Home » Eclipse Projects » RCP Testing Tool » RCPTT : some questions(Some questions for RCPTT evaluation)
RCPTT : some questions [message #1443849] Mon, 13 October 2014 05:35 Go to next message
I have some questions about RCPTT :
question1:
Which version of Eclipse as AUT are supported by RCPTT ? and which are not ?
question2:
Which UI components are supported ? draw2d , GEF ....
question3:
For image comparasion is there a way to do it ?
question4:
Is there a command line to launch RCPTT tests ?
question5:
How to set parameters or varibales to be used by RCPTT scripts ?
question6:
What platforms are supported by RCPTT ? (windows , Linux (which versions ?) ..
question7:
How to set verification points ?
question8:
Does generated reports contain all information about assertion and verification points and their status.
question9:
Is there a way to continue in launching RCPTT tests and ignoring produced failures.
question10:
Is there a full documentation ? (ECL and RCPTT commands included)
Thanks in advance,
Maherzia
Re: RCPTT : some questions [message #1443875 is a reply to message #1443849] Mon, 13 October 2014 06:25 Go to previous messageGo to next message
Hello Maherzia,
I discovered recently RCPTT. I can say this:
question5:
You can read the guide for parameters. For parameters, you to have create a parameter. You can also use the command "let".
question7:
I use the command verify-true
question9:
It's the the normal functioning. RCPTT don't stop on a error, It's execute the Suite test complete.
question10:
You can read the user guide. And for the commands in details, I use this link. RCPTT from project q7 (without continous integration). It's more easy to find documentation on q7.
[Updated on: Mon, 13 October 2014 06:33] by Moderator
Re: RCPTT : some questions [message #1443896 is a reply to message #1443849] Mon, 13 October 2014 07:12 Go to previous messageGo to next message
Hello!
Thanks for contacting us!
1. RCPTT doesn't support E4 RCPs without 3.x compatibility layer (If AUT contains org.eclipse.ui.workbench plugin, then RCPTT supports it.).
2. RCPTT supports draw2d, GEF, GMF, Nebula Tables
3. No. There is no way for image comparison.
4. RCPTT is a testing tool that allows you to design tests and run them manually. There is commercial product Continuous Integration for RCPTT by Xored (http://ci.xored.com/) or you can use solutions from other vendors.
5. About variables and parameters you can read in User Guide (Variables and parameters)
6. RCPTT supports platforms which are supported by Eclipse.
7.This functionality is discribed here (verifications) and here (assertions) in User Guide.
8. Yes. Reports contain all information about assertion and verification points and their status.
9. If one test fails, RCPTT continue launching other tests. Contexts make tests independent, so one failure doesn't affect launching other tests.
10. You can find RCPTT documentation here and discription of ECL commands there.
Re: RCPTT : some questions [message #1443987 is a reply to message #1443896] Mon, 13 October 2014 10:04 Go to previous messageGo to next message
Thanks a lot Frabcis and Olga for your quick answers.
An other question, If I want to modify or to add some actions/verification points to my test script. Could I record from a specific AUT status ?
Is there the possibility to insert data into an existing script without replaying it.
This option is so helpfull for tests maintenance.
Re: RCPTT : some questions [message #1444045 is a reply to message #1443987] Mon, 13 October 2014 11:11 Go to previous messageGo to next message
We intentionally replay already recorded snippet when you click 'Record' in existing test case to make sure that a script is consistent. If you need to manually record something and place it in a suitable place of existing test case, you can use 'Record a Snippet' (https://www.eclipse.org/rcptt/documentation/img/ui-snippet.png) button on RCPTT IDE toolbar. This button immediately starts recording of an unnamed test case without any contexts, so that you can record actions and just cut-n-paste resulting script
Re: RCPTT : some questions [message #1444606 is a reply to message #1444045] Tue, 14 October 2014 06:00 Go to previous messageGo to next message
A very good option thanks !
An other question, I want to properly close my AUT at the end of the test. How could I do it ?
Re: RCPTT : some questions [message #1709656 is a reply to message #1444606] Wed, 30 September 2015 02:47 Go to previous messageGo to next message
Hi Maherzia,
If you run your tests in a continuous integration RCPTT Runner will close AUT automatically after all tests are passed.
Any other ways like closing AUT in a particular test are not supported.
Kind regards,
Ulyana.
Re: RCPTT : some questions [message #1759107 is a reply to message #1709656] Thu, 06 April 2017 10:00 Go to previous messageGo to next message
Hi Guys,
Is it possible to run more than 1 instance of RCPTT to execute 2 test suite simultaneously? Thanks.
Re: RCPTT : some questions [message #1799978 is a reply to message #1443875] Tue, 18 December 2018 05:08 Go to previous messageGo to next message
I know this discussion is old, but I just started using the tool and have problems with it. First I didn't understand why after each test, the AUT is not stopped and launched again, but I found a workaround for this and it's ok now. However, after failure the suite just stops. I used all kinds of contexts and nothing works. Please, help!
Re: RCPTT : some questions [message #1800280 is a reply to message #1799978] Sun, 23 December 2018 05:28 Go to previous messageGo to next message
Maria Barova wrote on Tue, 18 December 2018 11:08
I know this discussion is old, but I just started using the tool and have problems with it. ... However, after failure the suite just stops. ...
Hello Maria!
If you have a question, then please start a new thread instead of posting in an old thread! That way the answers will be easer to find in the future.
(I am also interested in how a test suite can be made to continue with the nest test after a failire!)
Re: RCPTT : some questions [message #1801669 is a reply to message #1799978] Thu, 24 January 2019 08:35 Go to previous message
Maria Barova wrote on Tue, 18 December 2018 05:08
Please disable Stop on First failure mode in Execution view.
index.php/fa/34719/0/
Previous Topic:NatTable
Next Topic:Unable to restart my AUT (Elexis)
Current Time: Sat Jul 19 15:58:45 EDT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
