Noob question regarding STL debug [message #743019] |
Thu, 20 October 2011 23:46  |
I'm using the indigo version of eclipse. I've read the FAQ but I don't quite understand it. (evidently, I am not allowed to post links yet).
I am a windows user (windows vista).[/b] What does the following command do and does it apply to a windows user?
svn co svn://gcc.gnu.org/svn/gcc/trunk/libstdc++-v3/python
I followed that link and manually downloaded the python files. I think created the .gdbinit file as instructed. One issue that I have is that I am not clear about what is meant by the root project directory.
The following was copy and pasted from the console so that you can see the mingw gdb version.
C:\MinGW\bin>gdb
GNU gdb (GDB) 7.3
I also see gdb-python27.exe in addition to the gdb.exe within the mingw\bin directory. So I tried changing the gdb settings to point to that gdb-python27.exe and the new .gdbinit file. I didn't find an existing .gdbinit file, so I assumed that I should just create it and put it somewhere on my c drive, and updated the preferences to point to that. The following error occurred when trying to debug my c++ project.
Error in final launch sequence
Failed to execute MI command:
source C:\PythonPrettyPrinting\PrettyPrinting.gdbinit
Error message from debugger back end:
C:\PythonPrettyPrinting\PrettyPrinting.gdbinit:6: Error in sourced command file:
Error while executing Python code.
If anyone can help, I'd appreciate it.
FUDForum. Page generated in 0.07131 seconds
