Home » Eclipse Projects » WindowBuilder » WindowBuilder crashed after Java Upgrade("Exception during 'super' constructor evaluation")
WindowBuilder crashed after Java Upgrade [message #1438556] |
Mon, 06 October 2014 03:42  |
I changed my Java project from JDK 1.7.0 to JDK 1.8.0 because I want to use the new features of Date.
I use Eclipse Luna (4.4.1) and experience in the application of Window Builder at my Swing classes the following problem when I try to switch to Design:
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.ClassCastException: javax.swing.JTextField cannot be cast to javax.swing.AbstractButton
Hide stack trace.
Stack trace:
at javax.swing.plaf.synth.SynthButtonUI.paint(SynthButtonUI.java:284)
at javax.swing.plaf.synth.SynthButtonUI.update(SynthButtonUI.java:255)
at javax.swing.JComponent.paintComponent(JComponent.java:778)
at javax.swing.JComponent.paint(JComponent.java:1054)
at javax.swing.JComponent.paintChildren(JComponent.java:887)
at javax.swing.JComponent.paint(JComponent.java:1063)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
at javax.swing.JComponent.printChildren(JComponent.java:1231)
at javax.swing.JComponent.paint(JComponent.java:1066)
at javax.swing.JComponent.print(JComponent.java:1200)
at java.awt.GraphicsCallback$PrintCallback.run(GraphicsCallback.java:50)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
at java.awt.Container.print(Container.java:2028)
at sun.awt.X11.XComponentPeer.print(XComponentPeer.java:446)
at sun.awt.X11.XPanelPeer.print(XPanelPeer.java:71)
at sun.awt.X11.XWindowPeer.print(XWindowPeer.java:2301)
at sun.awt.X11.XFramePeer.print(XFramePeer.java:439)
at java.awt.GraphicsCallback$PeerPrintCallback.run(GraphicsCallback.java:103)
at java.awt.Component.printAll(Component.java:3442)
at org.eclipse.wb.internal.swing.utils.SwingScreenshotMaker.makeShots(SwingScreenshotMaker.java:123)
at org.eclipse.wb.internal.swing.model.component.ComponentInfo.refresh_fetch(ComponentInfo.java:155)
at org.eclipse.wb.internal.swing.model.component.ComponentInfo.refresh_fetch(ComponentInfo.java:140)
at org.eclipse.wb.internal.swing.model.component.ContainerInfo.refresh_fetch(ContainerInfo.java:251)
at org.eclipse.wb.core.model.ObjectInfo$6$1.run(ObjectInfo.java:496)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:145)
at org.eclipse.wb.core.model.ObjectInfo$6.run(ObjectInfo.java:494)
at org.eclipse.wb.internal.swing.utils.SwingUtils$2.run(SwingUtils.java:76)
at org.eclipse.wb.internal.swing.utils.SwingUtils.invokeLaterAndWait(SwingUtils.java:180)
at org.eclipse.wb.internal.swing.utils.SwingUtils.runLaterAndWait(SwingUtils.java:73)
at org.eclipse.wb.internal.swing.model.component.ComponentInfo.execRefreshOperation(ComponentInfo.java:119)
at org.eclipse.wb.core.model.ObjectInfo.refresh(ObjectInfo.java:492)
at org.eclipse.wb.core.model.ObjectInfo.endEdit(ObjectInfo.java:446)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.run(ExecutionUtils.java:325)
at org.eclipse.wb.internal.core.model.property.accessor.SetterAccessor.setExpression(SetterAccessor.java:137)
at org.eclipse.wb.internal.core.model.property.GenericPropertyImpl.setExpressionUsingAccessor(GenericPropertyImpl.java:341)
at org.eclipse.wb.internal.core.model.property.GenericPropertyImpl.setExpression(GenericPropertyImpl.java:297)
at org.eclipse.wb.internal.swing.model.property.editor.icon.ImagePropertyEditor.openDialog(ImagePropertyEditor.java:178)
at org.eclipse.wb.internal.core.model.property.editor.TextDialogPropertyEditor$1.onClick(TextDialogPropertyEditor.java:35)
at org.eclipse.wb.internal.core.model.property.editor.presentation.ButtonPropertyEditorPresentationImpl$4.handleEvent(ButtonPropertyEditorPresentationImpl.java:124)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4454)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1388)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3799)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3409)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Full context stack trace:
Then I create a new JFrame with Window Builder and receive when switching to design, for example, the following error message:
An exception happened during evaluation of constructor JFrame() using arguments {}.
at java.beans.MethodRef.get(MethodRef.java:72)
at java.beans.PropertyDescriptor.getWriteMethod(PropertyDescriptor.java:270)
Hide stack trace.
Stack trace:
org.eclipse.wb.internal.core.utils.exception.DesignerException: 313 (Exception during 'super' constructor evaluation). JFrame() {} java.lang.NullPointerException
at org.eclipse.wb.internal.core.model.creation.ThisCreationSupport.create(ThisCreationSupport.java:275)
at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluateJavaInfoUsingCreationSupport(JavaInfoEvaluationHelper.java:642)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.addJavaInfo(JavaInfoParser.java:1261)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:253)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4491)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1401)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1187)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3080)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1772)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3742)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3363)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
at org.eclipse.wb.internal.core.model.JavaInfoUtils.addExposedChildred_Method(JavaInfoUtils.java:447)
at org.eclipse.wb.internal.core.model.JavaInfoUtils.addExposedChildren(JavaInfoUtils.java:429)
at org.eclipse.wb.internal.swing.model.component.ComponentInfo.createExposedChildren(ComponentInfo.java:109)
at org.eclipse.wb.internal.swing.model.component.ContainerInfo.createExposedChildren(ContainerInfo.java:143)
at org.eclipse.wb.core.model.JavaInfo.initialize(JavaInfo.java:423)
at org.eclipse.wb.internal.swing.model.component.ContainerInfo.initialize(ContainerInfo.java:114)
at org.eclipse.wb.core.model.JavaInfo.setObject(JavaInfo.java:1288)
at org.eclipse.wb.internal.core.model.creation.ThisCreationSupport.create(ThisCreationSupport.java:269)
... 61 more
... 61 more
I don't understand this behavior of Eclipse. The same behavior appears on my Laptop where also upgraded from Java 7 to Java 8 with Eclipse Kepler. Before under Java 7 and Eclipse Kepler there was not problems to show the swing view from WindowBuilder in Eclipse.
As information, I use on both machines Debian Linux (Workstation "Jessie" and Laptop "Wheezy").
I hope you can help me because that is not satisfactory working.
Andreas
Re: WindowBuilder crashed after Java Upgrade [message #1565324 is a reply to message #1564568] |
Thu, 15 January 2015 02:57   |
Hello Eric,
thanks for your response. I do not exclude that I make mistakes. The following stack trace appears in Eclipse if I want to change from the source code view for the view of WindowsBuilder.
Stack trace:
org.eclipse.wb.internal.core.utils.exception.DesignerException: 1100 (No description).
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parse(GroupLayoutCodeSupport.java:100)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutSupport.parse(GroupLayoutSupport.java:184)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutSupport$2.bindComponents(GroupLayoutSupport.java:91)
at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source)
at org.eclipse.wb.core.model.broadcast.BroadcastSupport$1.intercept(BroadcastSupport.java:208)
at org.eclipse.wb.core.model.broadcast.JavaEventListener$$EnhancerByCGLIB$$2f5eb733.bindComponents(<generated>)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.getRoot(JavaInfoParser.java:404)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parseRootMethods(JavaInfoParser.java:322)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:268)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4590)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:466)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:374)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:527)
at org.eclipse.wb.internal.core.editor.DesignPage.refreshGEF(DesignPage.java:392)
at org.eclipse.wb.internal.core.editor.actions.RefreshAction.run(RefreshAction.java:46)
at org.eclipse.wb.internal.core.editor.actions.DesignPageAction.run(DesignPageAction.java:34)
at org.eclipse.wb.internal.core.editor.errors.JavaExceptionComposite.doRefresh(JavaExceptionComposite.java:87)
at org.eclipse.wb.internal.core.editor.errors.ExceptionComposite$3.widgetSelected(ExceptionComposite.java:129)
at org.eclipse.wb.internal.swing.java6.model.SwingGroupLayoutCodeSupport.setGroupAlignment(SwingGroupLayoutCodeSupport.java:189)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutParserVisitor2.endVisit(GroupLayoutParserVisitor2.java:234)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:241)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2711)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2759)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:234)
at org.eclipse.jdt.core.dom.ASTNode.acceptChildren(ASTNode.java:2782)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:239)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parseGroup(GroupLayoutCodeSupport.java:119)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parse(GroupLayoutCodeSupport.java:97)
... 61 more
... 61 more
And here are the details of my installations in Eclipse - I am using Debian Linux.
*** Date: Donnerstag, 15. Januar 2015 08:54:52 Mitteleuropäische Normalzeit
*** Platform Details:
*** System properties:
__wbp.gwt.useWebKit=true
__wbp.linux.disableScreenshotWorkarounds=false
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.X11.XToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=4.4.1.M20140925-0400
eclipse.commands=-data
/home/andreas/Java8-Projects2
-os
linux
-ws
gtk
-arch
x86_64
-showsplash
/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
-launcher
/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/eclipse
-name
Eclipse
--launcher.library
/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140603-1326/eclipse_1605.so
-startup
/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.appendVmargs
-exitdata
378036
-product
org.eclipse.epp.package.java.product
-vm
/usr/bin/java
eclipse.home.location=file:/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/
eclipse.launcher=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.java
eclipse.product=org.eclipse.epp.package.java.product
eclipse.startTime=1421307575849
eclipse.stateSaveDelayInterval=30000
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.6
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
-jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
java.class.version=52.0
java.endorsed.dirs=/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/ext:/usr/java/packages/lib/ext
java.home=/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.8.0_25-b17
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.8
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.8.0_25
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.8
java.vm.vendor=Oracle Corporation
java.vm.version=25.25-b02
javax.swing.adjustPopupLocationToFit=false
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.m2e.log.dir=/home/andreas/Java8-Projects2/.metadata/.plugins/org.eclipse.m2e.logback.configuration
org.eclipse.swt.internal.gtk.useCairo=true
org.eclipse.update.reconcile=false
org.eclipse.update.resolution_url=
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JavaSE/compact1-1.8,JavaSE/compact2-1.8,JavaSE/compact3-1.8,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7,JavaSE-1.8
org.osgi.framework.language=de
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=3.14.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8",osgi.ee; osgi.ee="JavaSE/compact1"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact2"; version:List<Version>="1.8",osgi.ee; osgi.ee="JavaSE/compact3"; version:List<Version>="1.8"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=e07befa7-899c-0014-1e2d-d27df0a6fad4
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.8.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Linux
os.version=3.14-2-amd64
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/home/andreas/.eclipse/org.eclipse.platform_4.4.1_1196990527_linux_gtk_x86_64/configuration/
osgi.configuration.area.default=null
osgi.framework=file:/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/plugins/org.eclipse.osgi.compatibility.state_1.0.1.v20140709-1414.jar
osgi.install.area=file:/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/
osgi.instance.area=file:/home/andreas/Java8-Projects2/
osgi.instance.area.default=file:/home/andreas/workspace/
osgi.logfile=/home/andreas/Java8-Projects2/.metadata/.log
osgi.nl=de_DE
osgi.os=linux
osgi.sharedConfiguration.area=file:/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/configuration/
osgi.splashLocation=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64/plugins
osgi.tracefile=/home/andreas/Java8-Projects2/.metadata/trace.log
osgi.user.area=null
osgi.user.area.default=null
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.awt.enableExtraMouseButtons=true
sun.boot.class.path=/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/resources.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/rt.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/jsse.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/jce.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/charsets.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/jfr.jar:/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1.8.0_25-oraclejdk-amd64/jre/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.font.fontmanager=sun.awt.X11FontManager
sun.io.unicode.encoding=UnicodeLittle
sun.java.command=/opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar -data /home/andreas/Java8-Projects2 -os linux -ws gtk -arch x86_64 -showsplash /opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.platform_4.4.0.v20140925-0400/splash.bmp -launcher /opt/eclipse-java-luna-SR1-linux-gtk-x86_64/eclipse -name Eclipse --launcher.library /opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140603-1326/eclipse_1605.so -startup /opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar --launcher.appendVmargs -exitdata 378036 -product org.eclipse.epp.package.java.product -vm /usr/bin/java -vmargs -Dosgi.requiredJavaVersion=1.6 -XX:MaxPermSize=256m -Xms40m -Xmx512m -jar /opt/eclipse-java-luna-SR1-linux-gtk-x86_64//plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
sun.os.patch.level=unknown
swing.systemlaf=javax.swing.plaf.metal.MetalLookAndFeel
user.country=DE
user.dir=/home/andreas
user.home=/home/andreas
user.language=de
user.name=andreas
user.timezone=Europe/Berlin
*** Features:
com.android.ide.eclipse.adt.feature (23.0.4.1468518) "Android Development Toolkit"
com.android.ide.eclipse.ddms.feature (23.0.4.1468518) "Dalvik Debug Monitor Service"
com.android.ide.eclipse.hierarchyviewer.feature (23.0.4.1468518) "Hierarchy Viewer"
com.android.ide.eclipse.traceview.feature (23.0.4.1468518) "Traceview"
com.google.gdt.eclipse.designer.feature (3.1.2.r36x201305212016) "GWT Designer"
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.gdb (8.5.0.201409172108) "GDB Common"
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client"
org.eclipse.egit (3.4.1.201406201815-r) "Git Team Provider"
org.eclipse.egit.mylyn (3.4.1.201406201815-r) "Git Team Provider"
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common"
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore"
org.eclipse.epp.mpc (1.3.1.v20140908-1651) "Marketplace Client"
org.eclipse.epp.package.java.feature (4.4.1.20140925-1820) "EPP Java Package"
org.eclipse.help (2.0.102.v20140925-0400) "Help System Base"
org.eclipse.jdt (3.10.0.v20140925-0400) "Eclipse Java Development Tools"
org.eclipse.jgit (3.4.1.201406201815-r) "JGit Core"
org.eclipse.m2e.feature (1.5.0.20140606-0033) "Maven Integration for Eclipse"
org.eclipse.m2e.logback.feature (1.5.0.20140606-0033) "m2e logback configuration"
org.eclipse.mylyn_feature (3.13.0.v20140826-1734) "Mylyn Tasks"
org.eclipse.mylyn.bugzilla_feature (3.13.0.v20140830-0030) "Mylyn Tasks"
org.eclipse.mylyn.builds (1.5.0.v20140830-1416) "Mylyn Builds"
org.eclipse.mylyn.commons (3.13.0.v20140704-2323) "Mylyn Commons"
org.eclipse.mylyn.commons.identity (1.5.0.v20140702-2248) "Mylyn Commons"
org.eclipse.mylyn.commons.notifications (1.5.0.v20140702-2248) "Mylyn Commons"
org.eclipse.mylyn.commons.repositories (1.5.0.v20140905-0008) "Mylyn Commons"
org.eclipse.mylyn.commons.repositories.http (1.5.0.v20140702-2248) "Mylyn Commons"
org.eclipse.mylyn.context_feature (3.13.0.v20140819-2236) "Mylyn Context"
org.eclipse.mylyn.cvs (1.5.0.v20140702-2223) "Mylyn Versions"
org.eclipse.mylyn.discovery (3.13.0.v20140820-1854) "Mylyn Commons"
org.eclipse.mylyn.git (1.5.0.v20140702-2223) "Mylyn Versions"
org.eclipse.mylyn.hudson (1.5.0.v20140702-2228) "Mylyn Builds"
org.eclipse.mylyn.ide_feature (3.13.0.v20140702-2225) "Mylyn Context"
org.eclipse.mylyn.java_feature (3.13.0.v20140819-2236) "Mylyn Context"
org.eclipse.mylyn.monitor (3.13.0.v20140702-2155) "Mylyn Commons"
org.eclipse.mylyn.tasks.ide (3.13.0.v20140704-0050) "Mylyn Tasks"
org.eclipse.mylyn.team_feature (3.13.0.v20140702-2225) "Mylyn Context"
org.eclipse.mylyn.versions (1.5.0.v20140702-2223) "Mylyn Versions"
org.eclipse.mylyn.wikitext_feature (2.2.0.v20140905-1515) "Mylyn WikiText"
org.eclipse.pde (3.10.0.v20140925-0400) "PDE"
org.eclipse.platform (4.4.0.v20140925-0400) "Eclipse Platform"
org.eclipse.rcp (4.4.0.v20140925-0400) "Eclipse RCP"
org.eclipse.recommenders.rcp.feature (2.1.9.v20140917-1240) "Code Recommenders UI"
org.eclipse.wb.core.feature (1.8.0.r44x201412082350) "WindowBuilder Core"
org.eclipse.wb.core.feature (1.7.0.r44x201405021445) "WindowBuilder Core"
org.eclipse.wb.core.ui.feature (1.8.0.r44x201412082358) "WindowBuilder Core UI"
org.eclipse.wb.core.ui.feature (1.7.0.r44x201405021455) "WindowBuilder Core UI"
org.eclipse.wb.core.xml.feature (1.8.0.r44x201412090000) "WindowBuilder Core for XML GUI's"
org.eclipse.wb.css.feature (1.6.0.r36x201305211952) "WindowBuilder CSS Support"
org.eclipse.wb.doc.user.feature (1.8.0.r44x201412090007) "WindowBuilder User Guide"
org.eclipse.wb.layout.group.feature (1.8.0.r44x201412090016) "WindowBuilder GroupLayout Support"
org.eclipse.wb.layout.group.feature (1.7.0.r44x201405021517) "WindowBuilder GroupLayout Support"
org.eclipse.wb.rcp.doc.user.feature (1.8.0.r44x201412090028) "WindowBuilder User Guide - SWT"
org.eclipse.wb.rcp.feature (1.8.0.r44x201412090039) "SWT Designer"
org.eclipse.wb.rcp.GroupLayout_support.feature (1.6.0.r36x201305212046) "SWT Designer GroupLayout Support"
org.eclipse.wb.rcp.SWT_AWT_support (1.8.0.r44x201412090052) "WindowBuilder SWT_AWT Support"
org.eclipse.wb.swing.doc.user.feature (1.8.0.r44x201412090030) "WindowBuilder User Guide - Swing"
org.eclipse.wb.swing.feature (1.8.0.r44x201412090035) "Swing Designer"
org.eclipse.wb.swing.feature (1.7.0.r44x201405021531) "Swing Designer"
org.eclipse.wb.swt.feature (1.8.0.r44x201412090024) "SWT Designer Core"
org.eclipse.wb.xwt.feature (1.8.0.r44x201412090046) "SWT Designer XWT Support"
org.eclipse.wst.xml_ui.feature (3.6.1.v201409111852) "Eclipse XML Editors and Tools"
*** Plug-in Registry:
ch.qos.logback.classic (1.0.7.v20121108-1250) "Logback Classic Module" [Resolved]
ch.qos.logback.core (1.0.7.v20121108-1250) "Logback Core Module" [Resolved]
ch.qos.logback.slf4j (1.0.7.v20121108-1250) "Logback Native SLF4J Logger Module" [Resolved]
com.android.ide.eclipse.adt (23.0.4.1468518) "Android Development Toolkit" [Active]
com.android.ide.eclipse.base (23.0.4.1468518) "Common Android Utilities" [Active]
com.android.ide.eclipse.ddms (23.0.4.1468518) "Dalvik Debug Monitor Service" [Starting]
com.android.ide.eclipse.gldebugger (23.0.4.1468518) "Tracer for OpenGL ES" [Starting]
com.android.ide.eclipse.hierarchyviewer (23.0.4.1468518) "Hierarchy Viewer" [Starting]
com.android.ide.eclipse.ndk (23.0.4.1468518) "ADT CDT Integration" [Starting]
com.android.ide.eclipse.traceview (23.0.4.1468518) "Traceview" [Starting]
com.genymobile.genymotion.ide.eclipse.plugin (1.0.3.201403261147) "Genymotion" [Starting]
com.genymobile.genymotion.lib (1.0.3.201403261147) "GenymotionLib" [Resolved]
com.google.gdt.eclipse.designer (3.1.2.r36x201305212009) "GWT Designer" [Active]
com.google.gdt.eclipse.designer.doc.user (3.1.2.r36x201305212016) "WindowBuilder User Guide - GWT" [Starting]
com.google.gdt.eclipse.designer.GWTExt (3.1.2.r36x201305212016) "GWT Designer GWT-Ext Support" [Active]
com.google.gdt.eclipse.designer.GXT (3.1.2.r36x201305212016) "GWT Designer Ext GWT (GXT) Support" [Active]
com.google.gdt.eclipse.designer.GXT.databinding (3.1.2.r36x201305212016) "GWT Designer Ext GWT (GXT) DataBinding Support" [Active]
com.google.gdt.eclipse.designer.hosted (3.1.2.r36x201305212000) "GWT Designer Hosted Support" [Active]
com.google.gdt.eclipse.designer.hosted.2_0 (3.1.2.r36x201305212000) "GWT Designer Hosted Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0.moz (3.1.2.r36x201305212000) "GWT Designer Linux GRE Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0.super (3.1.2.r36x201305212000) "GWT Designer Super Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0.webkit (3.1.2.r36x201305212000) "GWT Designer WebKit Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_2 (3.1.2.r36x201305212000) "GWT Designer Hosted Support 2.2" [Starting]
com.google.gdt.eclipse.designer.hosted.2_2.moz (3.1.2.r36x201305212000) "GWT Designer Linux GRE Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_2.webkit (3.1.2.r36x201305212000) "GWT Designer WebKit Support 2.2" [Starting]
com.google.gdt.eclipse.designer.hosted.lib (3.1.2.r36x201305212000) "GWT Designer Hosted Libraries" [Starting]
com.google.gdt.eclipse.designer.launch (3.1.2.r36x201305212016) "GWT Designer Launch Configurations" [Starting]
com.google.gdt.eclipse.designer.preferences (3.1.2.r36x201305212016) "GWT Designer Preferences" [Starting]
com.google.gdt.eclipse.designer.SmartGWT (3.1.2.r36x201305212016) "GWT Designer SmartGWT Support" [Active]
com.google.gdt.eclipse.designer.UiBinder (3.1.2.r36x201305212009) "GWT Designer UiBinder Support" [Active]
com.google.gdt.eclipse.designer.UiBinder.wizards (3.1.2.r36x201305212016) "GWT Designer UiBinder Wizards" [Starting]
com.google.gdt.eclipse.designer.wizards (3.1.2.r36x201305212016) "GWT Designer Wizards" [Active]
com.google.gson (2.2.4.v201311231704) "Google GSON" [Resolved]
com.google.guava (15.0.0.v201403281430) "Guava: Google Core Libraries for Java" [Resolved]
com.google.inject (3.0.0.v201312141243) "Google Guice (No AOP)" [Resolved]
com.google.inject.multibindings (3.0.0.v201402270930) "Google Guice (No AOP)" [Resolved]
com.ibm.icu (52.1.0.v201404241930) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.50.v201403120620) "JSch" [Resolved]
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle" [Resolved]
javaewah (0.7.9.v201401101600) "JavaEWAH" [Resolved]
javax.annotation (1.2.0.v201401042248) "javax.annotation Bundle" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.0.0.v201112011016) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
org.apache.ant (1.9.2.v201404171502) "Apache Ant" [Resolved]
org.apache.batik.css (1.7.0.v201011041433) "Apache Batik CSS" [Resolved]
org.apache.batik.util (1.7.0.v201011041433) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.7.0.v200903091627) "Apache Batik GUI Utilities" [Resolved]
org.apache.commons.codec (1.6.0.v201305230611) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.compress (1.6.0.v201310281400) "Apache Commons Compress" [Resolved]
org.apache.commons.httpclient (3.1.0.v201012070820) "Apache Commons Httpclient" [Resolved]
org.apache.commons.io (2.0.1.v201105210651) "Apache Commons IO" [Resolved]
org.apache.commons.lang (2.6.0.v201404270220) "Apache Commons Lang" [Resolved]
org.apache.commons.lang3 (3.1.0.v201403281430) "Apache Commons Lang" [Resolved]
org.apache.commons.logging (1.1.1.v201101211721) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.math (2.1.0.v201105210652) "Apache Commons Math" [Resolved]
org.apache.commons.pool (1.6.0.v201204271246) "Apache Commons Pool" [Resolved]
org.apache.felix.gogo.command (0.10.0.v201209301215) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (0.10.0.v201209301036) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (0.10.0.v201212101605) "Apache Felix Gogo Shell" [Active]
org.apache.httpcomponents.httpclient (4.2.6.v201311072007) "Apache HttpComponents HttpClient OSGi bundle" [Resolved]
org.apache.httpcomponents.httpcore (4.2.5.v201311072007) "Apache HttpComponents HttpCore" [Resolved]
org.apache.jasper.glassfish (2.2.2.v201205150955) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.lucene.analysis (3.5.0.v20120725-1805) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (3.5.0.v20120725-1805) "Apache Lucene Core" [Resolved]
org.apache.solr.client.solrj (3.5.0.v20120530-0900) "Apache Solr Java Client" [Resolved]
org.apache.ws.commons.util (1.0.1.v20100518-1140) "WS Commons Util Plug-in" [Resolved]
org.apache.xerces (2.9.0.v201101211617) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.aether.api (1.0.0.v20140518) "Aether API" [Resolved]
org.eclipse.aether.connector.basic (1.0.0.v20140518) "Aether Connector Basic" [Resolved]
org.eclipse.aether.impl (1.0.0.v20140518) "Aether Implementation" [Resolved]
org.eclipse.aether.maven (3.1.0.v20140706-2237) "Maven Aether Provider Bundle" [Resolved]
org.eclipse.aether.spi (1.0.0.v20140518) "Aether SPI" [Resolved]
org.eclipse.aether.transport.file (1.0.0.v20140518) "Aether Transport File" [Resolved]
org.eclipse.aether.transport.http (1.0.0.v20140518) "Aether Transport HTTP" [Resolved]
org.eclipse.aether.util (1.0.0.v20140518) "Aether Utilities" [Resolved]
org.eclipse.ant.core (3.3.0.v20140518-0042) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.400.v20140518-0030) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.500.v20140521-1557) "Ant UI" [Starting]
org.eclipse.cdt (8.5.0.201409172108) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.codan.checkers (3.2.0.201409172108) "Codan Checkers" [Starting]
org.eclipse.cdt.codan.checkers.ui (3.2.0.201409172108) "Codan Checkers UI" [Starting]
org.eclipse.cdt.codan.core (3.2.0.201409172108) "Code Analysis Core" [Starting]
org.eclipse.cdt.codan.core.cxx (3.2.0.201409172108) "Code Analysis Core for C/C++" [Starting]
org.eclipse.cdt.codan.ui (3.2.0.201409172108) "Code Analysis UI" [Starting]
org.eclipse.cdt.codan.ui.cxx (3.2.0.201409172108) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (5.8.0.201409172108) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.linux (5.3.0.201409172108) "C/C++ Development Tools Core Native Utilities for Linux" [Resolved]
org.eclipse.cdt.core.linux.x86_64 (5.3.0.201409172108) "C/C++ Development Tools Core Native Utilities for Linux (x86_64)" [Resolved]
org.eclipse.cdt.core.native (5.7.0.201409172108) "C/C++ Development Tools Core Native Utilities" [Active]
org.eclipse.cdt.debug.core (7.5.0.201409172108) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (7.3.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Active]
org.eclipse.cdt.debug.mi.ui (6.2.0.201409172108) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Active]
org.eclipse.cdt.debug.ui (7.5.0.201409172108) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.doc.user (5.3.0.201409172108) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.5.0.201409172108) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (4.5.0.201409172108) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.4.0.201409172108) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.4.100.201409172108) "Debugger Services Framework UI" [Starting]
org.eclipse.cdt.gdb (7.0.0.201409172108) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201409172108) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (7.1.0.201409172108) "C/C++ Development Tools Launching Support" [Starting]
org.eclipse.cdt.make.core (7.3.0.201409172108) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.2.0.201409172108) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (8.3.0.201409172108) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (8.3.0.201409172108) "GNU Managed Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (8.2.2.201409172108) "C/C++ Managed Builder UI" [Starting]
org.eclipse.cdt.ui (5.8.1.201409172108) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.5.501.v20140817-1445) "Compare Support" [Active]
org.eclipse.compare.core (3.5.400.v20130903-0736) "Core Compare Support" [Active]
org.eclipse.core.commands (3.6.100.v20140528-1422) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.200.v20140207-1251) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.2.v20140729-1044) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.200.v20140214-0004) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.1.v20140210-1835) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.200.v20140214-0004) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.4.600.v20140128-0851) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.300.v20140219-0051) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.400.v20140127-1516) "File Buffers" [Active]
org.eclipse.core.filesystem (1.4.100.v20140514-1614) "Core File Systems" [Active]
org.eclipse.core.filesystem.java7 (1.0.0.v20140429-1531) "Core File System for Java 7 and newer" [Resolved]
org.eclipse.core.filesystem.linux.x86_64 (1.2.200.v20140124-1940) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.6.0.v20140424-0053) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.200.v20140124-2013) "Internet Connection Management" [Active]
org.eclipse.core.net.linux.x86_64 (1.1.100.v20140124-2013) "Proxy for Linux x86_64" [Resolved]
org.eclipse.core.resources (3.9.1.v20140825-1431) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.10.0.v20140318-2214) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.200.v20140128-0851) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.300.v20140128-0851) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.800.v20130819-1716) "Core Variables" [Active]
org.eclipse.cvs (1.4.100.v20140925-0400) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.9.1.v20140805-1629) "Debug Core" [Active]
org.eclipse.debug.ui (3.10.1.v20140822-1408) "Debug UI" [Active]
org.eclipse.draw2d (3.9.101.201408150207) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.e4.core.commands (0.10.2.v20140424-2344) "Eclipse e4 core commands" [Active]
org.eclipse.e4.core.contexts (1.3.100.v20140407-1019) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.4.0.v20140414-1837) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.extensions (0.12.0.v20140417-2033) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.services (1.2.1.v20140808-1251) "Eclipse Application Services" [Active]
org.eclipse.e4.ui.bindings (0.10.200.v20140424-2042) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.10.100.v20140424-2042) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.11.101.v20140818-1343) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.9.300.v20140424-2042) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.0.0.v20140328-2112) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.model.workbench (1.1.0.v20140512-1820) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.1.0.v20140328-1925) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.widgets (1.0.0.v20140514-1823) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.2.1.v20140901-1244) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.1.1.v20140903-0821) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.12.1.v20140903-1023) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.12.100.v20140530-1436) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.12.0.v20140227-2118) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.ecf (3.4.0.v20140827-1444) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20140827-1444) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.4.0.v20140827-1444) "ECF Identity Core API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.200.v20140827-1444) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4 (1.0.800.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient4.ssl (1.0.0.v20140827-1444) "ECF HttpComponents Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20140827-1444) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.1.0.v20140827-1444) "ECF Core API" [Resolved]
org.eclipse.egit (3.4.1.201406201815-r) "Git Team Provider" [Starting]
org.eclipse.egit.core (3.4.1.201406201815-r) "Git Team Provider Core" [Active]
org.eclipse.egit.doc (3.4.1.201406201815-r) "Git Team Provider Documentation" [Resolved]
org.eclipse.egit.mylyn.ui (3.4.1.201406201815-r) "EGit Mylyn UI" [Starting]
org.eclipse.egit.ui (3.4.1.201406201815-r) "Git Team Provider UI" [Active]
org.eclipse.emf.common (2.10.1.v20140901-1043) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.9.0.v20140901-1055) "EMF Common UI" [Starting]
org.eclipse.emf.databinding (1.3.0.v20140901-1055) "EMF Data Binding" [Starting]
org.eclipse.emf.ecore (2.10.1.v20140901-1043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.10.0.v20140901-1043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.edit (2.9.0.v20140901-1055) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.xmi (2.10.1.v20140901-1043) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.edit (2.10.1.v20140901-1055) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.10.1.v20140901-1055) "EMF Edit UI" [Starting]
org.eclipse.epp.mpc.core (1.3.1.v20140820-1706) "Marketplace Client Core" [Active]
org.eclipse.epp.mpc.help.ui (1.3.1.v20140820-1706) "Marketplace Client Help" [Resolved]
org.eclipse.epp.mpc.ui (1.3.1.v20140908-1651) "Marketplace Client" [Active]
org.eclipse.epp.package.java (4.4.1.20140925-1820) "EPP Java Package" [Resolved]
org.eclipse.equinox.app (1.3.200.v20130910-1609) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (0.10.0.v20130327-1442) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.6.200.v20130402-1505) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.1.0.v20130327-1442) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.console (1.1.0.v20140131-1639) "Console plug-in" [Active]
org.eclipse.equinox.ds (1.4.200.v20131126-2331) "Declarative Services" [Active]
org.eclipse.equinox.event (1.3.100.v20140115-1647) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.100.v20131209-2144) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.500.v20131211-1531) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (3.0.200.v20131021-1843) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.300.v20130402-1529) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.500.v20140318-1755) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.400.v20130327-1442) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.300.v20130327-1442) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.3.0.v20140415-2008) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86_64 (1.1.200.v20140603-1326) "Equinox Launcher Linux X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.300.v20131211-1531) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20131113-1212) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.3.0.v20131211-1531) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.3.100.v20140224-1921) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20140228-1829) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.1.0.v20131211-1531) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.300.v20131210-1027) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.200.v20131211-1531) "Equinox Provisioning Discovery" [Starting]
org.eclipse.equinox.p2.engine (2.3.0.v20140506-1720) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20131119-0908) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20131115-1210) "Equinox Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.300.v20131211-1531) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.2.0.v20131211-1531) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.100.v20131209-2144) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.4.0.v20131119-0908) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.3.0.v20140911-0143) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.1.200.v20140414-0825) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20131211-1531) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.200.v20131119-0908) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.3.0.v20131211-1531) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.1.0.v20131211-1531) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.200.v20140512-1650) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.1.100.v20140523-0116) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.1.0.v20140408-1354) "Equinox Provisioning ECF based Transport" [Active]
org.eclipse.equinox.p2.ui (2.3.0.v20140404-1657) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.100.v20131210-1027) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.importexport (1.1.0.v20131210-1027) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.300.v20140407-1803) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.2.0.v20140422-1847) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20131119-0908) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.400.v20131211-1531) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.5.200.v20140224-1527) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.400.v20140428-1507) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.2.0.v20130424-1801) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.200.v20130626-2037) "Equinox Security Default UI" [Active]
org.eclipse.equinox.simpleconfigurator (1.1.0.v20131217-1203) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20131217-1203) "Simple Configurator Manipulator" [Active]
org.eclipse.equinox.util (1.0.500.v20130404-1337) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.9.100.201408150207) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.6.0.v20130326-1254) "Help System Core" [Active]
org.eclipse.help.base (4.0.200.v20140925-0400) "Help System Base" [Starting]
org.eclipse.help.ui (4.0.100.v20140401-0608) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.300.v20140407-1855) "Help System Webapp" [Starting]
org.eclipse.jdt (3.10.0.v20140925-0400) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.annotation (2.0.0.v20140415-1436) "JDT Annotations for Enhanced Null Analysis" [Resolved]
org.eclipse.jdt.annotation (1.1.0.v20140129-1625) "JDT Annotations for Enhanced Null Analysis" [Resolved]
org.eclipse.jdt.apt.core (3.3.600.v20140311-1758) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.400.v20131113-0353) "Java Compiler Apt IDE" [Active]
org.eclipse.jdt.apt.ui (3.3.400.v20140311-1758) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.1.0.v20140509-1235) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.300.v20140311-1758) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.10.0.v20140902-0626) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.5.0.v20130605-1748) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.8.101.v20140902-1548) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.6.300.v20140512-1926) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.user (3.10.1.v20140827-1504) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.7.300.v20140418-0836) "Java Development Tools JUnit support" [Active]
org.eclipse.jdt.junit.core (3.7.300.v20140409-1618) "Java Development Tools JUnit core support" [Active]
org.eclipse.jdt.junit.runtime (3.4.500.v20140527-1138) "Java Development Tools JUnit Runtime Support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.400.v20140314-0036) "Java Development Tools JUnit4 Runtime Support" [Resolved]
org.eclipse.jdt.launching (3.7.101.v20140825-1922) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.10.1.v20140817-1500) "Java Development Tools UI" [Active]
org.eclipse.jem.util (2.1.200.v201404021757) "Java EMF Model Utilities" [Starting]
org.eclipse.jetty.continuation (8.1.14.v20131031) "Jetty :: Continuation" [Resolved]
org.eclipse.jetty.http (8.1.14.v20131031) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (8.1.14.v20131031) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (8.1.14.v20131031) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (8.1.14.v20131031) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (8.1.14.v20131031) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (8.1.14.v20131031) "Jetty :: Utilities" [Resolved]
org.eclipse.jface (3.10.1.v20140813-1009) "JFace" [Active]
org.eclipse.jface.databinding (1.6.200.v20140528-1422) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.9.1.v20140827-1810) "JFace Text" [Resolved]
org.eclipse.jgit (3.4.1.201406201815-r) "JGit Core" [Active]
org.eclipse.jgit.archive (3.4.1.201406201815-r) "JGit Archive Formats" [Starting]
org.eclipse.jsch.core (1.1.500.v20131112-1442) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.500.v20131112-1442) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.6.101.v20140817-1500) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.7.100.v20140324-1358) "Refactoring UI" [Active]
org.eclipse.m2e.archetype.common (1.5.0.20140605-2032) "Maven Archetype Common Bundle" [Resolved]
org.eclipse.m2e.core (1.5.0.20140606-0033) "Maven Integration for Eclipse" [Starting]
org.eclipse.m2e.core.ui (1.5.0.20140606-0033) "Maven Integration for Eclipse" [Starting]
org.eclipse.m2e.discovery (1.5.0.20140606-0033) "m2e Marketplace" [Starting]
org.eclipse.m2e.editor (1.5.0.20140606-0033) "Maven Integration for Eclipse (Editors)" [Starting]
org.eclipse.m2e.editor.xml (1.5.0.20140606-0033) "Maven POM XML Editor" [Starting]
org.eclipse.m2e.jdt (1.5.0.20140606-0033) "Maven Integration for Eclipse JDT" [Starting]
org.eclipse.m2e.jdt.ui (1.5.0.20140606-0033) "Maven Integration for Eclipse JDT UI" [Resolved]
org.eclipse.m2e.launching (1.5.0.20140606-0033) "Maven Integration for Eclipse Launching" [Active]
org.eclipse.m2e.lifecyclemapping.defaults (1.5.0.20140606-0033) "Default Build Lifecycle Mapping Metadata" [Resolved]
org.eclipse.m2e.logback.appender (1.5.0.20140606-0033) "m2e logback appender" [Resolved]
org.eclipse.m2e.logback.configuration (1.5.0.20140606-0033) "m2e logback configuration" [Active]
org.eclipse.m2e.maven.indexer (1.5.0.20140605-2032) "Maven / Nexus Indexer Bundle" [Resolved]
org.eclipse.m2e.maven.runtime (1.5.0.20140605-2032) "Embedded Maven Runtime Bundle (includes Incubating components)" [Resolved]
org.eclipse.m2e.maven.runtime.slf4j.simple (1.5.0.20140605-2032) "slf4j-simple for use in m2e embedded maven runtime" [Resolved]
org.eclipse.m2e.model.edit (1.5.0.20140606-0033) "Maven Project Model Edit Bundle" [Starting]
org.eclipse.m2e.profiles.core (1.5.0.20140606-0033) "Maven Profiles Management" [Starting]
org.eclipse.m2e.profiles.ui (1.5.0.20140606-0033) "Maven Profiles Management UI" [Starting]
org.eclipse.m2e.refactoring (1.5.0.20140606-0033) "Maven Integration for Eclipse Refactoring" [Starting]
org.eclipse.m2e.scm (1.5.0.20140606-0033) "SCM Maven Integration for Eclipse" [Resolved]
org.eclipse.mylyn.bugzilla.core (3.13.0.v20140830-0030) "Mylyn Bugzilla Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (3.13.0.v20140702-2225) "Mylyn Bugzilla IDE Extensions" [Resolved]
org.eclipse.mylyn.bugzilla.ui (3.13.0.v20140809-1218) "Mylyn Bugzilla Connector UI" [Active]
org.eclipse.mylyn.builds.core (1.5.0.v20140702-2228) "Mylyn Builds" [Starting]
org.eclipse.mylyn.builds.ui (1.5.0.v20140830-1416) "Mylyn Build Framework" [Active]
org.eclipse.mylyn.commons.core (3.13.0.v20140704-2323) "Mylyn Commons" [Active]
org.eclipse
Current Time: Sun Jul 20 03:07:38 EDT 2025
Powered by FUDForum. Page generated in 0.09874 seconds
