Home » Modeling » EMF » [CDO] Consistency between XMIID and CDOId
[CDO] Consistency between XMIID and CDOId [message #1440334] Wed, 08 October 2014 04:21 Go to next message
Hi everyone,
i'm using CDO and the function to import and export in XMI.
I need to hold the consistency between XMIId and CDOid. For example when i export my model from CDO to XMI i got XMIId for each Eobject. If i export again all XMIID are different for all EObjects.
it's the same for the import.
There is any way to keep the consistency between two exports, and imports ?
Julien
Re: [CDO] Consistency between XMIID and CDOId [message #1440370 is a reply to message #1440334] Wed, 08 October 2014 05:24 Go to previous messageGo to next message
On 08/10/2014 10:21, Julien Siega wrote:
> Hi everyone,
> Thanks
> Julien
I know people who "solved" this by storing the extrinsic IDs in a
separate model in the CDO Repo on import, and then reusing them when
Exporting back to XML.
I think that if you find you have to conserve the IDs, you shouldn't use
them at all but rely on intrinsic model IDs.
Felix
Re: [CDO] Consistency between XMIID and CDOId [message #1440464 is a reply to message #1440370] Wed, 08 October 2014 07:55 Go to previous messageGo to next message
Felix Dorner wrote on Wed, 08 October 2014 09:24
> Hi everyone,
> Thanks
> Julien
Felix
Thanks for the tips, Is it a correspondence table between XMIId and CDOid ?
Is it possible to override the generation of CDOId with my own id ? I have the idea to try to use XMIId inside CDO.
Re: [CDO] Consistency between XMIID and CDOId [message #1440507 is a reply to message #1440464] Wed, 08 October 2014 08:57 Go to previous messageGo to next message
>> > Hi everyone,
>> when
>> imports ?
>> > Thanks
>> > Julien
>> use them at all but rely on intrinsic model IDs.
>> Felix
> CDOid ?
I don't remember exactly, I think they mapped XMI Id to the Object itself.
That's what I always wondered, but I don't know how CDOIds work. It
didn't seem feasible for some reason.
Re: [CDO] Consistency between XMIID and CDOId [message #1440625 is a reply to message #1440464] Wed, 08 October 2014 12:13 Go to previous messageGo to next message
Am 08.10.2014 um 13:55 schrieb Julien Siega:
>> > Hi everyone,
>> > Thanks
>> > Julien
>> I know people who "solved" this by storing the extrinsic IDs in a separate model in the CDO Repo on import, and then
>> reusing them when Exporting back to XML.
>> I think that if you find you have to conserve the IDs, you shouldn't use them at all but rely on intrinsic model IDs.
>> Felix
You can configure the server (before first start!) to let the clients generate UUIDs instead of the deault
server-generated long IDs:
In your cdo-server.xml set:
<property name="idGenerationLocation" value="CLIENT"/> <!-- Possible values: STORE | CLIENT -->
Then cdoID() will return a client-assigned UUID, which will also be stored in the cdo_id columns in the DB.
With CLIENT-assigned IDs you can plug your own CDOIDGenerator into the CDOSession:
org.eclipse.emf.cdo.session.CDOSessionConfiguration.setIDGenerator(CDOIDGenerator)
We could also enhance the CDOTransfer framework (assuming that's what you're using to export/import) to save target
XMLResources with xmi:id=CDOID.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Consistency between XMIID and CDOId [message #1441231 is a reply to message #1440625] Thu, 09 October 2014 08:30 Go to previous messageGo to next message
Thanks Eike,
I will try to do it inside the CDO transfert framework, do you have any entry point ? (it's not easy to find tutorial on CDOTransfert Smile )
Re: [CDO] Consistency between XMIID and CDOId [message #1441271 is a reply to message #1441231] Thu, 09 October 2014 09:36 Go to previous messageGo to next message
Am 09.10.2014 um 14:30 schrieb Julien Siega:
> Thanks Eike,
> on CDOTransfert :) )
I would try to do it in CDOTransfer.ModelTransferContext.perform() after the copier.copyAll(). Note that you don't have
access to CDO (IDs) on this generic level. You'll have to add some method to CDOTransferSystem so that CDOTransferSystem
can provide the needed IDs. If you make all that nice and reusable I'd be happy to consider it as a contribution to CDO.
Cheers
/Eike
Re: [CDO] Consistency between XMIID and CDOId [message #1441885 is a reply to message #1441271] Fri, 10 October 2014 06:06 Go to previous message
Ok.
And i don't know if i found a bug but when i user the idGenerationLocation on client with the option PROP_FORCE_NAMES_WITH_ID to true on mapping.
I got an SQL exception during the startup of my server. When i debug, it try to create a table with the name :
CDOBINARYRESOURCE_CEHTTP://WWW.ECLIPSE.ORG/EMF/CDO/ERESOURCE/4.0.0#//CDOBINARYRESOURCE
instead of CDOBINARYRESOURCE_CLNumber
i got no problem if i use "STORE" or if i comment PROP_FORCE_NAMES_WITH_ID properties.
Julien
[Updated on: Fri, 10 October 2014 06:14] by Moderator
Previous Topic:Re: EMF : Code generation from ecore and genmodel
Next Topic:Setting xsiSchemaLocation
Current Time: Sat Jul 19 19:03:14 EDT 2025
Powered by FUDForum. Page generated in 0.04519 seconds
