Home » Modeling » GMF (Graphical Modeling Framework) » Diagram Editor Gen Model(Diagram Editor Gen Model from xsd)
icon8.gif  Diagram Editor Gen Model [message #1444942] Tue, 14 October 2014 15:59 Go to next message
I tried to figure out building an diagram editor gen model from XSD ( XML Scheme ) ( GolfCountryClub.Xsd from the xml examples).
So i tried the following.
Building a new EMF Model from XSD.
Generating edit and editor
Than taking the Dashboard to generate the gmfgen via ecore and genmodel file.
Taking DocumentRoot as Diagram Element. Leaving all the other as default.
Transfer to gmfgen unsing RCP fails with Nullpointer exception.
I have no idea getting that exception away.
Taking another type as Diagram Element, not DocumentRoot?
Changing some switches deriving gmfgraph, gmftool or gmfmap?
eclipse version is Luna Service Release 1 (4.4.1)
Build id: 20140925-1800
Re: Diagram Editor Gen Model [message #1447019 is a reply to message #1444942] Fri, 17 October 2014 13:09 Go to previous message
Normally i think it should be an easy job. Creating an Editor Gen Model from an example xsd, here GolfCountryClub.xsd.
Or is like experienced before when increasing complexity you stumble over some errors in GMF and EMF
Previous Topic:Adding Items to Connection Creation Popup Menu
Next Topic:GMF 3.1, Search for Good Reference
Current Time: Sat Jul 19 05:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.27457 seconds
