Home » Eclipse Projects » Remote Application Platform (RAP) » Tree collapse selection change not firing Selection listener
Tree collapse selection change not firing Selection listener [message #1449211] Mon, 20 October 2014 23:20 Go to next message
I've got a Tree widget with a SelectionListener added.
Selection events work fine when navigating via keyboard arrows is mouse clicks.
However, clicking the collapse icon on a parent node of a selected node changes the visual selection to the parent but no selection event is fired.
Is this normal behaviour?
Also, there is a section about four pixels between the node text and node image where clicking will not select the node.
Re: Tree collapse selection change not firing Selection listener [message #1449262 is a reply to message #1449211] Tue, 21 October 2014 01:20 Go to previous messageGo to next message
which RAP version are you using? Is it reproducible with RAP 3.0M2?
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Tree collapse selection change not firing Selection listener [message #1449746 is a reply to message #1449262] Tue, 21 October 2014 15:50 Go to previous message
Version 2.3.1
I can reproduce it in 3.0.0-M2
public class BasicEntryPoint extends AbstractEntryPoint {
    protected void createContents(Composite parent) {
        final Tree tree = new Tree(parent, SWT.BORDER);
        TreeItem item1 = new TreeItem(tree, SWT.NONE);
        item1.setText("Item 1");
        TreeItem item2 = new TreeItem(item1, SWT.NONE);
        item2.setText("Item 2");
        tree.addListener(SWT.Selection, new Listener() {
			public void handleEvent(Event event) {
				System.out.println("Selection event " + event.item);
        tree.setLayoutData(new GridData(150, 150));
        Button button = new Button(parent, SWT.PUSH);
        button.setText("Print Selection");
        button.addListener(SWT.Selection, new Listener() {
				System.out.println("Tree selection: " + Arrays.toString(tree.getSelection()));
I would expect when Item 2 is selected and the collapse icon for Item 1 is clicked, resulting in the visible selection of Item 1, a selection event would be fired.
Request when clicking collapse icon:
{"head":{"requestCounter":4},"operations":[["set","w3",{"focusItem":"w6"}],["set","w6",{"expanded":false}],["notify","w3","Collapse",{"item":"w6"}],["set","w1",{"cursorLocation":[13,22]}]]}
Request when clicking Item 1:
{"head":{"requestCounter":5},"operations":[["set","w3",{"selection":["w6"]}],["notify","w3","Selection",{"item":"w6","button":1,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w3",{"focusItem":"w6"}],["set","w1",{"cursorLocation":[41,22]}]]}
w3 = Tree widget
w6 = Item 1
w7 = Item 2
The server side does return the correct selection when you call Tree#getSelection()
I think either the JS client needs to include a ["set","w3",{"selection":["w6"]}] and a notify Selection or the server-side needs to fire the selection event when it changes the selection with the set "focusItem".
Previous Topic:Native browser scrolling without Scrolling Composites in RAP
Next Topic:RAP E4 RWT Theming
Current Time: Sat Jul 19 09:03:30 EDT 2025
Powered by FUDForum. Page generated in 0.36372 seconds
