Incquery & Xtext [message #1446768] |
Fri, 17 October 2014 05:21  |
Is that possible to have an IncQuery based on Xtext 2.7.x ?? When do you
think you will move to Xtext 2.7 ??
Ali
Re: Incquery & Xtext [message #1461344 is a reply to message #1447678] |
Tue, 04 November 2014 08:10   |
Hi Zoltan,
As I can see on the following wiki page,
https://wiki.eclipse.org/EMFIncQuery/UserDocumentation/GettingStarted,
EMF-IncQuery 0.8 Runtime can be used with Xtext 2.7
When I use the EMF-IncQuery update site, i.e.
http://download.eclipse.org/incquery/updates/release, I can't find any
feature which only include the runtime.
Can you provide such kind of feature ??
Le 18/10/2014 20:26, Zoltan Ujhelyi a écrit :
> Hi Ali,
> as of now, we have no working build of EMF-IncQuery with Xtext 2.7. We
> are working on fixing the issue, but are a bit preoccupied with other
> problems. I cannot give a date for Xtext 2.7 compatibility.
> Sorry for the inconvenience,
> Zoltán
Re: Incquery & Xtext [message #1461387 is a reply to message #1461344] |
Tue, 04 November 2014 09:03   |
the corresponding feature is available on the update site, it is just hidden by default. If you want install the EMF-IncQuery runtime feature, enter the update site, and uncheck the 'Group items by category' box below the list, and then select EMF-IncQuery Runtime to install.
By default we are hiding this option, as if you are checking both the runtime and tooling plug-ins to install, they have to be selected together to get an update, which is quite hard to figure out.
Sorry for the confusion,
Zoltán
Re: Incquery & Xtext [message #1461428 is a reply to message #1461387] |
Tue, 04 November 2014 09:55   |
Hi Zoltan,
I use now org.eclipse.incquery.runtime.feature.feature.group.
I have now one runtime target and one development target until we get
IncQuery SDK on xtext 2.7
Thank you,
Ali
Le 04/11/2014 15:03, Zoltan Ujhelyi a écrit :
> Zoltán
FUDForum. Page generated in 0.04853 seconds
