Home » Language IDEs » Java Development Tools (JDT) » Debugger "Drop to frame"
Debugger "Drop to frame" [message #143552] Thu, 19 February 2004 14:56 Go to next message
Originally posted by: dlwester.us.ibm.com
In VisualAge for Java, there was a debugging feature "drop to frame",
which allowed you to restart execution at a higher level in the stack,
for instance, to call the same method you are in again, possibly after
changing some parameters or variables. Is there any similar
functionality in Eclipse?
Thanks!
DLW
Re: Debugger "Drop to frame" [message #143589 is a reply to message #143552] Thu, 19 February 2004 16:20 Go to previous messageGo to next message
Yes. It is called "Drop to Frame" :-)
You select the stack frame you are interested in, right click>Drop To Frame
It requires a VM that supports this feature.
Full details are at:
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. jdt.doc.user/reference/ref-51.htm
HTH
Darins
"Dave Westerman" <dlwester@us.ibm.com> wrote in message
news:c13472$n2m$1@eclipse.org...
> Thanks!
> DLW
Re: Debugger "Drop to frame" [message #143611 is a reply to message #143589] Thu, 19 February 2004 16:45 Go to previous messageGo to next message
Gee, how'd they come up with THAT name?!? ;-) Thanks a bunch Darin! I am
actually using WSAD 5.1.1, and this feature does not show up. So I guess
that means that the JDK 1.4.1 that is supplied with WSAD doesn't support it.
DLW
Re: Debugger "Drop to frame" [message #143618 is a reply to message #143611] Thu, 19 February 2004 16:56 Go to previous messageGo to next message
Correct.
If the VM responds negatively to our requests for its level of support, we
do not show the action.
Darins
news:c13ak9$uso$1@eclipse.org...
it.
> DLW
Re: Debugger "Drop to frame" [message #144131 is a reply to message #143618] Fri, 20 February 2004 16:29 Go to previous messageGo to next message
I actually can get "drop to frame" to work for a simple Java program, so
the JVM definitely supports it. But I can't get it to appear on my menu
for any of my J2EE applications running in the WAS 5.1 WTE.
Re: Debugger "Drop to frame" [message #144880 is a reply to message #144131] Tue, 24 February 2004 05:45 Go to previous message
Originally posted by: thomas_maeder.ch.ibm.com
"drop to frame" does not work when the drop goes to or across a native
frame (due to the way the operation is spec'ed). For example, you can't
drop a program's main method, since it is called from native code.
Thomas
Previous Topic:Bug in Eclipse? multiple class definitions in one java file
Next Topic:Images and Plugins
Current Time: Sat Jul 19 17:13:59 EDT 2025
Powered by FUDForum. Page generated in 0.04797 seconds
