Home » Eclipse Projects » Runtimes » unable to compile javafx8 code in eclipse kepler using jre1.8
unable to compile javafx8 code in eclipse kepler using jre1.8 [message #1434682] Tue, 30 September 2014 08:44 Go to next message
Hi i am trying to learn javafx8. I have imported jre8 into kepler. But unable to compile the file. The import " import javafx.application.Application" says
"Access restriction: The type Application is not accessible due to restriction on required library D:\jdk1.8.0_20\jre\lib\ext\jfxrt.jar"
why is this happening? how can i run my code?
Thanks in advance.
Re: unable to compile javafx8 code in eclipse kepler using jre1.8 [message #1434725 is a reply to message #1434682] Tue, 30 September 2014 09:46 Go to previous message
I have resolved this by adding an access rule to the jre. thank you so much.
Previous Topic:Can I get an Empty IDE as target platform using Target Platform provisioning
Next Topic:Problem of memory consumption with Jetty 9 and JDK8
Current Time: Sun Jul 20 15:33:42 EDT 2025
Powered by FUDForum. Page generated in 0.03828 seconds
