Home » Modeling » EMF » [Texo] generating a default value for an attribute
[Texo] generating a default value for an attribute [message #1431552] Thu, 25 September 2014 17:10 Go to next message
Hi all,
I've set a default value for an attribute in my ecore model file. But if
I generate the Java code there's no assignment of this value. How do I
create it in the right way?
TIA,
Ralf.
Re: [Texo] generating a default value for an attribute [message #1436700 is a reply to message #1431552] Fri, 03 October 2014 05:23 Go to previous messageGo to next message
Hi Ralf,
Missed your post... I tested it for int/string/enum and for all 3 the default value worked. What type is your eattribute?
Here are my examples:
private String title = "TEST";
* <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
private int pages = 100;
* @generated
private BookCategory category = BookCategory.SCIENCEFICTION;
gr. Martin
On 25-09-14 23:10, Ralf Heydenreich wrote:
> Hi all,
> TIA,
> Ralf.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] generating a default value for an attribute [message #1437655 is a reply to message #1436700] Sat, 04 October 2014 16:17 Go to previous message
Am 03.10.2014 um 11:23 schrieb Martin Taal:
> Hi Ralf,
> * @generated
> * @generated
> gr. Martin
>> Hi all,
>> TIA,
>> Ralf.
Hi Martin,
thanks for your answer. Now, I've tested it with EBooleanObject value
and it works as expected. But I have to use the simple type version
("true/false") instead of "Boolean.TRUE" or "Boolean.FALSE".
It does not work if I use EIntegerObject. Whether if I use
"java.lang.Integer.valueOf(1)" nor if I use the simple "1" as Default
Value Literal.
Are the default values only useable with simple types?
Greetz,
Ralf.
Previous Topic:[CDO] Using conflict resolver
Next Topic:EFS provider based on EMF model of resources
Current Time: Sun Jul 20 09:39:04 EDT 2025
Powered by FUDForum. Page generated in 0.05850 seconds
