on my computer:
- Eclipse Luna
- Apache Tomcat v7.0
- Struts2
- Hibernate Tools.
- Libraries hibernate: I tried 3.6 i 4.3
- Use the SGDB PostgreSQL 9.3
I have also tried to delete the Hibernate libraries and only had the Hibernate Tools but still gives the same error.
Even just leaving the Hibernate3 and JDBC driver library for PostgreSQL
I would appreciate help solving this.
Thank you.
José Luis
Re: Eclipse and Hibernate. Reverse engineering [message #1451176 is a reply to message #1449752] Thu, 23 October 2014 08:48 Go to previous message
Hibernate Tools is provided by a third party, not supported by eclipse.org. I suggest you seek help on the Hibernate forums, https://forum.hibernate.org/
Previous Topic:Eclipse won't start? READ THIS FIRST didn't work
Next Topic:Eclipse not starting on Mepis Linux
Current Time: Sun Jul 20 08:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.13708 seconds
