Home » Modeling » EMF » [CDO] is it abandoned? what is alternative?
[CDO] is it abandoned? what is alternative? [message #1444026] Mon, 13 October 2014 10:51 Go to next message
I am doing some pre study for developing EMF based multiuser application facilitating collaboration.
CDO and EMF store came as two candiates. I liked CDO as it offers database persistance. EMF Store is also good but it offers file persistance which might be problematic when data size increases and we need to make sure our application can handle really big models...
I just came across to one of the thread (https://www.eclipse.org/forums/index.php/t/826480/) saying CDO is already abandoned..... is it true? Should i drop the idea of using CDO? Is Teneo offers a good replacement for CDO? Does Teneo also supports collaboration and transactions?
thanks!
[Updated on: Mon, 13 October 2014 11:25] by Moderator
Re: [CDO] Multi user collaborations [message #1444558 is a reply to message #1444026] Tue, 14 October 2014 04:29 Go to previous messageGo to next message
Am 13.10.2014 um 16:51 schrieb ModelGeek Mising name:
Then CDO is probably the best fit.
> abondoned..... is it true?
That thread didn't say that CDO is abandoned. David was frustrated because his CDO-based application didn't work as he
expected and couldn't find someone who was willing to solve his problem in four hours. So he felt compelled to tell the
world why *he* abandoned CDO.
Of course the CDO project is not terminated and won't be terminated. A great many companies use it successfully.
Cheers
/Eike
http://www.esc-net.de
> thanks!
Re: [CDO] Multi user collaborations [message #1444636 is a reply to message #1444558] Tue, 14 October 2014 06:41 Go to previous messageGo to next message
thanks for the clarification.
Cheers
Re: [CDO] Multi user collaborations [message #1446176 is a reply to message #1444636] Thu, 16 October 2014 09:08 Go to previous messageGo to next message
I agree with Eike. It is a problem that is either how we use CDO or maybe something else.
But to say we expected the problem to be solved in 4 hours is incorrect. I asked if Eike could at least look at our corrupted repositories, frankly it would take an hour to look at them and someone with deep knowledge of CDO will probably quickly realise what is wrong. You only need to use the standard CDO Explorer view that comes with the CDO plugins to try to export the repository and it clearly shows the corruption, it will fail. Inspecting that then might give a clue to how we recover them and even possibly how they get into that state. Our experience has been that CDO works well most of the time and then at random, saving the same class types as many times successfully previously, using exactly the same code it corrupts the repository. We have no idea why and various test cases where we effectively copy the entire repository pass. Clearly a difficult problem to solve. Eike admitted himself that he is very busy, he has to make a living after all.
Regarding the drop off of commits, I did not make it up, - http://git.eclipse.org/c/cdo/cdo.git/stats/?period=q&ofs=10
You make your own decision.
David
Re: [CDO] Multi user collaborations [message #1446202 is a reply to message #1446176] Thu, 16 October 2014 09:43 Go to previous messageGo to next message
So David, did you know completely abandon CDO, or would you give it
another try if your problem was addressed? The reason I ask, is I have
been CDO for several years and at some point we had corruption issues,
which we reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396743
Both Eike and Stefan went through a great deal of trouble, to
solve the problem, which they did in the end.
I don't want to speak for Eike, but what I gather is that there is a bit
of disappointment, that the community hasn't been more active to
document, promote, patch and whatever else CDO. (Mea culpa here).
It's a great technology, but also very complex and simply diving-in is
not a trivial task. It requires a lot of time to understand the code,
hence perhaps the reason people are hesitant. I remember one comment
stating "Massively intimidating", which says it all.
What I know for sure though, is that Eike has been very responsive on
questions on the forum, Skype and email..So he certainly can't be blamed
for not being responsive from my experience.
> David
Re: [CDO] Multi user collaborations [message #1449423 is a reply to message #1446202] Tue, 21 October 2014 06:28 Go to previous messageGo to next message
At this stage I still have 3 broken repos with hundreds of hours design work in them, so yes I'd like to solve this issue. We modified the CDO code to skip over the model objects that had this
> java.lang.ClassCastException: org.eclipse.emf.cdo.common.revision.CDORevisionUtil$uninitialized cannot be cast to
> org.eclipse.emf.cdo.common.id.CDOID
> org.eclipse.net4j.signal.RemoteException: java.lang.ClassCastException:
> org.eclipse.emf.cdo.common.revision.CDORevisionUtil$uninitialized cannot be cast to org.eclipse.emf.cdo.common.id.CDOID
and saved to xmi files.
But when we try to reimport and commit those xmi files using the std CDO Explorer view we get this
The object "SubstitutionField[TRANSIENT](org.eclipse.emf.internal.cdo.object.DynamicCDOObjectImpl)" is not contained in a resource
Eike had thought our model design might have been a problem. For all our design classes we subclass an Abstract class called BaseModel which has one EAttribute, a class called UUID which has 2 EAttribute values lsb and msb. In fact I found that about 32 of these UUID in one corrupted repo had a CDO_VERSION of -2 when the class instances that reference them had not been 'deleted'. But removing these from the H2 repo did not fix the repository. If I ever recover these repos I can change the ecore to include the lsb and msb EAttributes from UUID class in BaseModel directly making it concrete, if that is what causes our issue, who knows, and then change the H2 repo like so
ALTER TABLE "REPO_20140827"."PUBLIC".SUBSTITUTIONFIELD ADD "LSB" bigint NULL ;
ALTER TABLE "REPO_20140827"."PUBLIC".SUBSTITUTIONFIELD ADD "MSB" bigint NULL ;
UPDATE SUBSTITUTIONFIELD  SET LSB = (SELECT LSB FROM UUID WHERE SUBSTITUTIONFIELD.UUID = UUID.CDO_ID);
UPDATE SUBSTITUTIONFIELD SET MSB = (SELECT MSB FROM UUID WHERE SUBSTITUTIONFIELD.UUID = UUID.CDO_ID);
ALTER TABLE SUBSTITUTIONFIELD DROP COLUMN "UUID" ;
Frankly we are in the dark and hacking like mad to try to recover the situation.
If you want to spend 15 minutes to open a corrupt repo in the CDO Explorer view then drop me an email to stpdave on the gmail domain.
All you have to do is open a repo and try to export, boom.
David
Re: [CDO] Multi user collaborations [message #1449529 is a reply to message #1449423] Tue, 21 October 2014 09:50 Go to previous messageGo to next message
I discovered something just now. As above we managed to export to xmi from a corrupt repository by skipping the java.lang.ClassCastException: org.eclipse.emf.cdo.common.revision.CDORevisionUtil$uninitialized
The resultant xmi file is Imported into a empty CDO repo with the Package Registry loaded for the model edmmodel and opened in the Eclipse Text editor.
We get this, clearly were the problem lies.
  <model:MappingSubstitution xmi:id="t40167" substitutionFields="NNULL" name="Mapping BBG COLLAT_TYPE to collateraltype">
    <uuid xmi:id="t40168" lsb="-6140311635292653201" msb="9063455697632575823"/>
Note the NNULL
This is the equivalent input xmi element
  <edmmodel:MappingSubstitution name="Mapping BBG COLLAT_TYPE to collateraltype">
    <uuid lsb="-6140311635292653201" msb="9063455697632575823"/>
    <substitutionFields inputField="/936/@containedField.14" outputField="/1186/@containedField.0">
      <uuid lsb="-8198965334738203190" msb="-2815692950055403294"/>
    </substitutionFields>
This suggests the /936 offset to the related object of Class TransformationNodePort is incorrect?
No idea how to fix this though, a weakness of the offset notation used is you cannot easily find the reference objects, much better to use something like the href.
Re: [CDO] Multi user collaborations [message #1449532 is a reply to message #1449423] Tue, 21 October 2014 09:50 Go to previous messageGo to next message
The resultant xmi file is Imported into a empty CDO repo and opened in a Text editor
Note the NNULL
Re: [CDO] Multi user collaborations [message #1449533 is a reply to message #1449423] Tue, 21 October 2014 09:54 Go to previous messageGo to next message
Note the NNULL
Re: [CDO] Multi user collaborations [message #1449534 is a reply to message #1449423] Tue, 21 October 2014 09:54 Go to previous messageGo to next message
Note the NNULL
Re: [CDO] Multi user collaborations [message #1449535 is a reply to message #1449423] Tue, 21 October 2014 09:54 Go to previous messageGo to next message
Note the NNULL
Re: [CDO] Multi user collaborations [message #1449538 is a reply to message #1449423] Tue, 21 October 2014 09:56 Go to previous messageGo to next message
  </model:MappingSubstitution>
Note the NNULL
  </edmmodel>
Re: [CDO] Multi user collaborations [message #1449539 is a reply to message #1449423] Tue, 21 October 2014 09:58 Go to previous messageGo to next message
Note the NNULL
  </edmmodel>
Re: [CDO] Multi user collaborations [message #1449540 is a reply to message #1449423] Tue, 21 October 2014 09:59 Go to previous messageGo to next message
The forum will not take the content of the attached file as a post
Re: [CDO] Multi user collaborations [message #1449543 is a reply to message #1449423] Tue, 21 October 2014 10:00 Go to previous messageGo to next message
Note the NNULL
  </edmmodel>
Re: [CDO] Multi user collaborations [message #1449626 is a reply to message #1449543] Tue, 21 October 2014 12:27 Go to previous message
Am 21.10.2014 um 16:00 schrieb David Wynter:
The first XMI snippet below looks strange because it suggests that the containment reference (?) "substitutionFields" is
stored as an attribute. How exactly did you create this file?
How did you manage to skip exceptions during the export?
How does this import operation relate to the XMI snippet you show below and a text editor? Do you mean you open the
exported file in a text editor?
Do you register your namespace under multiple nsPrefixes? Here it's "model", beloe it's "edmmodel".
As mentioned above, the fact that "substitutionFields" is serialized as an attribute looks suspicious in the first
place. The value "NNULL", too. Both can not be understood without knowing how exactly this file has been created.
> Note the NNULL
> </edmmodel>
Where is this suggestion? I don't understand what you imply with this sentence/question. But the containment reference
vs attribute question seems more fundamental.
This fragment path notation is under your control (but I'm not an XML expert). If you assign XMI IDs to your resource's
root objects they should also be used in serialized references to those objects.
Cheers
/Eike
Previous Topic:[CDO] Persisting CDORevisionCache to filesystem to improve user experience
Next Topic:Add duplicated elements to EList
Current Time: Sun Jul 20 08:52:51 EDT 2025
Powered by FUDForum. Page generated in 0.05547 seconds
