Home » Eclipse Projects » e(fx)clipse » No repository found at http://download.eclipse.org/efxclipse/compiler-released.
No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1443823] Mon, 13 October 2014 04:49 Go to next message
Hello Tom,
I've installed
e(fx)clipse - IDE - Updatesite - http://download.eclipse.org/efxclipse/updates-released/1.0.0/site
via the Eclipse "Install New Software"-function.
Now, when I want do perform "Check for Updates" I get the following error during the update-check-process:
Furthermore, when running the
File -> New -> Other -> JavaFX -> New FXGraph Wizard
I get the following error:
Failed to create injector for org.eclipse.fx.ide.fxgraph.FXGraph ExtensionFactory: org.eclipse.fx.ide.fxgraph.ui.FXGraphExecutableExtensionFactory
Seems, as if the installation went somehow wrong. Do you have any hints?
I have syntax highlighting support for fxml but no edit time error hints.
I was looking for your fxml-compiler, but didn't find a download-link for the 1.0.0-e(fx)clipse version, only for the 0.9.0-version, but I didn't want to mix that with 1.0.0 version, so I didn't install that.
Thanks & Greetings
Thomas
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444000 is a reply to message #1443823] Mon, 13 October 2014 10:19 Go to previous messageGo to next message
On 13.10.14 16:09, Thomas Gawehn wrote:
> Hello Tom,
> I've installed
http://download.eclipse.org/efxclipse/compiler-released is not a p2 repo
so it makes no sense that it is in the update site. I have no idea how
and why this site could have been added to the p2-repos to search for
updates.
> ExtensionFactory:
My wild guess is that this fails because of a mismatch between installed
Xbase you have and the one we require. What's the version of Xtext/Xtend
you have installed?
... the XML-Editor should not be affected by the FXGraph problems it does
not need that at all.
Unfortunately the 1.0.0 release of the compiler is broken - I'm
currently working on that so that at least the nightly compiler stuff is
in shape when we release 1.1.0 so even if I'd provide you the link it
would not be functional :-(
Tom
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444069 is a reply to message #1444000] Mon, 13 October 2014 11:39 Go to previous messageGo to next message
FYI - a sample project with a working fxml-compiler is checked into the
repo at
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/tree/demos/org.eclipse.fx.samples.fxml.compiler
Tom
>> Hello Tom,
>> I've installed
> updates.
>> ExtensionFactory:
> you have installed?
> Tom
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444473 is a reply to message #1444000] Tue, 14 October 2014 01:46 Go to previous messageGo to next message
Tom,
many thanks for your support.
you have installed?
My installed version of Xtext is
Xtext Redistributable
2.7.2.v201409160908
org.eclipse.xtext.redist.feature.group
I've also made a clean new download of Eclipse Luna 4.4.1 and then installed only efxclipse 1.0.0 and the above Xtext-package ...
So FXML-error reporting directly on the FXML-source is not available?
https://www.eclipse.org/efxclipse/fxml_tooling.png
let one suppose it would exist ...
would not be functional Sad
So looking really forward for the 1.1.0-version Wink ... as the compiler will give us a good understanding of using and modeling JavaFX widgets and comparing FXML to JavaFX-classes!
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1444487 is a reply to message #1444473] Tue, 14 October 2014 02:18 Go to previous messageGo to next message
On 14.10.14 07:46, Thomas Gawehn wrote:
> Tom,
> Quote:
>> you have installed?
> 2.7.2.v201409160908
Yeah IIRC 1.0.0 was built against 2.6.1. If you use the latest Xtext you
need to use our nightly build (our nightlies are fairly stable and we
take care to not break things) instead of the 1.0 release.
> Quote:
>> hints.
My comment referred to the FXGraph problem which should not affect
FXML-Editing. We currently only do auto-completion and error reporting
for controler based stuff but you are right we should add error reporting.
If you open the JavaFX Preview you should see errors but that's not as
good as error reporting inside the FXML - please file a bugzilla so that
we can track adding this feature.
> Quote:
>> would not be functional :(
> So looking really forward for the 1.1.0-version ;) ... as the compiler
If you checkout the sample project I pointed to in the other post you
can give it a spin already now.
Tom
Re: No repository found at http://download.eclipse.org/efxclipse/compiler-released. [message #1451021 is a reply to message #1444473] Thu, 23 October 2014 03:56 Go to previous message
The nightly build of the compiler has been restored you can grab the
latest compiler suite from
http://download.eclipse.org/efxclipse/compiler-nightly/org.eclipse.fx.fxml.compiler_1.0.0-SNAPSHOT.jar
Tom
> Tom,
> Quote:
>> you have installed?
> 2.7.2.v201409160908
> Quote:
>> hints.
> Quote:
Previous Topic:Upcoming 1.1.0 release
Next Topic:Locale changes at runtime
Current Time: Sat Jul 19 14:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
