Home » Modeling » EMF » [EMF] load an XML stream, how to resolve the factory
[EMF] load an XML stream, how to resolve the factory [message #1441277] Thu, 09 October 2014 09:45 Go to next message
I am adding a RESTfull interface to NetXStudio to consume data from
remote ends. I Use the Jersey package to fire the requests. Jersey has
some API to process the result. I get the result in either XML or JSON
in an InputStream.
I am looking for options to load the XML varial in an EMF Resource.
Some ideas:
1 Use Dymanic EMF.
2 Having an EPackage/EFactory for the XML returned and load it in an EMF
Resource.
For the latter, I am a bit puzzle how to let the ResourceSetImpl resolve
the model factory, as there is no URI as such to load from. (What I have
is an inputstream). I haven't played with this extension yet
org.eclipse.emf.ecore.content_parser, but this could work out, still I
don't have a URI for the stream. (Unless I write the content to file,
set the extension and refer it, but that seems the long way home).
Any thoughs/ideas to bind the model factory to a bear InputStream?
Thanks Christophe
Re: [EMF] load an XML stream, how to resolve the factory [message #1441292 is a reply to message #1441277] Thu, 09 October 2014 10:16 Go to previous messageGo to next message
Hi Christophe,
On 09/10/2014 15:45, Christophe Bouhier wrote:
> in an InputStream.
> Some ideas:
> 1 Use Dymanic EMF.
> Resource.
> Thanks Christophe
I don't know what a varial is. Maybe I don't understand well. Can you
not use Resource.load(InputStream, Map)? The factory is derived from the
package is derived from the ns uri found in your stream so that should
just work no?
Re: [EMF] load an XML stream, how to resolve the factory [message #1441296 is a reply to message #1441277] Thu, 09 October 2014 10:21 Go to previous messageGo to next message
Christophe,
Comments below.
On 09/10/2014 3:45 PM, Christophe Bouhier wrote:
> in an InputStream.
> Some ideas:
> 1 Use Dymanic EMF.
EMF can read XML without a model using a resource as created by
org.eclipse.emf.ecore.xmi.impl.GenericXMLResourceFactoryImpl. Of course
with this approach, it's essentially equivalent to DOM.
> EMF Resource.
Is there an XML Schema for it? Do you want to use a generated model?
What kind of processing will you want to do?
> resolve the model factory, as there is no URI as such to load from.
You're talking about loading an Ecore model or loading an instance?
> (What I have is an inputstream).
You can load directly from an input stream using
org.eclipse.emf.ecore.resource.Resource.load(InputStream, Map<?, ?>).
It's always possible to directly create a resource and then load it from
a stream...
I don't think there is enough context to really answer this properly...
> Thanks Christophe
Re: [EMF] load an XML stream, how to resolve the factory [message #1441301 is a reply to message #1441296] Thu, 09 October 2014 10:32 Go to previous messageGo to next message
On 09-10-14 16:21, Ed Merks wrote:
> Christophe,
> Comments below.
>> Hi,
>> in an InputStream.
>> Some ideas:
>> 1 Use Dymanic EMF.
>> EMF Resource.
Yes I have the schema, and I have generated the model code, so I have
the model package and the model factory.
Loading the instance.
Yes, but how will it find the model factory?
> a stream...
>> Thanks Christophe
Re: [EMF] load an XML stream, how to resolve the factory [message #1441318 is a reply to message #1441301] Thu, 09 October 2014 10:58 Go to previous messageGo to next message
The same way it finds it when loading from an xml file. The actual data
source doesn't matter for epackage resolution.
Re: [EMF] load an XML stream, how to resolve the factory [message #1441356 is a reply to message #1441318] Thu, 09 October 2014 12:02 Go to previous messageGo to next message
Yes, in this case the package (nsURI) is not in the returned XML. I get
a PackageNotFoundException.
, so I either need to inject it or what I was hoping for, to force the
Resource or the ResourceSet to use a certain epackage.
something like load(InputStream,EPackage,MAP<?,?> would be nice.
so this use case is about:
Creating a model instance for a given XML input (As InputStream) which
doesn't contain schema information (xmlns), but as the caller I know the
EPackage which could handle this XML. How to do this with EMF?
Re: [EMF] load an XML stream, how to resolve the factory [message #1441377 is a reply to message #1441356] Thu, 09 October 2014 12:42 Go to previous messageGo to next message
Oh.
Maybe if you load using a suitable ExtendedMetadata instance? Or look
XMLHelper.setNoNamespacePackage()? Maybe these two are even related
somehow, I'd check who calls setNoNamespacePackage in EMF runtime and
see if you can exploit that somehow.
Felix
Re: [EMF] load an XML stream, how to resolve the factory [message #1441826 is a reply to message #1441377] Fri, 10 October 2014 04:37 Go to previous messageGo to next message
> Oh.
That's interresting. Looking at the code, I am not seeing, the XMLHelper
be set, so it seems, I need to extend XMLResource.
Something like this co do it perhaps?
final EPackage pkg = ...
XMLResource res = new XMLResourceImpl(){
protected XMLHelper createXMLHelper() {
XMLHelper helper = createXMLHelper();
helper.setNoNamespacePackage(pkg);
return helper;
> Felix
Re: [EMF] load an XML stream, how to resolve the factory [message #1441848 is a reply to message #1441826] Fri, 10 October 2014 05:09 Go to previous messageGo to next message
> @Override
> return helper;
Maybe. But the EMFish way would probably be something among:
ExtendedMetadata myMetadata = new BasicExtendedMetadata();
myMetadata.setPackage(null, myEPackage);
XMLResource.load(myStream,
Collections.singletonMap(XMLResource.OPTION_EXTENDED_METADATA, myMetadata);
Re: [EMF] load an XML stream, how to resolve the factory [message #1441933 is a reply to message #1441848] Fri, 10 October 2014 07:40 Go to previous messageGo to next message
that's not supported. There is an EPackageExtendedMetaData
implementation, but that one is used internally it seems. (As there is
an option to bind a namespace to an EPackage, but in my case there is no
namespace in the XML.
Re: [EMF] load an XML stream, how to resolve the factory [message #1441943 is a reply to message #1441933] Fri, 10 October 2014 07:52 Go to previous messageGo to next message
How about this:
String OPTION_MISSING_PACKAGE_HANDLER = "MISSING_PACKAGE_HANDLER";
Re: [EMF] load an XML stream, how to resolve the factory [message #1441953 is a reply to message #1441943] Fri, 10 October 2014 08:02 Go to previous messageGo to next message
> How about this:
Ah finally this worked:
BasicExtendedMetaData basicExtendedMetaData = new BasicExtendedMetaData() {
public EPackage getPackage(String namespace) {
return package;
// TODO Auto-generated method stub
// return super.getPackage(namespace);
So, it is possible to receive XML which has no package reference, and
load it in a Resource with proper EPackage resolution. cool stuff.
The thing is that, the RESTFull service is described with a so called
..wadl schema, which connects the URI's with HTTP method and associated
..xsd. So to bind the RESTfull URI's to an EMF Entity model, would be to
bind the EMFPackage to a .wandl file. This requires additional
descriptor, but would work in dynamicly resolving EPackages when firing
RESTFull requests, which was my purpose.
Thanks all for your help.
Re: [EMF] load an XML stream, how to resolve the factory [message #1441954 is a reply to message #1441943] Fri, 10 October 2014 08:02 Go to previous messageGo to next message
Christophe,
Given you have a schema and have generated the model, isn't there an
XyzResourceFactoryImpl? You should be using the resource created by
that factory; note now hit configures the right options for handling the
no-namespace package...
> How about this:
Re: [EMF] load an XML stream, how to resolve the factory [message #1441957 is a reply to message #1441954] Fri, 10 October 2014 08:08 Go to previous messageGo to next message
On 10-10-14 14:02, Ed Merks wrote:
> Christophe,
YEs there is!
> that factory;
uh, but I receive the XML data as an InputStream. I don't have a URI to
feed:
public Resource createResource(URI uri) {
Perhaps that's not relevant when calling load(InputStream..)
But more importantly, I want some dynamic resolution of the EPackage,
and the EPackage Global Registry is the central place for this.
hit??
>> How about this:
Re: [EMF] load an XML stream, how to resolve the factory [message #1441966 is a reply to message #1441957] Fri, 10 October 2014 08:20 Go to previous messageGo to next message
Christophe,
Comments below.
>> Christophe,
> YEs there is!
>> that factory;
No, the resource itself receives that.
> I don't have a URI to feed:
> @Override
It's not the only way to create a resource. And besides, you can use
any dummy URI you want, so long as it creates the right type of resource
using the right factory. Then you can all load on that resource.
That should all kick in as normal, but note there can only be one
package per namespace and the no-namespace is treated special because
many people might generate models for no-namespace schemas. But I don't
know what you mean by "dynamic"...
> hit??
You've found the code in the generated XyzResourceFactoryImpl?
Note that you can invoke Generate Test Code to see how the
XyzExample.java uses this...
>>>> is no
>>> How about this:
Re: [EMF] load an XML stream, how to resolve the factory [message #1441993 is a reply to message #1441953] Fri, 10 October 2014 09:12 Go to previous messageGo to next message
> @Override
> return package;
basicExtendedMetadata.setPackage(null, package) doesn't work then?
Re: [EMF] load an XML stream, how to resolve the factory [message #1443742 is a reply to message #1441993] Mon, 13 October 2014 02:43 Go to previous messageGo to next message
>> @Override
>> return package;
There is no public setPackage(..) method.
Re: [EMF] load an XML stream, how to resolve the factory [message #1443767 is a reply to message #1443742] Mon, 13 October 2014 03:25 Go to previous messageGo to next message
Christophe,
Note that the template is like this:
<%if (genPackage.hasExtendedMetaData() &&
!genPackage.hasTargetNamespace()) {%>
extendedMetaData = new
<%=genModel.getImportedName("org.eclipse.emf.ecore.util.BasicExtendedMetaData")%>(new
<%=genModel.getImportedName("org.eclipse.emf.ecore.impl.EPackageRegistryImpl")%>(<%=genModel.getImportedName("org.eclipse.emf.ecore.EPackage")%>.Registry.INSTANCE));
extendedMetaData.putPackage(null,
<%=genPackage.getImportedPackageInterfaceName()%>.eINSTANCE);
I.e., it creates a new BasicExtendedMetaData that uses a new package
registry that delegates to the global package registry and uses the
public API setPackage to register the generated package for the null
namespace in that extended metadata's delegating registry.
I would have thought you had a generated resource factory for this
schema's model and that it would contain this (and that you would just
reuse that)...
>>> @Override
>>> return package;
Re: [EMF] load an XML stream, how to resolve the factory [message #1443788 is a reply to message #1443742] Mon, 13 October 2014 03:57 Go to previous messageGo to next message
>>> @Override
>>> return package;
Oops I meant putPackage()
Re: [EMF] load an XML stream, how to resolve the factory [message #1444603 is a reply to message #1443767] Tue, 14 October 2014 05:52 Go to previous messageGo to next message
On 13-10-14 09:25, Ed Merks wrote:
> Christophe,
> reuse that)
wow, after so many years working with EMF, I didn't know this.
Thanks Ed,Felix, very usefull stuff!
**** XXXResourceFactoryImpl constructor:
extendedMetaData = new BasicExtendedMetaData(new
EPackageRegistryImpl(EPackage.Registry.INSTANCE));
extendedMetaData.putPackage(null, TopologyPackage.eINSTANCE);
>>>> @Override
>>>> return package;
Re: [EMF] load an XML stream, how to resolve the factory [message #1455942 is a reply to message #1444603] Wed, 29 October 2014 18:51 Go to previous message
I faced the same issue you have and I found a quite good solution.
In my case, I would like to load an XML stream where the xmlns is not there but the content in XML matches my metamodel.
To do so, in my XmlResource I have overridden the createXMLLoad method to provide my XMLLoad implementation.
In your own XMLLoad Implementation, you have to override the makeDefaultHandler to provide your own SAXXMLHandler.
In your handler implementation you have to:
- override the handleTopLocations(String prefix, String name) method to store the name which is the name of the tag of the xml root element.
- override the handleMissingPackage method to do what you want from the name you stored in handleTopLocations. In my case based on the name, I retrieve the right EPackage because the uriString is missing due to the fact no xmlns is provided.
That's it,
Stéphane.
Previous Topic:Issue to load XML file provide with Edapt example project
Next Topic:[CDO] uri of repository resource
Current Time: Sat Jul 19 17:10:46 EDT 2025
Powered by FUDForum. Page generated in 0.25854 seconds
