Home » Language IDEs » ServerTools (WTP) » [One for Tim DeBoer?] can't do derived project since removal of .deployables
[One for Tim DeBoer?] can't do derived project since removal of .deployables [message #144183] Mon, 17 October 2005 12:50 Go to next message
I recently upgraded to the 7th Oct integration build, and found myself a
big stuck.
Having got used to builds being staged in .deployables, I've got two
projects, and Ant scripts to build them, but most importantly **one of
the builds is derived from the other**.
Since the changes covered in
http://dev.eclipse.org/mhonarc/lists/wtp-dev/msg02620.html, I can no
longer use an Ant script to import JSP and other resources into the
second build (basically we have a "site" build, and we add various pages
to it to give us our "admin" build).
What should I do? Can I have one WTP project dependent on another (I
couldn't do that in 0.7, at least, not that I could work out)?
It would be great if, just the same as having a simple Java project
dependent on another, we could have a Web Project depend on another, and
be able to "Run On Server..." such that the resource of both are
combined (obviously with web.xml from the second taking priority).
I had this all working, and it now looks that post 1.0M8, I'm well and
truly stuck.
Any suggestions?
Neale Upstone
Re: [One for Tim DeBoer?] can't do derived project since removal of .deployables [message #144193 is a reply to message #144183] Mon, 17 October 2005 13:33 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <dj0kop$op$1@news.eclipse.org>, neale@nealeupstone.com
says...
I do this, with the "outer" project being deployed in a .war, and the
other one a library .jar project. Works fine. If yours is arranged a
bit differently, it might be tougher. Check the properties of the
bigger project; there is a place to specify that it depends on another
project.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: [One for Tim DeBoer?] can't do derived project since removal of .deployables [message #144202 is a reply to message #144193] Mon, 17 October 2005 13:41 Go to previous messageGo to next message
So does that mean both of your projects are web projects ?
I can't see how that's going to merge two sets of JSP files
Neale
> says...
> project.
Re: [One for Tim DeBoer?] can't do derived project since removal of .deployables [message #144211 is a reply to message #144202] Mon, 17 October 2005 13:54 Go to previous message
No, one (the .war) is a "Dynamic Web Project", and the other is deployed
as a jar from the "Other Projects" section.
In article <dj0nng$6pf$1@news.eclipse.org>, neale@nealeupstone.com
says...
> Cheers,
> Neale
> > says...
> > project.
Previous Topic:WTP and Tomcat. embedded vs stand-alone
Next Topic:How to consume JSPs, css, images from different module?
Current Time: Sat Jul 19 14:57:29 EDT 2025
Powered by FUDForum. Page generated in 0.06408 seconds
