Home » Newcomers » Newcomers » Unable to delete eclipse project(An exception has been caught while processing the refactoring Delete Resource)
Unable to delete eclipse project [message #1443924] Mon, 13 October 2014 08:08 Go to next message
I have using eclipse-jee-kepler-SR2-win32-x86_64.
We have created an eclipse plugin and using this plugin we are creating a java project in eclipse.
Once the project is created, lib folder has few plugin related jars(Example: x,y,z jars).
There are no source files in the project that are using this jars.
Now select this new project and from right click pop up click Delete option.
In "Delete Resources" dialog select "Delete project contents on disk (cannot be undone)" check box
Reason:
Problems encountered while deleting resources
Click OK.
Project does not get deleted and it throws following error message:
An exception has been caught while processing the refactoring Delete Resource(refer the attached file).
Now the lib folder has only one jar(z, rest all jars are deleted) which is being used and this is not allowing to delete the project.
Any clue why it is failing?
regards
Irfan
  • Attachment: Capture.GIF
    (Size: 47.28KB, Downloaded 314 times)
Re: Unable to delete eclipse project [message #1444178 is a reply to message #1443924] Mon, 13 October 2014 15:00 Go to previous messageGo to next message
What's in the popup behind the one that's shown? What was in that lib folder?
Update to Luna SR1 and try it again. You never know.
[Updated on: Mon, 13 October 2014 15:02] by Moderator
Re: Unable to delete eclipse project [message #1444413 is a reply to message #1443924] Mon, 13 October 2014 23:39 Go to previous messageGo to next message
Pop up behind the one is delete resources confirmation dialog(Refer attachment)
Lib folder has plugin related jars.
I will update to Luna SR1 and try the delete project option.
Irfan
Re: Unable to delete eclipse project [message #1444424 is a reply to message #1444413] Tue, 14 October 2014 00:01 Go to previous message
I tried deleting project using eclipse-java-luna-SR1-win32-x86_64 as well, still I am not able to delete project in eclipse.
Irfan
Previous Topic:Start screen missing ?
Next Topic:Error when installing on 64 bit Ubuntu 14.10
Current Time: Sun Jul 20 09:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.30414 seconds
