Home » Archived » Eclipse Process Manager (Stardust) » Debug fails to start
icon5.gif  Debug fails to start [message #1449117] Mon, 20 October 2014 19:44 Go to next message
I'm trying to debug a process but i get this error : Confused I have Eclipse Process manager v 2.0.1. How can I check my audittrail version
org.eclipse.stardust.common.error.InternalException: : Invalid audittrail version 'null'. Eclipse Process Manager requires a minimum auditrail version '2.0.0'.
	at org.eclipse.stardust.modeling.debug.debugger.Debugger.init(Debugger.java:441)
	at org.eclipse.stardust.modeling.debug.debugger.Debugger.<init>(Debugger.java:165)
	at org.eclipse.stardust.modeling.debug.debugger.Debugger.main(Debugger.java:102)
Caused by: org.eclipse.stardust.common.error.IncompatibleAuditTrailException: Invalid audittrail version 'null'. Eclipse Process Manager requires a minimum auditrail version '2.0.0'.
	at org.eclipse.stardust.engine.core.runtime.beans.ModelManagerBean.getModelManagerPartition(ModelManagerBean.java:348)
	at org.eclipse.stardust.engine.core.runtime.beans.ModelManagerBean.getModelManagerPartition(ModelManagerBean.java:287)
	at org.eclipse.stardust.engine.core.runtime.beans.ModelManagerBean.getRuntimeOid(ModelManagerBean.java:238)
	at org.eclipse.stardust.engine.core.runtime.beans.UserBean.findParticipantLink(UserBean.java:608)
	at org.eclipse.stardust.engine.core.runtime.beans.UserBean.addToParticipants(UserBean.java:569)
	at org.eclipse.stardust.engine.core.runtime.beans.UserBean.addToParticipants(UserBean.java:550)
Re: Debug fails to start [message #1449214 is a reply to message #1449117] Mon, 20 October 2014 23:28 Go to previous messageGo to next message
By the way, here are the steps I took when I encountered the error.
I created a dynamic web project with 1 process model.
On the process development perspective I added a manual activity and assigned a participant.
When I select "debug" in the right-click option menu, Process test perspective opens but the error occurs.
Re: Debug fails to start [message #1449267 is a reply to message #1449214] Tue, 21 October 2014 01:29 Go to previous messageGo to next message
Melissa,
had you create a database in the server tab when you ran the debug?
Actually we still have the debugging feature but nowadays with Stardust's convenient Eclipse WTP integration (and the browser modeler) it is very easy to debug a process in the real (RAD) runtime environment. Hence most people prefer that option. Have you tried?
Best regards
Rob
Re: Debug fails to start [message #1449285 is a reply to message #1449267] Tue, 21 October 2014 02:05 Go to previous messageGo to next message
Hi Rob,
Thanks for the reply. I've set up the audittrail database in my Tomcat server tab.
When I deploy my model on my server it works. I was trying to run it on debug/simulation mode, that's where I encountered the error.
Is there another way to setup the database?
I haven't tried debugging/simulation in the RAD, can you send me the link on that feature?
Re: Debug fails to start [message #1449288 is a reply to message #1449285] Tue, 21 October 2014 02:12 Go to previous messageGo to next message
Melissa,
please see if this helps https://infinity.sungard.com/documentation/stardust/1.0/index.jsp?topic=%2Forg.eclipse.stardust.docs.simulation%2Fhtml%2Fsimulation%2Ftoc.html&resultof=%22simulation%22%20%22simul%22%20
Rob
Re: Debug fails to start [message #1449296 is a reply to message #1449288] Tue, 21 October 2014 02:25 Go to previous messageGo to next message
Hi Rob,
thanks for the link. I'll look into it.
Re: Debug fails to start [message #1450233 is a reply to message #1449296] Wed, 22 October 2014 04:20 Go to previous message
Just a little side note: since Stardust 1.1 we're publishing the documentation into the official Eclipse Help Center (for Luna it is http://help.eclipse.org/luna). This means that the documentation for Stardust 2.0.1 (specially for the simulation feature can be found here: Simulation Feature
Sven
Previous Topic:Stardust offline donwload links no longer working
Next Topic:Adding Custom Activities to Stardust Modeler
Current Time: Sun Jul 20 03:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.04169 seconds
