Home » Modeling » TMF (Xtext) » Possible to suppress UI elements in Xtext for batch mode execution of xtext?
Possible to suppress UI elements in Xtext for batch mode execution of xtext? [message #1431076] Thu, 25 September 2014 03:11 Go to next message
Hi All,
I have a xtext based grammar, that I want to use in batch mode in Linux.
The problem i am facing is that if the DISPLAY is not set, the grammar fails giving exceptions for NoClassDefFoundErr on some UI plugins.
I would want to have no dependency to GUI when running in batch. I use the Guice.createInjector() to get the runtime module of the DSL, and apparently that is the problem area, so when the xtext parser is injected it probably enables some UI classes for editor.
Is there a way to disable the GUI elements when we inject the parser?
Below is the stack trace(not full):
Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
Failed to create injector for com.qualcomm.qti.csr.xtext.mydsl.MyDSL
com.google.inject.internal.util.$ComputationException: java.lang.NoClassDefFoundError: org/eclipse/ui/actions/WorkspaceModifyOperation
com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: java.lang.NoClassDefFoundError: org/eclipse/ui/actions/WorkspaceModifyOperation
at com.google.inject.internal.util.$MapMaker$StrategyImpl.compute(MapMaker.java:553)
at com.google.inject.internal.util.$MapMaker$StrategyImpl.compute(MapMaker.java:419)
at com.google.inject.internal.util.$CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
at com.google.inject.internal.FailableCache.get(FailableCache.java:50)
at com.google.inject.internal.ConstructorInjectorStore.get(ConstructorInjectorStore.java:49)
at com.google.inject.internal.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:125)
at com.google.inject.internal.InjectorImpl.initializeJitBinding(InjectorImpl.java:521)
at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:847)
at com.google.inject.internal.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:772)
at com.google.inject.internal.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:256)
at com.google.inject.internal.InjectorImpl.getBindingOrThrow(InjectorImpl.java:205)
at com.google.inject.internal.InjectorImpl.getInternalFactory(InjectorImpl.java:853)
at com.google.inject.internal.FactoryProxy.notify(FactoryProxy.java:46)
at com.google.inject.internal.ProcessedBindingData.runCreationListeners(ProcessedBindingData.java:50)
at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:133)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
Rohit Ahuja
Re: Possible to suppress UI elements in Xtext for batch mode execution of xtext? [message #1433785 is a reply to message #1431076] Mon, 29 September 2014 04:32 Go to previous messageGo to next message
Hi Rohit,
if you run within Eclipse / Equinox, you have to be very careful to not
use a second Injector besides the one that is part of the UI plugin.
Please note that the UI plugin - even though it is called UI plugin -
does not necessarily need a UI. The bundle usually works fine in
headless mode. Thus I recommend the use the injector that is provided by
the UI plugins' activator in your batch application.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 25.09.14 09:11, schrieb rohit ahuja:
> Hi All,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Rohit Ahuja
Re: Possible to suppress UI elements in Xtext for batch mode execution of xtext? [message #1434715 is a reply to message #1433785] Tue, 30 September 2014 09:29 Go to previous messageGo to next message
Hi Sebastian,
Thanks for your reply.
Based on your suggestion i changed my injector, to use the Injector of the Activator in the UI Plugin like below
Injector injector = DSLActivator.getInstance().getInjector(DSLActivator.DSLName);
I also noticed that the Activator internally, calls Guice to create the Injector itself in the createInjector method, like below.
Module runtimeModule = getRuntimeModule(language);
Module sharedStateModule = getSharedStateModule();
Module uiModule = getUiModule(language);
Module mergedModule = Modules2.mixin(runtimeModule, sharedStateModule, uiModule);
return Guice.createInjector(mergedModule);
At the point of Guice.createInjector(), i get NoClassDefFoundErr, log below , Any suggestions??
at com.google.inject.internal.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:772) at com.google.inject.internal.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:256)
Rohit Ahuja
Re: Possible to suppress UI elements in Xtext for batch mode execution of xtext? [message #1434729 is a reply to message #1434715] Tue, 30 September 2014 09:49 Go to previous messageGo to next message
Hi Rohit,
you have to make sure that the bundle with the missing class is
contained in your product. PLease note that a bundle name with *.ui does
not necessarily mean that the bundle is not capable of working headless.
Sebastian
Am 30.09.14 15:29, schrieb rohit ahuja:
> Hi Sebastian,
> Injector injector =
> uiModule);
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Rohit Ahuja
Re: Possible to suppress UI elements in Xtext for batch mode execution of xtext? [message #1695989 is a reply to message #1434729] Wed, 20 May 2015 19:01 Go to previous message
Hi Sebastian,
I am working on the same problem. I think you need to see the complete exception stack trace to see that the problem is not comming from missing bundles. In fact since DISPLAY is not set, the gtk library cannot be started which causes a lot of other bundles to not load and as a result the injector cannot find some of the classes.
Is there any alternative way to get the xtext resource loaded, which won't trigger loading and SWT dependent classes? Do you know if any of the existing tools using xtext supporting a no display use model?
!SESSION 2015-05-20 14:17:41.480 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_10
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi 4 0 2015-05-20 14:18:05.777
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.ide (237).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start() of bundle org.eclipse.ui.ide.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClass(MultiSourcePackage.java:31)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2404)
at java.lang.Class.getDeclaredConstructors(Class.java:1853)
at com.google.inject.spi.InjectionPoint.forConstructorOf(InjectionPoint.java:243)
at com.google.inject.internal.ConstructorBindingImpl.create(ConstructorBindingImpl.java:96)
at com.google.inject.internal.InjectorImpl.createUninitializedBinding(InjectorImpl.java:629)
at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:845)
at com.google.inject.internal.InjectorImpl.createImplementedByBinding(InjectorImpl.java:732)
at com.google.inject.internal.InjectorImpl.createUninitializedBinding(InjectorImpl.java:618)
at com.google.inject.internal.InjectorImpl.createParameterInjector(InjectorImpl.java:925)
at com.google.inject.internal.InjectorImpl.getParametersInjectors(InjectorImpl.java:913)
at com.google.inject.internal.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:69)
at com.google.inject.internal.ConstructorInjectorStore.access$000(ConstructorInjectorStore.java:28)
at com.google.inject.internal.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:36)
at com.google.inject.internal.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:32)
at com.google.inject.internal.FailableCache$1.apply(FailableCache.java:39)
at com.google.inject.internal.util.$MapMaker$StrategyImpl.compute(MapMaker.java:549)
at com.google.inject.internal.InjectorImpl.createProviderBinding(InjectorImpl.java:317)
at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:805)
at com.google.inject.internal.SingleFieldInjector.<init>(SingleFieldInjector.java:41)
at com.google.inject.internal.MembersInjectorStore.getInjectors(MembersInjectorStore.java:125)
at com.google.inject.internal.MembersInjectorStore.createWithListeners(MembersInjectorStore.java:95)
at com.google.inject.internal.MembersInjectorStore.access$000(MembersInjectorStore.java:34)
at com.google.inject.internal.MembersInjectorStore$1.create(MembersInjectorStore.java:42)
at com.google.inject.internal.MembersInjectorStore$1.create(MembersInjectorStore.java:39)
at com.google.inject.internal.MembersInjectorStore.get(MembersInjectorStore.java:65)
at com.google.inject.internal.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:73)
at MyProject.xtext.MyDSL.ui.internal.MyDSLActivator.createInjector(MyDSLActivator.java:67)
at MyProject.xtext.MyDSL.ui.internal.MyDSLActivator.getInjector(MyDSLActivator.java:55)
at MyProject.util.MyDSLMapper.mapFileToModel(MyDSLMapper.java:390)
at MyProject.util.MyDSLMapper.mapModelAndDoPostProcessing(MyDSLMapper.java:551)
at MyProject.batch.ImportMyDSLBatchHandler.runBatch(ImportMyDSLBatchHandler.java:55)
at MyRCP.batch.impl.BatchProcessorImpl.runBatchCallbacks(BatchProcessorImpl.java:105)
at MyRCP.rcp.Application.start(Application.java:71)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:925)
at org.eclipse.swt.widgets.Display.create(Display.java:909)
at org.eclipse.swt.graphics.Device.<init>(Device.java:156)
at org.eclipse.swt.widgets.Display.<init>(Display.java:507)
at org.eclipse.swt.widgets.Display.<init>(Display.java:498)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1704)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.createProblemsViews(IDEWorkbenchPlugin.java:394)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start(IDEWorkbenchPlugin.java:351)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 159 more
Root exception:
Previous Topic:Generated SyntacticSequencer in the serializer package
Next Topic:Debugging parser
Current Time: Sat Jul 19 06:45:52 EDT 2025
Powered by FUDForum. Page generated in 0.04153 seconds
