Home » Archived » Visual Editor (VE) » How i do for start a Visual Editor by code or extension?
How i do for start a Visual Editor by code or extension? [message #142765] Wed, 07 November 2007 03:01 Go to next message
Originally posted by: caye5200.yahoo.com.cn
Hello:
when we create a visual class ,visual editor can start,
now i want start a visual editor by code or extension .
how i do?
Re: How i do for start a Visual Editor by code or extension? [message #142795 is a reply to message #142765] Wed, 07 November 2007 19:22 Go to previous messageGo to next message
To Open VE, you need to open a Java file. with VE editor ID using
IDE.openEditor(IWorkbenchPage page, IFile input,
String editorId);
Yves YANG
http://www.soyatec.com/eface
"zxc" <caye5200@yahoo.com.cn> wrote in message
news:fgrrcm$qqk$1@build.eclipse.org...
> Hello:
> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #142804 is a reply to message #142795] Wed, 07 November 2007 20:21 Go to previous messageGo to next message
Yves YANG,
thank you, i can open ve using this method,
EditorUtility.openInEditor(IEditorInput input, String editorID, boolean
activate)
editorID is
" org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itor "
but ,i have anthor problem, i try get a EditorPart,
BundleHost
bundle=(BundleHost)org.eclipse.ve.internal.java.core.JavaVEP lugin.getPlugin().getBundle()
className=" org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart "
classInstance=bundle.loadClass(className);
visualPart=(JavaVisualEditorPart)classInstance.newInstance() ;
visualPart.init(IEditorSite site, IEditorInput input)
the method argument "site" how can i do to get?
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:fgtkrv$ibu$1@build.eclipse.org...
> String editorId);
> Regards
> Yves YANG
>> Hello:
>> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #142862 is a reply to message #142804] Thu, 08 November 2007 11:03 Go to previous messageGo to next message
You can't just new up an editor instance. You have to use the
EditorUtility.openInEditor to open an editor. There are many different
things that need to be set up and called and the EditorUtility does that
for you.
Re: How i do for start a Visual Editor by code or extension? [message #142872 is a reply to message #142804] Thu, 08 November 2007 11:04 Go to previous messageGo to next message
for you.
Re: How i do for start a Visual Editor by code or extension? [message #142883 is a reply to message #142872] Thu, 08 November 2007 19:58 Go to previous messageGo to next message
Rich kulp,
Thank you ! i am Develop a plugin now , i want to get lastModel for a view
and not open the Editor, I am failed.
then ,i found that VE must be activated
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:fgvc0f$u81$2@build.eclipse.org...
> for you.
Re: How i do for start a Visual Editor by code or extension? [message #143132 is a reply to message #142765] Fri, 23 November 2007 10:44 Go to previous messageGo to next message
Originally posted by: oliver.mietrach.macio.de
I do it by opening a .jave-File by Code. Here is my Snippet
IProject project = ResourcesPlugin.getWorkspace().getRoot()
.getProject("project");
IFile iFile = project.getFile("myFile.java");
IWorkbenchPage page = this.getWindowConfigurer().getWindow()
.getActivePage();
page.openEditor(new FileEditorInput(iFile),
" org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itor ");
This will do it, I hope.
Greets Oliver
zxc schrieb:
> Hello:
> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #143140 is a reply to message #143132] Fri, 23 November 2007 10:47 Go to previous message
Excuse me I saw the answers too late
> .getActivePage();
> Greets Oliver
> zxc schrieb:
>> Hello:
>> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #616853 is a reply to message #142765] Wed, 07 November 2007 19:22 Go to previous message
String editorId);
Yves YANG
> Hello:
> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #616854 is a reply to message #142795] Wed, 07 November 2007 20:21 Go to previous message
Yves YANG,
activate)
editorID is
BundleHost
> String editorId);
> Regards
> Yves YANG
>> Hello:
>> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #616860 is a reply to message #142804] Thu, 08 November 2007 11:03 Go to previous message
for you.
Re: How i do for start a Visual Editor by code or extension? [message #616861 is a reply to message #142804] Thu, 08 November 2007 11:04 Go to previous message
for you.
Re: How i do for start a Visual Editor by code or extension? [message #616862 is a reply to message #142872] Thu, 08 November 2007 19:58 Go to previous message
Rich kulp,
> for you.
Re: How i do for start a Visual Editor by code or extension? [message #616887 is a reply to message #142765] Fri, 23 November 2007 10:44 Go to previous message
.getActivePage();
Greets Oliver
zxc schrieb:
> Hello:
> how i do?
Re: How i do for start a Visual Editor by code or extension? [message #616888 is a reply to message #143132] Fri, 23 November 2007 10:47 Go to previous message
> .getActivePage();
> Greets Oliver
> zxc schrieb:
>> Hello:
>> how i do?
Previous Topic:Getting an Error after unpacking some sources
Next Topic:Problem with mirror hosting VE updates: http://www.eclipse.ps.pl/tools/ve/updates/1.0
Current Time: Sat Jul 19 15:24:29 EDT 2025
Powered by FUDForum. Page generated in 0.07325 seconds
