Home » Eclipse Projects » Gemini » Can someone share a working target run-time setup?(need to run JPA samples)
Can someone share a working target run-time setup? [message #1426769] Fri, 19 September 2014 03:31 Go to next message
Hello there,
Can someone share a "ss" list (or screen shot) of bundles where the out-of-box Gemini JPA samples has successfully run?
I have attached mine which gives me error can not find "org.eclipse.persistence.internal.jpa.rs.metadata.model.Link".
Thanks a lot,
David
Re: Can someone share a working target run-time setup? [message #1432186 is a reply to message #1426769] Fri, 26 September 2014 15:23 Go to previous messageGo to next message
Hi David,
Here is what I just ran (in Juno):
id	State       Bundle
0	ACTIVE      org.eclipse.osgi_3.8.1.v20120830-144521
7	ACTIVE      org.eclipse.gemini.dbaccess.derby_1.0.0.RELEASE
8	ACTIVE      org.eclipse.osgi.services_3.3.100.v20120522-1822
11	ACTIVE      osgi.enterprise_4.2.0.201003190513
15	ACTIVE      org.eclipse.osgi.util_3.2.300.v20120522-1822
16	ACTIVE      org.eclipse.equinox.cm_1.0.400.v20120522-1841
17	ACTIVE      org.apache.derby_10.5.1.1
18	ACTIVE      org.eclipse.persistence.jpa.jpql_2.5.0.v20130507-3faac2b
19	ACTIVE      org.apache.felix.gogo.command_0.8.0.v201108120515
20	ACTIVE      org.apache.felix.gogo.shell_0.8.0.v201110170705
21	ACTIVE      org.eclipse.persistence.antlr_3.2.0.v201302191141
22	ACTIVE      org.eclipse.persistence.asm_3.3.1.v201302191223
23	ACTIVE      org.eclipse.persistence.jpa_2.5.0.v20130507-3faac2b
25	ACTIVE      org.eclipse.equinox.console_1.0.0.v20120522-1841
26	ACTIVE      org.apache.felix.gogo.runtime_0.8.0.v201108120515
28	ACTIVE      org.eclipse.persistence.core_2.5.0.v20130507-3faac2b
29	ACTIVE      javax.persistence_2.1.0.v201304241213
31	ACTIVE      org.eclipse.gemini.jpa.sample.configadmin_1.2.0.qualifier
32	ACTIVE      org.eclipse.gemini.jpa.sample.configadmin.gen_1.2.0.qualifier
33	ACTIVE      org.eclipse.gemini.jpa.sample.configadmin.pu_1.2.0.qualifier
34	ACTIVE      org.eclipse.gemini.jpa_1.2.0.qualifier
The output is in the attached file.
-Mike
  • Attachment: output.txt
    (Size: 12.49KB, Downloaded 301 times)
Re: Can someone share a working target run-time setup? [message #1434023 is a reply to message #1432186] Mon, 29 September 2014 11:02 Go to previous message
I tried it with the RT distro:
- EclipseRT-OSGi-StarterKit-Luna-win32-win32-x86_64
- EclipseLink 2.5.0
- Gemini JPA 1.2.0 M1
and I also got an missing class error (though a different one). The class that it couldn't find was org.eclipse.persistence.jpa.jpql.parser.ExpressionVisitor.
This appears to be an EclipseLink dependency problem, since a class in the EL jpa bundle was trying to load a class in the jpa.jpql bundle but had no dependency on its package. I modified the bundle manifest in the org.eclipse.persistence.jpa bundle to import org.eclipse.persistence.jpa.jpql.parser and the sample worked. Here is the list of bundles that were installed:
osgi> ss
"Framework is launched."
id      State       Bundle
0       ACTIVE      org.eclipse.osgi_3.10.0.v20140606-1445
                    Fragments=1
1       RESOLVED    org.eclipse.osgi.compatibility.state_1.0.0.v20140403-1907
                    Master=0
2       RESOLVED    org.apache.commons.codec_1.6.0.v201305230611
3       RESOLVED    org.apache.commons.logging_1.1.1.v201101211721
4       ACTIVE      org.apache.felix.gogo.command_0.10.0.v201209301215
5       ACTIVE      org.apache.felix.gogo.runtime_0.10.0.v201209301036
6       ACTIVE      org.apache.felix.gogo.shell_0.10.0.v201212101605
7       RESOLVED    org.apache.httpcomponents.httpclient_4.2.6.v201311072007
8       RESOLVED    org.apache.httpcomponents.httpcore_4.2.5.v201311072007
9       STARTING    org.eclipse.core.jobs_3.6.0.v20140424-0053
10      STARTING    org.eclipse.ecf_3.4.0.v20140528-1625
                    Fragments=17
11      STARTING    org.eclipse.ecf.filetransfer_5.0.0.v20140528-1625
12      STARTING    org.eclipse.ecf.identity_3.4.0.v20140528-1625
13      STARTING    org.eclipse.ecf.provider.filetransfer_3.2.200.v20140528-1625
                    Fragments=16
14      STARTING    org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.500.v20140528-1625
                    Fragments=15
15      RESOLVED    org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140528-1625
                    Master=14
16      RESOLVED    org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140528-1625
                    Master=13
17      RESOLVED    org.eclipse.ecf.ssl_1.1.0.v20140528-1625
                    Master=10
18      STARTING    org.eclipse.equinox.app_1.3.200.v20130910-1609
19      ACTIVE      org.eclipse.equinox.common_3.6.200.v20130402-1505
20      STARTING    org.eclipse.equinox.concurrent_1.1.0.v20130327-1442
21      ACTIVE      org.eclipse.equinox.console_1.1.0.v20140131-1639
22      RESOLVED    org.eclipse.equinox.ds_1.4.200.v20131126-2331
23      STARTING    org.eclipse.equinox.frameworkadmin_2.0.100.v20131209-2144
24      ACTIVE      org.eclipse.equinox.frameworkadmin.equinox_1.0.500.v20131211-1531
25      RESOLVED    org.eclipse.equinox.launcher_1.3.0.v20140415-2008
                    Fragments=26
26      RESOLVED    org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140603-1326
                    Master=25
27      STARTING    org.eclipse.equinox.p2.artifact.repository_1.1.300.v20131211-1531
28      ACTIVE      org.eclipse.equinox.p2.console_1.0.300.v20131113-1212
29      ACTIVE      org.eclipse.equinox.p2.core_2.3.0.v20131211-1531
30      STARTING    org.eclipse.equinox.p2.director_2.3.100.v20140224-1921
31      STARTING    org.eclipse.equinox.p2.engine_2.3.0.v20140506-1720
32      STARTING    org.eclipse.equinox.p2.garbagecollector_1.0.200.v20131115-1210
33      RESOLVED    org.eclipse.equinox.p2.jarprocessor_1.0.300.v20131211-1531
34      ACTIVE      org.eclipse.equinox.p2.metadata_2.2.0.v20131211-1531
35      STARTING    org.eclipse.equinox.p2.metadata.repository_1.2.100.v20131209-2144
36      STARTING    org.eclipse.equinox.p2.operations_2.4.0.v20131119-0908
37      STARTING    org.eclipse.equinox.p2.ql_2.0.100.v20131211-1531
38      ACTIVE      org.eclipse.equinox.p2.repository_2.3.0.v20131211-1531
39      STARTING    org.eclipse.equinox.p2.touchpoint.eclipse_2.1.200.v20140512-1650
40      STARTING    org.eclipse.equinox.p2.touchpoint.natives_1.1.100.v20140523-0116
41      STARTING    org.eclipse.equinox.p2.transport.ecf_1.1.0.v20140408-1354
42      STARTING    org.eclipse.equinox.preferences_3.5.200.v20140224-1527
43      ACTIVE      org.eclipse.equinox.registry_3.5.400.v20140428-1507
44      STARTING    org.eclipse.equinox.security_1.2.0.v20130424-1801
                    Fragments=45
45      RESOLVED    org.eclipse.equinox.security.win32.x86_64_1.0.100.v20130327-1442
                    Master=44
46      STARTING    org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203
47      ACTIVE      org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20131217-1203
48      STARTING    org.eclipse.equinox.util_1.0.500.v20130404-1337
49      ACTIVE      org.eclipse.osgi.services_3.4.0.v20140312-2051
50      RESOLVED    org.sat4j.core_2.3.5.v201308161310
51      RESOLVED    org.sat4j.pb_2.3.5.v201404071733
52      ACTIVE      org.apache.derby_10.8.2.2
53      ACTIVE      org.eclipse.gemini.dbaccess.util_1.1.0.RELEASE
54      ACTIVE      osgi.enterprise_4.2.0.201003190513
57      ACTIVE      javax.persistence_2.1.0.v201304241213
58      ACTIVE      org.eclipse.persistence.antlr_3.2.0.v201302191141
59      ACTIVE      org.eclipse.persistence.asm_3.3.1.v201302191223
60      ACTIVE      org.eclipse.persistence.core_2.5.0.v20130507-3faac2b
61      ACTIVE      org.eclipse.persistence.jpa.jpql_2.5.0.v20130507-3faac2b
62      ACTIVE      org.eclipse.persistence.jpa_2.5.0.v20130507-3faac2b
63      ACTIVE      org.eclipse.gemini.jpa_1.2.0.M1
66      ACTIVE      org.eclipse.gemini.jpa.sample.basic_1.2.0.M1
67      ACTIVE      org.eclipse.gemini.dbaccess.derby_1.1.0.RELEASE
osgi>
-Mike
Previous Topic:Springsource ebr down
Next Topic:AbstractMethodError exception problem on query execution
Current Time: Sun Jul 20 14:30:05 EDT 2025
Powered by FUDForum. Page generated in 0.45376 seconds
