Home » Archived » EMF-IncQuery » Incquery & Xtext
Incquery & Xtext [message #1446768] Fri, 17 October 2014 05:21 Go to next message
Is that possible to have an IncQuery based on Xtext 2.7.x ?? When do you
think you will move to Xtext 2.7 ??
Ali
Re: Incquery & Xtext [message #1447678 is a reply to message #1446768] Sat, 18 October 2014 14:26 Go to previous messageGo to next message
Hi Ali,
as of now, we have no working build of EMF-IncQuery with Xtext 2.7. We are working on fixing the issue, but are a bit preoccupied with other problems. I cannot give a date for Xtext 2.7 compatibility.
Sorry for the inconvenience,
Zoltán
Re: Incquery & Xtext [message #1461344 is a reply to message #1447678] Tue, 04 November 2014 08:10 Go to previous messageGo to next message
Hi Zoltan,
As I can see on the following wiki page,
https://wiki.eclipse.org/EMFIncQuery/UserDocumentation/GettingStarted,
EMF-IncQuery 0.8 Runtime can be used with Xtext 2.7
When I use the EMF-IncQuery update site, i.e.
http://download.eclipse.org/incquery/updates/release, I can't find any
feature which only include the runtime.
Can you provide such kind of feature ??
Le 18/10/2014 20:26, Zoltan Ujhelyi a écrit :
> Hi Ali,
> Zoltán
Re: Incquery & Xtext [message #1461387 is a reply to message #1461344] Tue, 04 November 2014 09:03 Go to previous messageGo to next message
the corresponding feature is available on the update site, it is just hidden by default. If you want install the EMF-IncQuery runtime feature, enter the update site, and uncheck the 'Group items by category' box below the list, and then select EMF-IncQuery Runtime to install.
By default we are hiding this option, as if you are checking both the runtime and tooling plug-ins to install, they have to be selected together to get an update, which is quite hard to figure out.
Sorry for the confusion,
Zoltán
Re: Incquery & Xtext [message #1461428 is a reply to message #1461387] Tue, 04 November 2014 09:55 Go to previous messageGo to next message
Hi Zoltan,
I use now org.eclipse.incquery.runtime.feature.feature.group.
I have now one runtime target and one development target until we get
IncQuery SDK on xtext 2.7
Thank you,
Ali
Le 04/11/2014 15:03, Zoltan Ujhelyi a écrit :
> Zoltán
Re: Incquery & Xtext [message #1565501 is a reply to message #1461428] Thu, 15 January 2015 05:09 Go to previous message
just to report back: current EMF-Incquery integration builds are working with Xtext 2.7, and we have a release 0.9.0 planned on the 1st February that will include this fix.
Zoltán
Previous Topic:Get notified when index is ready
Next Topic:Performance differences Plugin/Java API
Current Time: Sun Jul 20 17:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.04083 seconds
