Re: An inrernal errooccurred during:"Launching" ,when i was debugging... [message #145528 is a reply to message #144283] |
Tue, 17 May 2005 10:03  |
I get same error using eclipse 3.1m6 it should be compatible:
April 15, 2005 - CDT 3.0 - M6 - NOW AVAILABLE! -- this is the latest
milestone build in the CDT 3.0 series. This build runs against Eclipse
3.1 M6 (thus the same milestone name :). This build as well as our
weekly 3.0 builds can be found on our 3.0 Build Site.
the error is:
java.lang.NoClassDefFoundError:
org/eclipse/debug/core/model/IMemoryBlockRetrievalExtension
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:312)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:295)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:176)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:221)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:135)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:59)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:331)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:94)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.<init >(CDebugTarget.java:235)
at org.eclipse.cdt.debug.core.CDIDebugModel$1.run(CDIDebugModel .java:96)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1702)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1722)
at
org.eclipse.cdt.debug.core.CDIDebugModel.newDebugTarget(CDID ebugModel.java:107)
at
org.eclipse.cdt.launch.internal.LocalRunLaunchDelegate.launc h(LocalRunLaunchDelegate.java:102)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:795)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:993)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
any hint?
thanks,
Luca
rekinyz wrote:
> be solved!
> because i was using eclipse3.1 + cdt3.0
FUDForum. Page generated in 0.04087 seconds
