Audit Trail support for MySql current version [message #1421185] |
Wed, 10 September 2014 23:08  |
I am trying to deploy stardust on MySql. Currently Stardust only supports MySql versions 5.0 and 5.1.
I use Ubuntu. Current Ubuntu version (14.04) comes by default with MySql version 5.5 and older versions are not available in repository for install.
I tried to deploy Stardust DDL on MySql 5.5 and I got the following error:
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=InnoDB' at line 1
I could delete 'TYPE=InnoDB' in DDL file to work around the error.
From your experience would Stardust work on MySql 5.5 at all? What are the plans in regard of support for current MySql version?
Dan
FUDForum. Page generated in 0.03966 seconds
