Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Forms] Stable version for experiment(combination of versions: Java, EMF Forms, eclipse modeling project etc.)
[EMF Forms] Stable version for experiment [message #1441305] |
Thu, 09 October 2014 10:39  |
I am revisiting EMF Forms and having some difficulty in IDE setup. Could anybody share thought on [relatively] stable combination of versions for
- Java (8, 7, 6?)
- EMF Forms (1.2, 1.3, 1.4?)
- Eclipse Modeling Project package (Luna SR1?, Luna v1, Kepler SR2, ... ) ?
At this stage, I am just interested in basic functionalities without errors in console. BTW, I am working on Mac.
Thank you for any help in advance.
Akira
Re: [EMF Forms] Stable version for experiment [message #1441866 is a reply to message #1441305] |
Fri, 10 October 2014 05:36   |
what are the problem with your IDE set-up? Could you describe that more
in detail?
Have you followed this:
http://eclipsesource.com/blogs/tutorials/getting-started-with-EMF-Forms/
Java Version does not really matter. Please always use the latest
version, Luna SR1 (already contains 1.4.0). In the meantime 1.4.1 is
available so you can update Luna SR1 with 1.4.1 of EMF Forms
Best regards
Jonas
Am 09.10.2014 16:39, schrieb Akira Tanaka:
> Hello,
> versions for
> - Java (8, 7, 6?)
> Akira
Re: [EMF Forms] Stable version for experiment [message #1442029 is a reply to message #1441866] |
Fri, 10 October 2014 10:19   |
Hello Jonas,
Thank you for the response. I tried again to fresh install everything, and it works now. Thank you very much. I can proceed with this setup. However, just in case, I tried yesterday's setup, I get error messages when launching run configuration. Other modeling components like Acceleo might have impact(?).
!SESSION 2014-10-10 22:36:34.470 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_51
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=ja_JP
Framework arguments: -application org.eclipse.emf.ecp.application.e3.application
Command-line arguments: -application org.eclipse.emf.ecp.application.e3.application -data /Users/atanaka/Desktop/Luna/Modeling/workspace-acceleo/../runtime-EclipseApplication -dev file:/Users/atanaka/Desktop/Luna/Modeling/workspace-acceleo/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog
!ENTRY org.eclipse.amalgam.discovery.modeling 4 0 2014-10-10 22:36:35.721
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.amalgam.discovery.modeling [83]
Unresolved requirement: Require-Bundle: org.eclipse.amalgam.discovery.ui; bundle-version="1.0.0"
-> Bundle-SymbolicName: org.eclipse.amalgam.discovery.ui; bundle-version="1.5.0.201404290822"; singleton:="true"
org.eclipse.amalgam.discovery.ui [84]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.p2.ui
-> Bundle-SymbolicName: org.eclipse.equinox.p2.ui; bundle-version="2.3.0.v20140404-1657"; singleton:="true"
org.eclipse.equinox.p2.ui [442]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.director
-> Export-Package: org.eclipse.equinox.internal.p2.director; bundle-version="2.3.100.v20140224-1921"; bundle-symbolic-name="org.eclipse.equinox.p2.director"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.operations, org.eclipse.equinox.p2.repository.tools, org.eclipse.pde.core, org.eclipse.equinox.p2.reconciler.dropins, org.eclipse.equinox.p2.ui, org.eclipse.equinox.p2.director.app"
org.eclipse.equinox.p2.director [421]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.provisional.configurator
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.amalgam.discovery.ui 4 0 2014-10-10 22:36:35.724
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.amalgam.discovery.ui [84]
!ENTRY org.eclipse.ant.launching 4 0 2014-10-10 22:36:35.728
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ant.launching [86]
Unresolved requirement: Require-Bundle: org.eclipse.debug.core; bundle-version="[3.9.0,4.0.0)"
!ENTRY org.eclipse.ant.ui 4 0 2014-10-10 22:36:35.734
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ant.ui [87]
Unresolved requirement: Require-Bundle: org.eclipse.ui.externaltools; bundle-version="[3.2.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.externaltools; bundle-version="3.2.300.v20140327-1949"; singleton:="true"
org.eclipse.ui.externaltools [1136]
Above are just several beginning entries.
Thank you again for your help.
Akira
Re: [EMF Forms] Stable version for experiment [message #1443754 is a reply to message #1442029] |
Mon, 13 October 2014 03:07  |
the error messages mean, that other components (non-ecp) could not be
resolved. Did you create the run config as described in the tutorial?
Best regards
Jonas
Am 10.10.2014 16:19, schrieb Akira Tanaka:
> Hello Jonas,
> java.vendor=Oracle Corporation
> -dev
> !STACK 0
> -> Export-Package:
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> org.eclipse.ant.ui
> at
> at
> at
> at
> at
> at
> at
> Akira
Current Time: Sun Jul 20 07:57:16 EDT 2025
Powered by FUDForum. Page generated in 0.03579 seconds
