Home » Newcomers » Newcomers » Avoid "The method ... can potentially be declared as static" warning
Avoid "The method ... can potentially be declared as static" warning [message #1435498] Wed, 01 October 2014 11:34 Go to next message
How can I avoid the warning in this scenario?
public class A {
    // warning occurs on this method:
    // The method foo() from the type A can potentially be declared as static
    protected boolean foo() {
        return false;
public final class B extends A {
        // do B specific things
Re: Avoid "The method ... can potentially be declared as static" warning [message #1436076 is a reply to message #1435498] Thu, 02 October 2014 07:09 Go to previous messageGo to next message
If you do not put the return in B.java has an error
(Sorry for bad english)
A.java
public class A {
	public boolean foo()
		return false;
B.java
public class B extends A {
	public boolean foo() {
		// TODO Auto-generated method stub
		return true;
[Updated on: Thu, 02 October 2014 07:11] by Moderator
Re: Avoid "The method ... can potentially be declared as static" warning [message #1436157 is a reply to message #1435498] Thu, 02 October 2014 09:44 Go to previous messageGo to next message
I was implying the return value with the comment. But better to be explicit about things.
public class A {
        return false;
        // do non-static, B specific things
        return true;
The relevant Eclipse setting is here:
index.php/fa/19356/0/
  • Attachment: static.png
    (Size: 2.04KB, Downloaded 956 times)
[Updated on: Thu, 02 October 2014 09:44] by Moderator
Re: Avoid "The method ... can potentially be declared as static" warning [message #1436256 is a reply to message #1436157] Thu, 02 October 2014 12:21 Go to previous messageGo to next message
That looks like a bug to me. The analysis that produces the warning should probably take into account the fact that the method is overridden by another class in the project (assuming B is in the same project as A). Try asking on the JDT forum, or just entering it into Bugzilla
Re: Avoid "The method ... can potentially be declared as static" warning [message #1436856 is a reply to message #1436256] Fri, 03 October 2014 10:02 Go to previous messageGo to next message
Thanks, I'll post it to JDT before entering a bug.
Re: Avoid "The method ... can potentially be declared as static" warning [message #1440515 is a reply to message #1436856] Wed, 08 October 2014 09:06 Go to previous message
I get your question. I think the way things proceed is when we are in Class A there is no look at the function and see it is not accessing any other methods.
So let us narrow it's scope and make it static (so that it can only access static methods).
When we are in A we do not who is inheriting from A.
Previous Topic:Hide Header Row For Nested Table
Next Topic:Nanomind fail
Current Time: Sun Jul 20 13:06:36 EDT 2025
Powered by FUDForum. Page generated in 0.08236 seconds
